Hey Dave, thanks for this! I am still on v4.8 and seems like I should update eventually. I will update my config above as soon as I tested it. Will link yours in the meantime.
In that case here’s the full config for anyone who might find it useful. Note that I’ve commented out some entries that my setup doesn’t have, and also added some new ones for various soil sensor readings.
There’s also a few where WeeWX provides the data but it’s not coming through via MQTT, e.g. wind direction and wind gust, I need to play with that, probably by setting the retained flag on the messages if that’s where the problem lies.
Another note, for the WeeWX integration I’m using Michael Schantl’s WeeWX-MQTT, so this may also depend on which WeeWX extension you’re using to get the data into mosquitto.
# To see what the WeeWX MQTT topics are called:
# mosquitto_sub -v -t "weather/#" -h localhost
mqtt:
# Temperature
- name: weather_station_outtemp_c
unique_id: uniqueid__weather_outtemp_c
icon: mdi:thermometer
state_topic: "weather/outTemp_degree_C"
value_template: "{{ value | round(1) }}"
availability_topic: "weather/connection_status"
payload_available: "online"
payload_not_available: "offline"
unit_of_measurement: "°C"
device_class: temperature
# Not terribly useful because the reading is affected by heat from the
# electronics.
- name: weather_station_intemp_c
unique_id: uniqueid__weather_intemp_c
state_topic: "weather/inTemp_degree_C"
- name: weather_station_dewpoint_c
unique_id: uniqueid__weather_dewpoint_c
state_topic: "weather/dewpoint_degree_C"
# Not present on this station
#- name: weather_station_indewpoint_c
# unique_id: uniqueid__weather_indewpoint_c
# icon: mdi:thermometer
# state_topic: "weather/inDewpoint_degree_C"
# value_template: "{{ value | round(1) }}"
# availability_topic: "weather/connection_status"
# payload_available: "online"
# payload_not_available: "offline"
# unit_of_measurement: "°C"
# device_class: temperature
- name: weather_station_windchill_c
unique_id: uniqueid__weather_windchill_c
state_topic: "weather/windchill_degree_C"
#- name: weather_station_apptemp_c
# unique_id: uniqueid__weather_apptemp_c
# state_topic: "weather/appTemp_degree_C"
- name: weather_station_heatindex_c
unique_id: uniqueid__weather_geatindex_c
state_topic: "weather/heatindex_degree_C"
#- name: weather_station_humidex_c
# unique_id: uniqueid__weather_humindex_c
# # Note spelling mistake in the topic.
# state_topic: "weather/humidex_degree_C"
# Humidity
- name: weather_station_outhumidity
unique_id: uniqueid__weather_outhumidity
icon: mdi:water-percent
state_topic: "weather/outHumidity_percent"
unit_of_measurement: "%"
device_class: humidity
#- name: weather_station_inhumidity
# unique_id: uniqueid__weather_inhumidity
# icon: mdi:water-percent
# state_topic: "weather/inHumidity_percent"
# unit_of_measurement: "%"
# device_class: humidity
# Present but gives same readings as atmospheric pressue
#- name: weather_station_altimeter_mbar
# unique_id: uniqueid__weather_altimeter_atmospheric
# icon: mdi:gauge
# state_topic: "weather/altimeter_mbar"
# value_template: "{{ value | round(0) }}"
# unit_of_measurement: "mbar"
# device_class: atmospheric_pressure
- name: weather_station_pressure_mbar
unique_id: uniqueid__weather_pressure_atmospheric
icon: mdi:gauge
state_topic: "weather/pressure_mbar"
- name: weather_station_barometer_mbar
unique_id: uniqueid__weather_barometer_atmospheric
icon: mdi:gauge
state_topic: "weather/barometer_mbar"
# Wind
- name: weather_station_windspeed_kph
unique_id: uniqueid__weather_windspeed_kph
icon: mdi:weather-windy
state_topic: "weather/windSpeed_km_per_hour"
unit_of_measurement: "km/h"
device_class: wind_speed
- name: weather_station_windgust_kph
unique_id: uniqueid__weather_windgust_kph
icon: mdi:weather-windy-variant
state_topic: "weather/windGust_km_per_hour"
- name: weather_station_winddir
unique_id: uniqueid__weather_winddir
icon: mdi:wind-turbine
state_topic: "weather/windDir_degree_compass"
unit_of_measurement: "°"
#- name: weather_station_windgustdir
# unique_id: uniqueid__weather_windgustdir
# icon: mdi:wind-turbine
# state_topic: "weather/windGustDir"
# unit_of_measurement: "°"
#- name: weather_station_windrun_km
# unique_id: uniqueid__weather_windrun_km
# state_topic: "weather/windrun_km"
# value_template: "{{ value | round(3) }}"
# unit_of_measurement: "km"
# device_class: distance
- name: weather_station_rainrate_cm_per_hour
unique_id: uniqueid__weather_rainrate_cm_per_hour
icon: mdi:umbrella-outline
state_topic: "weather/rainRate_cm_per_hour"
value_template: "{{ (value | float * 10) | round(1) }}"
unit_of_measurement: "cm/h"
device_class: precipitation_intensity
- name: weather_station_rain_cm
unique_id: uniqueid__weather_rain_cm
icon: mdi:umbrella
state_topic: "weather/rain_cm"
unit_of_measurement: "cm"
force_update: true # important!
#- name: weather_station_rain24_mm
# unique_id: uniqueid__weather_rain24_mm
# icon: mdi:umbrella
# state_topic: "weather/rain24_cm"
# value_template: "{{ (value | float * 10) | round(1) }}"
# unit_of_measurement: "mm"
# device_class: precipitation
#- name: weather_station_hourrain_mm
# unique_id: uniqueid__weather_hourrain_mm
# state_topic: "weather/hourRain_cm"
#- name: weather_station_dayrain_mm
# unique_id: uniqueid__weather_dayrain_mm
# state_topic: "weather/dayRain_cm"
#- name: weather_station_weekrain_mm
# unique_id: uniqueid__weather_weekrain_mm
# state_topic: "weather/weekRain_cm"
#- name: weather_station_monthrain_mm
# unique_id: uniqueid__weather_monthrain_mm
# state_topic: "weather/monthRain_cm"
- name: weather_station_evapotranspiration_mm
unique_id: uniqueid__evapotranspiration_mm
icon: mdi:water-opacity
state_topic: "weather/ET_cm"
value_template: "{{ (value | float * 10) | round(5) }}"
# Solar
- name: weather_station_radiation_wpm2
unique_id: uniqueid__weather_radiation_irradiance
icon: mdi:radioactive
state_topic: "weather/radiation_watt_per_meter_squared"
unit_of_measurement: "W/m²"
device_class: irradiance
- name: weather_station_maxsolarrad_wpm2
unique_id: uniqueid__weather_maxsolarrad_irradiance
state_topic: "weather/maxSolarRad_watt_per_meter_squared"
- name: weather_station_cloudbase_meter
unique_id: uniqueid__weather_cloudbase_distance
state_topic: "weather/cloudbase_meter"
unit_of_measurement: "m"
- name: weather_station_uv
unique_id: uniqueid__weather_uv
icon: mdi:sunglasses
state_topic: "weather/UV_uv_index"
unit_of_measurement: ""
# Soil
- name: weather_station_soiltemp1_c
unique_id: uniqueid__weather_soiltemp1_c
state_topic: "weather/soilTemp1_degree_C"
- name: weather_station_soilMoist1_centibar
unique_id: uniqueid__soilMoist1_centibar
state_topic: "weather/soilMoist1_centibar"
unit_of_measurement: "cbar"
- name: weather_station_leafWet1_count
unique_id: uniqueid__leafWet1_count
state_topic: "weather/leafWet1_count"
- name: weather_station_soiltemp2_c
unique_id: uniqueid__weather_soiltemp2_c
state_topic: "weather/soilTemp2_degree_C"
- name: weather_station_soilMoist2_centibar
unique_id: uniqueid__soilMoist2_centibar
state_topic: "weather/soilMoist2_centibar"
- name: weather_station_leafWet2_count
unique_id: uniqueid__leafWet2_count
state_topic: "weather/leafWet2_count"
# Misc
- name: weather_station_weewx_update_datetime
unique_id: uniqueid__weather_datetime
icon: mdi:calendar-clock
state_topic: "weather/dateTime_unix_epoch"
value_template: "{{ value | int | timestamp_local() }}"
device_class: timestamp
template:
- binary_sensor:
- name: weather_station_weewx_connected
unique_id: uniqueid__weather_connected
icon: mdi:calendar-sync-outline
state: >
{%- set seconds = (now() - states.sensor.weather_station_weewx_update_datetime.last_changed).total_seconds() -%}
{{ seconds < 120 }}
availability: >
{{ has_value('sensor.weather_station_weewx_update_datetime') }}
device_class: connectivity
I just noticed, from a comment on Matthew Wall’s WeeWX-MQTT, that you may be using that instead of Michael Schantl’s one. So the naming difference may be due to the different code base… both of them are a bit of a headache, they were written for now out-of-date versions of WeeWX and paho-mqtt and it looks like neither are taking updates. I went with the MS version rather than the MW version because it was easier to get going with WeeWX 5.x and HA, but it doesn’t seem to honour the persistence flag, possibly because the version of paho-mqtt it’s using is too old to support it.
In the interests of sacrifice for the communal good I’ve uninstalled the MS WeeWX-MQTT and instead installed the MW WeeWX-MQTT, which exposes the missing topics. So you need a different HA YAML config depending on whether you use the MS WeeWX-MQTT or the MW WeeWX-MQTT.
For those just joining us, there are two things called WeeWX-MQTT, one by Michael Schantl (MS), one by Matthew Wall (MW). Both date from about the same time and haven’t been updated for awhile, which means they’re tied to old versions of the paho-mqtt library so you’ll need to pip install paho-mqtt==$old_version
, as well as change the install command from wee_extension --install
to weectl extension install
for WeeWX 5.x.
In terms of which one to go with, MW-WeeWX-MQTT is slightly more configurable than MS-WeeWX-MQTT, as well as exposing a few more topics (actually synthetic topics like rainfall in the last 24 hours). For that one the paho-mqtt version needed is 1.6.1, so pip install paho-mqtt==1.6.1
Here’s the final updated config, currently set up for MW WeeWX-MQTT but with comments indicating what to change for MS WeeWX-MQTT, there are also comments for other sensors/topics that have special considerations. This also includes soil/leaf sensors if you have those.
Tested to work with WeeWX 5.x up to the latest release, 5.1.0, with credit to @ThomDietrich whose work this is based on.
# Michael Schantl's WeeWX-MQTT provides "weather/connection_status" but
# Matthew Wall's WeeWX-MQTT doesn't, or at least its status is always
# reported as "offline" so the availability check is commented out for
# this version.
mqtt:
# Temperature
# MW also makes this available as outTemp_C
# MW has inTemp_C, MS has inTemp_degree_C.
# electronics.
state_topic: "weather/inTemp_C"
# MW also makes this available as windchill_C.
# Present in MW, not present in MS.
state_topic: "weather/appTemp_C"
# Humidity
# MW also makes this available as outHumidity.
# icon: mdi:gauge
icon: mdi:gauge
icon: mdi:gauge
# Wind
# MW also makes this available as windSpeed_kph.
# windGust_kph in MW, windGust_km_per_hour in MS
# state_topic: "weather/windGust_km_per_hour"
state_topic: "weather/windGust_kph"
icon: mdi:umbrella
icon: mdi:umbrella
icon: mdi:umbrella
icon: mdi:umbrella
# Solar
# MW also makes this available as radiation_Wpm2
# MW also makes this available as maxSolarRad_Wpm2
# MW also makes this available as UV.
# Soil
# MW has soilTemp1_C, MS has soilTemp1_degree_C.
state_topic: "weather/soilTemp1_C"
# There's also a matching leafTemp1_C but this is just a copy of
# soilTemp1_C.
# MW has soilTemp2_C, MS has soilTemp2_degree_C.
state_topic: "weather/soilTemp2_C"
# There's also a matching leafTemp2_C but this is just a copy of
# soilTemp2_C.
# Misc
template:
- binary_sensor:
state: >
{{ seconds < 120 }}
availability: >
homeassistant:
customize:
sensor.weather_station_outtemp_c:
friendly_name: "Temperature"
sensor.weather_station_intemp_c:
friendly_name: "Temperature (indoors)"
sensor.weather_station_dewpoint_c:
friendly_name: "Dew Point"
sensor.weather_station_windchill_c:
friendly_name: "Wind Chill"
sensor.weather_station_apptemp_c:
friendly_name: "Apparent Temperature"
sensor.weather_station_heatindex_c:
friendly_name: "Heat Index"
sensor.weather_station_humidex_c:
friendly_name: "Humidity Index"
sensor.weather_station_outhumidity:
friendly_name: "Humidity"
sensor.weather_station_pressure_mbar:
friendly_name: "Pressure"
sensor.weather_station_barometer_mbar:
friendly_name: "Barometer"
sensor.weather_station_windspeed_kph:
friendly_name: "Wind Speed"
sensor.weather_station_windgust_kph:
friendly_name: "Wind Gust"
sensor.weather_station_winddir:
friendly_name: "Wind Direction"
sensor.weather_station_windgustdir:
friendly_name: "Wind Gust Direction"
sensor.weather_station_windrun_km:
friendly_name: "Wind Run"
weather_station_rainrate_cm_per_hour:
friendly_name: "Rain Rate"
sensor.weather_station_rain_cm:
friendly_name: "Rain"
sensor.weather_station_rain24_mm:
friendly_name: "Rain (24 hours)"
sensor.weather_station_hourrain_mm:
friendly_name: "Rain (hour)"
sensor.weather_station_dayrain_mm:
friendly_name: "Rain (day)"
sensor.weather_station_evapotranspiration_mm:
friendly_name: "Evapotranspiration"
weather_station_radiation_wpm2:
friendly_name: "Solar Radiation"
sensor.weather_station_maxsolarrad_wpm2:
friendly_name: "Solar Radiation (max)"
sensor.weather_station_cloudbase_meter:
friendly_name: "Cloud Base"
sensor.weather_station_uv:
friendly_name: "UV Index"
sensor.weather_station_soiltemp1_c:
friendly_name: "Soil Temperature 1"
sensor.weather_station_soilMoist1_centibar:
friendly_name: "Soil Moisture 1"
weather_station_leafWet1_count:
friendly_name: "Leaf Wetness 1"
sensor.weather_station_soiltemp2_c:
friendly_name: "Soil Temperature 2"
sensor.weather_station_soilMoist2_centibar:
friendly_name: "Soil Moisture 2"
sensor.weather_station_leafWet2_count:
friendly_name: "Leaf Wetness 2"
Amazing work. Thanks Dave!
