Weird input_select error in log
Just noticed these errors in my log:
2018-12-22 17:19:01 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/usr/local/lib/python3.6/site-packages/homeassistant/core.py", line 1098, in async_call
    raise ServiceNotFound(domain, service) from None
homeassistant.exceptions.ServiceNotFound: (ServiceNotFound(...), 'Service input_select.turn_off not found')
2018-12-22 17:19:21 WARNING (MainThread) [aiohttp.websocket] websocket connection is closing.
2018-12-22 17:24:27 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
I have scoured my YAMl from top to bottom. Nowhere do I try to call input_select.turn_off
There is something seriously screwy with the input_select code. Also see this: Input Select bug? HA mixes up values at startup
Do you have any groups that contain input_selects? If so, you will get this when the group is switched on/off.
That’s that mystery solved then. Ta.
I do have an all lounge lights group. I could put that in and hide the card control.
