msavazzi
(Massimo Savazzi)
1
I have these errors in the log:
but my configuration is very simple:
I’ve deleted all test scene and scripts
but when I open the YAML file I find:
There are multiple and only the last one appears to be correct. the others appear to be old.
Why they are still there?
I only created and deleted from the UI
Even If I go under entities and filter:
So questions are:
- why I get the errors in the log and how to fix them
- why the YAML are not aligned with the UI?
You have nothing, that is perfect, i wish to have no errors at all you probably missed to paste the error
I even couldn’t see a log yet, that is unifi dashboard, showing all active clients.
msavazzi
(Massimo Savazzi)
5
@anon63427907 @avd706 sorry me dummy I’ve posted the wrong image not the log of HA but the list of devices… now I’ve updated with the correct image
Can you also post your configuration.yaml, i assume there is something wrong around automations:
msavazzi
(Massimo Savazzi)
7
here we go:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
#sensor: !include sensors.yaml
# Example configuration.yaml entry
- platform: qnap
host: !secret qnap_1_host
port: !secret qnap_1_port
username: !secret qnap_1_username
password: !secret qnap_1_password
ssl: !secret qnap_1_ssl
verify_ssl: !secret qnap_1_verify_ssl
monitored_conditions:
- status
- system_temp
- cpu_temp
- cpu_usage
- memory_free
- memory_used
- volume_size_free
- volume_size_used
switch:
switches:
ewelink_virtual_switch:
turn_on:
service: switch.turn_on
turn_off:
service: switch.turn_off
cover:
covers:
ewelink_virtual_cover:
open_cover:
service: cover.open_cover
close_cover:
service: cover.close_cover
stop_cover:
service: cover.stop_cover
set_cover_position:
service: cover.set_cover_position
fan:
fans:
ewelink_virtual_fan:
value_template: "{{ states('input_boolean.state') }}"
turn_on:
service: fan.turn_on
turn_off:
service: fan.turn_off
set_preset_mode:
service: fan.set_preset_mode
automations.yaml
[core-ssh config]$ more automations.yaml
- id: '1642012201265'
alias: Fancoil Sync
description: Power Off Fancoil if Tado is not heating
- type: value
platform: device
device_id: ecd4748dc635832b71643e0acb87e259
entity_id: sensor.calorifero_studio_heating
domain: sensor
condition: []
- choose:
- conditions:
- type: is_value
condition: device
domain: sensor
above: 1
sequence:
- scene: scene.t_06_2_on
default:
- scene: scene.t_08_1_on
mode: single
- id: '1642015488549'
alias: Fancoil Sync
- type: value
platform: device
domain: sensor
condition: []
- choose:
- conditions:
- type: is_value
condition: device
domain: sensor
above: 1
sequence:
default:
mode: single
- id: '1642015836377'
alias: FanCoil Sync
description: ''
- platform: state
entity_id: sensor.piano_interrato_heating
condition: []
- choose:
- conditions:
- condition: numeric_state
above: '1'
sequence:
- service: switch.turn_on
entity_id: switch.1000f7f6ae_2
default:
- service: switch.turn_off
mode: single
msavazzi
(Massimo Savazzi)
10
@anon63427907 but in the UI I do see only 1 automation while in the yaml I have 3 and also why I get the error?
tom_l
11
Try writing them without using device automations. Use state/numeric_state triggers and conditions instead.
