Hey all,
I am seeing a strange issue when calling remote.send_command service from a UI element as its tap action. I am trying to build a custom remote controller UI in lovelace, and I am using the following sample code for one of the buttons:
type: custom:button-card
color: transparent
color_type: card
icon: mdi:arrow-left
styles:
card:
- height: 90px
- width: 90px
- color: var(--button-card-text-color)
- border-radius: 50%
- border: 1px solid var(--button-card-text-color)
- background-color: var(--button-card-on-background)
tap_action:
action: call-service
service: remote.send_command
device: '77622271'
command: DirectionUp
device_id: b1250f2888560dbbb3970b3378d08465
I have a Logitech Harmony remote that I am trying to send commands through. Following the instructions for the Harmony integration, I came up with the tap_action section seen above. When I use the developer tools to run the following service, it works just fine, and the command registers on my TV as expected:
device: '77622271'
However, when the above service is called as part of the tap_action of the remote controller UI button, I get the following error appearing in the bottom left corner:
I obviously have data[‘command’] provided. I have tried putting the command in single quotes, but I still get the same error.
Here is where it gets interesting though: as far as I can tell, there is not a single entry about this in the Home Assistant logs. I even have my logging set to “debug”, so I can get as much detail logged as possible. But there is not a single entry regarding this error. When I intentionally introduce an unexpected key to the command, I get an error that also registers in the Home Assistant logs.
logger:
default: debug
logs:
homeassistant.components.zha: debug
zigpy: debug
Looking forward to some ideas here. Maybe I am doing something obviously wrong that someone can point out.
Thanks!
