So I have two helper groups, Lamps and Guest Lamps, that contains a pair of lights in each group. Both are exposed in Alexa via Home Assistant and I can toggle them ON/OFF via the Alexa App but the VOICE command to toggle on/off ONLY works on the Lamps group and not the Guest Lamps group. The weird part is in the Logbook entries for the calls the Lamps is calling service light turn_on/off for lights.lamps but on the Guest Lamps group its calling switch.guest_lamps.
Here are the Logbook entries:
Here is the entities:
So anyone know what gives?
I’ve toggled the Voice Assistant exposed entities for Guest Lamps but no luck…
