I’m having some strange things happen with authentication with esphome.
When I flash a previously used ESP with a new esphome device, it is causing another device to require re-authentication. I’m no sure how this is happening as the esp32 is bein completely reflashed.
When I plug the unused ESP in and power it up, it immediately requires another device on esphome to be re-authenticated.
If I try pull the logs of this newly created ESP device, it fails with an authentication error.
If I unplug the new esp32 device that I am flashing, and click re-authenticate, it re authenticates immediately without asking for the password and remains authenticated until I plug this esp32 back in?
The device just keeps failing authentication, even after I manually input the authentication key.
Any idea whats going on here, have tried rebooting HA multiple time to clear anything like cache etc.
