Weird automation behaviour
So I’m having a slightly strange automation issue.
9 times out of 10 the automation works perfectly, but there have been occasions where the light does not turn off, which it should following the automation.
The automation is a motion activated light, with sun condition and timeout of 120 seconds.
I have found now that on 2 or 3 occasions the light after activation from the automation, has just stayed on indefinitely.
Any ideas? Can post same yaml later when I get home.
Also, if possible, post the automation’s trace when this happened :
