Ladies, Gents,
i´m not a newbee, but 52 y old and not a skilled mqtt pro.
system: raspi 3b+ with 120gb ssd: hass core 0.112.2 OS 4.10 mosquitto broker
weewx on another raspi.
currently i´m asking the weewx server via mqtt broker for new weather data. log:
1594996516: New connection from 192.168.0.15 on port 1883.
1594996516: New client connected from 192.168.0.15 as weewx_36f5aed1 (p2, c1, k60, u’xxxxxxx’).
1594996517: Client weewx_36f5aed1 disconnected.
1594996593: Saving in-memory database to /data/mosquitto.db.
1594996816: New connection from 192.168.0.15 on port 1883.
[INFO] found xxxxxxx on local database
1594996817: New client connected from 192.168.0.15 as weewx_2c1ea416 (p2, c1, k60, u’xxxxxxx’).
1594996818: Client weewx_2c1ea416 disconnected.
1594997119: New connection from 192.168.0.15 on port 1883.
1594997120: New client connected from 192.168.0.15 as weewx_d92fbd1c (p2, c1, k60, u’xxxxxxx’).
1594997121: Client weewx_d92fbd1c disconnected.
so far, so good, but where are the data? how can i integrate the data into hass.io ?
i´ve checked with the mqtt explorer, if there are the data and voila
ok, but how to subscribe the wx-variables and how can i integrate them?
any help is very appreciated,
greez michl
Great! Thank you @Burningstone !
Is there a way to reduce the number of decimals?
You can round the result in the value_template part of the sensor. Can you show your current working code please?
this is the part from configuration.yaml
mqtt sensor
- platform: mqtt
state_topic: “weather/outTemp_C”
unit_of_measurement: ‘°C’
Please read this topic , especially point 11 regarding the correct formatting of code in the forum.
You can use a value_template to round your value.
Try this:
- platform: mqtt
value_template: "{{ (value | round(2)) | float }}"
I’m not sure if the last float filter is needed, you can probably remove it, can’t test at the moment.
Thank you @Burningstone for help and hints regarding correct formatting.
and no problem, i´ll play around and will inform if this thing works.
works like a charme.
i had to adapt the quotation marks and reduced to 1 decimal, now this is working fine:
- platform: mqtt
state_topic: "weather/outTemp_C"
unit_of_measurement: '°C'
value_template: "{{ (value | round(1)) | float }}"
Thx for helping a silversurfer
Posting a complete list of weewx entities here to make it easier for others.
Enjoy!
Beware: Apprarently there were some changes with WeeWX 5.0:
It looks like the names have changed again, possibly due to the WeeWX 5.x update. Or at least ThomDietrich ’s very useful config doesn’t work any more with the current version. Here’s a partial list of what currently works, if it’s useful I’ll post the full thing.
mqtt:
# Temperature
- name: weather_station_outtemp_c
unique_id: uniqueid__weather_outtemp_c
icon: mdi:thermometer
state_topic: "weather/outTemp_degree_C"
value_template: "{{ value | round(1…
Config for weewx 4.8:
mqtt:
value_template: "{{ value | round(1) }}"
availability_topic: "weather/availability"
unit_of_measurement: "°C"
device_class: temperature
- name: weather_station_intemp_c
unique_id: uniqueid__weather_intemp_c
state_topic: "weather/inTemp_C"
- name: weather_station_dewpoint_c
unique_id: uniqueid__weather_dewpoint_c
state_topic: "weather/dewpoint_C"
- name: weather_station_indewpoint_c
unique_id: uniqueid__weather_indewpoint_c
state_topic: "weather/inDewpoint_C"
- name: weather_station_windchill_c
unique_id: uniqueid__weather_windchill_c
state_topic: "weather/windchill_C"
- name: weather_station_apptemp_c
unique_id: uniqueid__weather_apptemp_c
state_topic: "weather/appTemp_C"
- name: weather_station_heatindex_c
unique_id: uniqueid__weather_geatindex_c
state_topic: "weather/heatindex_C"
- name: weather_station_humidex_c
unique_id: uniqueid__weather_humindex_c
state_topic: "weather/humidex_C"
- name: weather_station_outhumidity
unique_id: uniqueid__weather_outhumidity
icon: mdi:water-percent
state_topic: "weather/outHumidity"
unit_of_measurement: "%"
device_class: humidity
- name: weather_station_inhumidity
unique_id: uniqueid__weather_inhumidity
state_topic: "weather/inHumidity"
- name: weather_station_altimeter_mbar
unique_id: uniqueid__weather_altimeter_atmospheric
icon: mdi:gauge
state_topic: "weather/altimeter_mbar"
value_template: "{{ value | round(0) }}"
unit_of_measurement: "mbar"
device_class: atmospheric_pressure
- name: weather_station_pressure_mbar
unique_id: uniqueid__weather_pressure_atmospheric
icon: mdi:gauge
state_topic: "weather/pressure_mbar"
- name: weather_station_barometer_mbar
unique_id: uniqueid__weather_barometer_atmospheric
icon: mdi:gauge
state_topic: "weather/barometer_mbar"
- name: weather_station_windspeed_kph
unique_id: uniqueid__weather_windspeed_kph
icon: mdi:weather-windy
state_topic: "weather/windSpeed_kph"
unit_of_measurement: "km/h"
device_class: wind_speed
- name: weather_station_windgust_kph
unique_id: uniqueid__weather_windgust_kph
icon: mdi:weather-windy-variant
state_topic: "weather/windGust_kph"
- name: weather_station_winddir
unique_id: uniqueid__weather_winddir
icon: mdi:wind-turbine
state_topic: "weather/windDir"
unit_of_measurement: "°"
- name: weather_station_windgustdir
unique_id: uniqueid__weather_windgustdir
state_topic: "weather/windGustDir"
- name: weather_station_windrun_km
unique_id: uniqueid__weather_windrun_km
state_topic: "weather/windrun_km"
value_template: "{{ value | round(3) }}"
unit_of_measurement: "km"
device_class: distance
- name: weather_station_rainrate_mm_per_hour
unique_id: uniqueid__weather_rainrate_mm_per_hour
icon: mdi:umbrella-outline
state_topic: "weather/rainRate_cm_per_hour"
value_template: "{{ (value | float * 10) | round(1) }}"
unit_of_measurement: "mm/h"
device_class: precipitation_intensity
- name: weather_station_rain_mm
unique_id: uniqueid__weather_rain_mm
icon: mdi:umbrella
state_topic: "weather/rain_cm"
unit_of_measurement: "mm"
force_update: true # important!
- name: weather_station_rain24_mm
unique_id: uniqueid__weather_rain24_mm
icon: mdi:umbrella
state_topic: "weather/rain24_cm"
- name: weather_station_hourrain_mm
unique_id: uniqueid__weather_hourrain_mm
icon: mdi:umbrella
state_topic: "weather/hourRain_cm"
- name: weather_station_dayrain_mm
unique_id: uniqueid__weather_dayrain_mm
icon: mdi:umbrella
state_topic: "weather/dayRain_cm"
- name: weather_station_evapotranspiration_mm
unique_id: uniqueid__evapotranspiration_mm
icon: mdi:water-opacity
state_topic: "weather/ET_cm"
value_template: "{{ (value | float * 10) | round(5) }}"
- name: weather_station_radiation_wpm2
unique_id: uniqueid__weather_radiation_irradiance
icon: mdi:radioactive
state_topic: "weather/radiation_Wpm2"
unit_of_measurement: "W/m²"
device_class: irradiance
- name: weather_station_maxsolarrad_wpm2
unique_id: uniqueid__weather_maxsolarrad_irradiance
state_topic: "weather/maxSolarRad_Wpm2"
- name: weather_station_cloudbase_meter
unique_id: uniqueid__weather_cloudbase_distance
state_topic: "weather/cloudbase_meter"
unit_of_measurement: "m"
- name: weather_station_uv
unique_id: uniqueid__weather_uv
icon: mdi:sunglasses
state_topic: "weather/UV"
unit_of_measurement: ""
- name: weather_station_weewx_update_datetime
unique_id: uniqueid__weather_datetime
icon: mdi:calendar-clock
state_topic: "weather/dateTime"
value_template: "{{ value | int | timestamp_local() }}"
device_class: timestamp
template:
- binary_sensor:
- name: weather_station_weewx_connected
unique_id: uniqueid__weather_connected
icon: mdi:calendar-sync-outline
state: >
{%- set seconds = (now() - states.sensor.weather_station_weewx_update_datetime.last_changed).total_seconds() -%}
{{ seconds < 120 }}
availability: >
{{ has_value('sensor.weather_station_weewx_update_datetime') }}
device_class: connectivity
homeassistant:
customize:
sensor.weather_station_outtemp_c:
friendly_name: "Ventus W830 Temperatur"
sensor.weather_station_intemp_c:
friendly_name: "Ventus W830 Temperatur (innen)"
sensor.weather_station_dewpoint_c:
friendly_name: "Ventus W830 Taupunkt"
sensor.weather_station_indewpoint_c:
friendly_name: "Ventus W830 Taupunkt (innen)"
sensor.weather_station_windchill_c:
friendly_name: "Ventus W830 Windkühle"
sensor.weather_station_apptemp_c:
friendly_name: "Ventus W830 gefühlte Temperatur"
sensor.weather_station_heatindex_c:
friendly_name: "Ventus W830 Hitzeindex"
sensor.weather_station_humidex_c:
friendly_name: "Ventus W830 Luftfeuchte-Index"
sensor.weather_station_outhumidity:
friendly_name: "Ventus W830 Luftfeuchte"
sensor.weather_station_inhumidity:
friendly_name: "Ventus W830 Luftfeuchte (innen)"
sensor.weather_station_altimeter_mbar:
friendly_name: "Ventus W830 Luftdruck (Altimeter, QNH)"
sensor.weather_station_pressure_mbar:
friendly_name: "Ventus W830 Luftdruck (Absolut, QFE)"
sensor.weather_station_barometer_mbar:
friendly_name: "Ventus W830 Luftdruck (Meeresspiegel, Temperatur, QFF)"
sensor.weather_station_windspeed_kph:
friendly_name: "Ventus W830 Windgeschwindigkeit"
sensor.weather_station_windgust_kph:
friendly_name: "Ventus W830 Böengeschwindigkeit"
sensor.weather_station_winddir:
friendly_name: "Ventus W830 Windrichtung"
sensor.weather_station_windgustdir:
friendly_name: "Ventus W830 Böenrichtung"
sensor.weather_station_windrun_km:
friendly_name: "Ventus W830 Windlauf"
sensor.weather_station_rainrate_mm_per_hour:
friendly_name: "Ventus W830 Regenrate"
sensor.weather_station_rain_mm:
friendly_name: "Ventus W830 Regen"
sensor.weather_station_rain24_mm:
friendly_name: "Ventus W830 Regen (24h)"
sensor.weather_station_hourrain_mm:
friendly_name: "Ventus W830 Regen (Stunde)"
sensor.weather_station_dayrain_mm:
friendly_name: "Ventus W830 Regen (Tag)"
sensor.weather_station_evapotranspiration_mm:
friendly_name: "Ventus W830 EvapoTranspiration (ET)"
sensor.weather_station_radiation_wpm2:
friendly_name: "Ventus W830 Sonnenstrahlung"
sensor.weather_station_maxsolarrad_wpm2:
friendly_name: "Ventus W830 Sonnenstrahlung Maximum"
sensor.weather_station_cloudbase_meter:
friendly_name: "Ventus W830 Wolkenuntergrenze"
sensor.weather_station_uv:
friendly_name: "Ventus W830 UV-Index"
sensor.weather_station_weewx_update_datetime:
friendly_name: "Ventus W830 Letzte Aktualisierung"
binary_sensor.weather_station_weewx_connected:
friendly_name: "Ventus W830 Regelmäßige Aktualisierungen"
Hello all
I am trying to bring this example into the MQTT format for version 2022.12.0.
Unfortunately I have absolutely no idea how and all attempts to bring the upper into a mqtt.yaml fail.
I hope you can help me with this as I don’t really understand the new format.
Many thanks in advance
Guido
Hey, was confused as you are talking about changes in 2022.12. I believe these changes came some releases ago BUT the old format was deprecated with 2022.12.
Anyhow, it’s not that complicated of a change. I’ve just updated my post above with the working weewx.yaml configuration. Hope it works for you as well!
ThomDietrich:
Hello ThomDietrich
Thanks for the change
I was able to save the file mqtt.yaml successfully with your information.
However, I still get an error message.
I have this entry in configuration.yaml:
mqtt: !include mqtt.yaml
and I get the following error message:
Invalid config for [mqtt]: [mqtt] is an invalid option for [mqtt]. Check: mqtt->mqtt->mqtt. (See /config/configuration.yaml, line 10)
Do I have to make another entry in configuration.yaml?
You need to learn about packages. I always felt that the concept and a base configuration should be part of the default configuration! Anyhow, please read here: Packages - Home Assistant
In your configuration.yaml add:homeassistant:
packages: !include_dir_named packages
Create the folder packages
Create and fill packages/weewx.yaml with the content above.
In parallel you can create all kinds of yaml files, for topics. Here is a random example I found via google: home-assistant-config/packages at master · aneisch/home-assistant-config · GitHub
Thank you for your help with my problem.
Everything is now working as it should.
I wish you all a merry and healthy christmas.
Guido
JTailor
(J Tailor)
March 2, 2023, 3:25pm
15
Is it possible to send the MQTT section of your weewx.conf file ?
I have problems with reading the values ?
Grtz
hi, this is the section in the weewx.conf
[[MQTT]]
server_url = mqtt://username:[email protected] :1883
topic = weather
unit_system = METRIC
retain = True
username & password have to be defined in the config of the mosquitto broker @homeassistant in the config tab. hope it helps.
greez
noxx
(Ralf B)
August 18, 2023, 6:51am
18
Have Problems to receive data of my weewx station.
i installed the addon in weewx and add this to my config:
[[MQTT]]
server_url = mqtt://mqtt_user:[email protected] :1883
topic = weather
i also added this to my configuration.yaml in HA.
# Weatherstation WEEWX-MQTT
mqtt:
- state_topic: "weather/outTemp_C"
name: "Outdoor Temperature"
unit_of_measurement: "C"
device_class: "temperature"
icon: "mdi:thermometer"
- state_topic: "weather/windSpeed_kmh"
unit_of_measurement: "kmh"
icon: "mdi:weather-windy-variant"
- state_topic: "weather/windGust_kmh"
icon: "mdi:weather-windy"
in the LOG of the Mosquitto Broker i see only
023-08-18 07:25:43: New connection from 192.168.1.215:36185 on port 1883.
2023-08-18 07:25:43: New client connected from 192.168.1.215:36185 as weewx_e7f53078 (p2, c1, k60, u'mqtt_user').
2023-08-18 07:26:45: New connection from 172.30.32.2:54454 on port 1883
Log in weewx looks ok…
Aug 18 08:36:42 raspberrypi weewx[874] INFO user.mqtt: data will be uploaded to mqtt://mqtt_user:[email protected] :1883
Aug 18 08:40:37 raspberrypi weewx[874] INFO user.mqtt: client established for mqtt://mqtt_user:[email protected] :1883
Aug 18 08:40:37 raspberrypi weewx[874] INFO weewx.restx: MQTT: Published record 2023-08-18 08:40:00 CEST (1692340800)
ozczecho
(Mike)
August 18, 2023, 1:16pm
19
@noxx - try
- name: My Temperature
state_topic: "weather/loop"
value_template: '{{ value_json.outTemp_C | round(1) }}'
Hello @noxx ,
First thing that immediately catches my eye: in MQTT Explorer we can see windSpeed_kph but you are trying to subscribe to windSpeed_kmh in HA. Please check your definitions.
mqtt:
# Temperature
availability_topic: "weather/connection_status"
payload_available: "online"
payload_not_available: "offline"
state_topic: "weather/inTemp_degree_C"
state_topic: "weather/dewpoint_degree_C"
state_topic: "weather/inDewpoint_degree_C"
state_topic: "weather/windchill_degree_C"
state_topic: "weather/appTemp_degree_C"
state_topic: "weather/heatindex_degree_C"
# Note spelling mistake in the topic.
state_topic: "weather/humidex_degree_C"
# Humidity
state_topic: "weather/outHumidity_percent"
state_topic: "weather/inHumidity_percent"
icon: mdi:gauge
icon: mdi:gauge
icon: mdi:gauge
One caveat is that some of those entries aren’t available for all station types, so you may need to add or remove pieces depending on what you’ve got available.
