Ive got a couple of simple automation which use dictionaries and dictionaries in both are mirrored.
- alias: Set Central Heating Temporary Mode
initial_state: on
- platform: state
entity_id: input_select.central_heating_temporary_mode
- service: automation.turn_off
entity_id: automation.get_central_heating_temporary_mode
- service: mqtt.publish
data_template:
topic: "ebusd/f47/Hc1SFMode/set"
payload: >
{% set tpmode = {
'None': 'none',
'Day away': 'onedayholiday',
'Day in': 'onedaybankholiday',
'Party': 'party' } %}
{{ tpmode.get(trigger.to_state.state,'none') }}
- delay: 00:00:05
- service: automation.turn_on
- alias: Get Central Heating Temporary Mode
initial_state: on
- platform: mqtt
topic: "ebusd/f47/Hc1SFMode"
service: input_select.select_option
data_template:
option: >
{% set tpmode = {
'none': 'None',
'onedayholiday': 'Day away',
'onedaybankholiday': 'Day in',
'party': 'Party' } %}
{{ tpmode.get('trigger.payload','None') }}
Unfortunately, the second one doesnt seem to work and Home Assistant throws out an error:
Logger: homeassistant.components.automation.get_central_heating_temporary_mode
Source: helpers/script.py:1122
Integration: Automation ([documentation](https://www.home-assistant.io/integrations/automation), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+automation%22))
First occurred: November 23, 2020, 8:04:30 PM (313 occurrences)
Last logged: 1:14:05 AM
* Get Central Heating Temporary Mode: Error executing script. Invalid data for call_service at pos 1: string value is None for dictionary value @ data['option']
* Get Central Heating Temporary Mode: Already running
logger: homeassistant.components.automation.get_central_heating_temporary_mode
Source: core.py:1405
First occurred: November 23, 2020, 8:04:30 PM (311 occurrences)
While executing automation automation.get_central_heating_temporary_mode
Traceback (most recent call last): File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 433, in async_trigger await self.action_script.async_run( File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1010, in async_run await asyncio.shield(run.async_run()) File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 245, in async_run await self._async_step(log_exceptions=False) File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 253, in _async_step await getattr( File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 460, in _async_call_service_step await service_task File "/usr/src/homeassistant/homeassistant/core.py", line 1405, in async_call processed_data = handler.schema(service_data) File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 218, in __call__ return self._exec((Schema(val) for val in self.validators), v) File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 340, in _exec raise e if self.msg is None else AllInvalid(self.msg, path=path) File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 336, in _exec v = func(v) File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 272, in __call__ return self._compiled([], data) File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 817, in validate_callable return schema(data) File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 272, in __call__ return self._compiled([], data) File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 594, in validate_dict return base_validate(path, iteritems(data), out) File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 432, in validate_mapping raise er.MultipleInvalid(errors) voluptuous.error.MultipleInvalid: string value is None for dictionary value @ data['option']
I don’t really get it, why only one errors if both have almost same dictionaries but mirrored.
