Weird Problem: Text not updating from HA sensors, all other sensor are fine
I am having a very strange problem. Hope one of you good folks here have some ideas because I am going nuts with this.
Trying to get text from HA to ESPHome. All other HA sensors appear fine in ESPHome and vice a versa eg device sending sensor data to HA.
Have tried numerous approaches and have now really pared it back. So have tried 2 different sources of text in HA.
1 text input helper
2 constant value txt sensor (ha yaml below)
test_txt_sensor:
          friendly_name: 'Test Text'
          unique_id: 'sensor.bschet'
          value_template: 'Hello Test'
On the ESP side I have the following
text_sensor:
  - platform:  homeassistant
    name: "Heat Schedule"
    entity_id:  sensor.bschet
    internal: true
    on_value:
      then:
        - lambda: |-
            ESP_LOGD("main", "The current sched is %s", x.c_str());
    entity_id: input_text.text1
    on_value:
       then:
         - lambda:  ESP_LOGD("main", "The current text is %s", x.c_str());
Also have tried to use the values outside of the on_value triggers with no luck and just to check the rest of the ESP code I set up a static template text sensor snippet below. All of the display works as expected.
    name: "Template Text Sensor"
    internal: true
    lambda: |-
      return {"Hello World"};
    update_interval: 60s
I cant see any errors in the detailed logs and they are set to VERY_VERBOSE as this is the only way the nextion display to work correctly. Haven’t got to the bottom of that one either.
Thank you in advance
All the sensors are set internal: true this hides them from the front end of home assistant.
This sensor by not setting a name: is the same as setting internal: true
    on_value:
       then:
So either remove internal: true or add a name to the above depending on the sensor you want displayed.
Hi Mike,
Thanks for the reply.
Change the code as suggested but has not solved the issue. Have checked both sensor values that are visible as sensors in HA from the ESP device both are > Unknown
the test code now looks like this
text_sensor:
    on_value:
      then:
        - lambda: |-
            ESP_LOGD("main", "The current schedba is %s", x.c_str());
    name: "text test sensor"
    on_value:
       then:
         - lambda:  ESP_LOGD("main", "The current schedbb is %s", x.c_str());
    internal: true
    lambda: |-
Im beginning to wonder about incompatible versions BTW ESP latest 2022.1.2 & HA core-2021.12.2 both running in separate docker containers.
Also I wonder about this post from last year Can’t get a sensor value from the homeassistant “text_sensor” or from “sensor”
What is that integration?
This is just a hardcoded test sensor. What I am actually trying to do is send schedule information from the hacs schedule component. But to do that I need to send a csv text string. But I simplified the code to explain the problem
Are you trying to implement the use of input text? That would be something like this:
input_text:
  bschet:
    initial: Hello Test
I have never heard of that integration. I think you have made that up.
Its a custom card and custom component Scheduler card/custom component
I want to use it to define a schedule for the esp device that controls my biomass plant room. So the ESP needs to know the schedule so if I have a wifi or HA failure the controller still works
I have already set up the input helper via the gui that did help either that what drive input_text.text1
What does sensor.bschet say in developer tools/states.
The HA sensors sensor.bschet & input_text.text1 have right values but when I followed mike’s advice post #2 and published the ESP values back to HA both ESP values where unknown when the device was on and unavailable when the device was switch off.
I am going try to remove the ESP device from HA and re add it. Another post with a similar issue said it resolved it.
That did not resolve the issue :frowning_face:
Any other thoughts?
How do I get detailed logs from HA? Just clutching at straws
I get the feeling that you have probably changed a few things now, can you post:
  1. your esphome yaml
  2. any relevant ha yaml
  3. your esphome logs
This is the esp device yaml
esphome:
  platform: ESP8266
  board: d1_mini
  on_boot:
    then:
      # read the RTC time once when the system boots
      ds1307.read_time:
wifi:
  ssid: !secret wifi_ssid
  fast_connect: true
api:
  password: !secret api_password
  services:
    - service: update_nextion
      then:
        - lambda: 'id(disp1)->upload_tft();'
ota:
  password: !secret ota_password
logger:
    baud_rate: 0     # Disable UART logging (pins GPIO1/3 are used for Nextion communication)
    level: VERY_VERBOSE
    logs:
        api: VERY_VERBOSE
        homeassistant: VERY_VERBOSE
        nextion: VERY_VERBOSE
        api.service: VERY_VERBOSE
        sensor: VERY_VERBOSE
        scheduler: DEBUG
captive_portal:
uart:
  rx_pin: D6
  tx_pin: D7
  baud_rate: 115200
time:
  - platform: ds1307
    # repeated synchronization is not necessary unless the external RTC
    # is much more accurate than the internal clock
    update_interval: never
    # instead try to synchronize via network repeatedly ...
    on_time_sync:
      then:
        # ... and update the RTC when the synchronization was successful
        ds1307.write_time:
http_request:
i2c:
  sda: D2
  scl: D1
  scan: true
dallas:
  - pin: D4
    update_interval: 30s
  - platform: dallas
    name: "Tank Top Temperature"
    address: 0x8C01202253CD1E28
    entity_id: sensor.sun_elevation
    internal: true
  - platform: homeassistant   # Office temperature
    entity_id: sensor.office_temperature_temperature
    internal: true
  - platform: wifi_signal
    name: "WiFi Signal Boiler"
text_sensor:
    name: "esp bsched rtn"
    on_value:
      then:
        - lambda: |-
    name: "esp input test rtn"
    on_value:
       then:
    internal: true
    lambda: |-
# Select setup
select:
    optimistic: true
    options:
      - 'Off'
      - 'Manual On'
      - 'Auto'
      - 'Local'
    initial_option: 'Off'
    on_value:
      then:
        - logger.log:
            format: "$$$$$$$$$$$$$$$ Chosen option: %s"
            args: ["x.c_str()"]
        - script.execute: adjust_buttons_pagew
        - script.execute: adjust_buttons_pageb
globals:
 - id: first_page             # First page of the display?
   type: bool
   restore_value: no
   initial_value: 'false'
 - id: current_brightness             # Is display on?
   type: float
   restore_value: no
   initial_value: '-1.0'
 - id: wifi_state
   type: bool
   restore_value: no
 - id: current_mode          #  0= OFF, MAN_ON, AUTO,   = LOCAL
   type: int
   initial_value: '0'
   restore_value: yes
 - id: run_state                #  false not runing - true running
   type: bool
   restore_value: no
 - id:  auto_btn_img_idx
   type: int
   restore_value: no
   initial_value: '0'
display:
  - platform: nextion
    update_interval: 10s
    tft_url: 'http://rhome:8123/local/boiler5.tft'
    lambda: |-
      ESP_LOGD("main", "enter display loop");
      if (id(first_page)) {
        it.goto_page("weather");
        auto time = id(rtc_time).now();
         auto day_text =  time.strftime("%a");
         it.set_component_text("dayw",day_text.c_str());
         it.set_component_text_printf("hourw","%02d:",time.hour);
         it.set_component_text_printf("minutew","%02d",time.minute);
         it.set_component_text_printf("statuslabelw","s: %s",id(bsched).state.c_str());
         id(adjust_buttons_pagew).execute();
         if (id(wifi_state)) {
            it.send_command_printf  ("wifiiconw.picc=0");
            else {
              it.send_command_printf  ("wifiiconw.picc=1");
        else
        it.goto_page("temperature");
        it.set_component_text_printf("topt","%2.1f",id(toptemp).state);
        it.set_component_text_printf("bottemp","%2.1f",id(temperature_office).state);
        it.set_component_text_printf("ladtemp","%2.1f",id(temperature_office).state);
        it.set_component_text_printf("furtemp","%2.1f",id(temperature_office).state);
        it.set_component_text_printf("rettemp","%2.1f",id(temperature_office).state);
        it.set_component_text_printf("blendtemp","%2.1f",id(toptemp).state);
        it.set_component_text_printf("statuslabel","s: %s",id(bsched).state.c_str());
         it.set_component_text("day",day_text.c_str());
         it.set_component_text_printf("hour","%02d:",time.hour);
         it.set_component_text_printf("minute","%02d",time.minute);
          id(adjust_buttons_pageb).execute();
            it.send_command_printf  ("wifiicon.picc=0");
            else {
              it.send_command_printf  ("wifiicon.picc=1");
      id(first_page) = !id(first_page);  // Switch page
      ESP_LOGD("main", "EXIT display loop");
      ESP_LOGD("main", "The current sched is %s", id(bsched).state.c_str());
binary_sensor:
  - platform: status
  - platform: nextion
    page_id: 0
    component_id: 14
    internal: true
    on_release:
      lambda: |-
         auto call = id(boil_mode).make_call();
         call.set_option("Off");
         call.perform();
  - platform: nextion
    page_id: 0
    component_id: 15
    internal: true
    on_release:
      lambda: |-
         call.set_option("Manual On");
         call.perform();
  - platform: nextion
    page_id: 0
    component_id: 16
    internal: true
    on_release:
     if:
          condition:
              lambda: 'return id(wifi_state);'
          then:
            lambda: |-
             call.set_option("Auto");
             call.perform();
          else:
            lambda: |-
             call.set_option("Local");
             call.perform();
  - platform: nextion
    page_id: 1
    component_id: 9
    internal: true
    on_release:
      lambda: |-
         call.perform();
  - platform: nextion
    page_id: 1
    component_id: 8
    internal: true
    on_release:
      lambda: |-
         call.perform();
  - platform: nextion
    page_id: 1
    component_id: 10
    internal: true
    on_release:
      if:
          condition:
          then:
            lambda: |-
             call.perform();
          else:
            lambda: |-
             call.perform();
  - platform: status
    name: "Boiler API Status"
    internal: true
    on_state:       # based on wifi connection, we set the global variable here. This way it will be stored and valid upon refresh
      - if:
          condition:
            api.connected:
          then:
            - globals.set:
                value: 'true'
            - lambda: |-
                  id(disp1).send_command_printf  ("wifiicon.picc=0");
          else:
             - globals.set:
                 value: 'false'
             - lambda: |-
                   id(disp1).send_command_printf  ("wifiicon.picc=1");
script:
  - id: adjust_buttons_pageb    # adjust button setting on boiler page
    then:
      - lambda: |-
          id(auto_btn_img_idx) = 0;
          if ( !id(wifi_state))
                id(auto_btn_img_idx) = 3;
      - if:
          condition:
             - lambda: |-
                  return (strcmp( id(boil_mode).state.c_str(), "Off") == 0);
          then:
                lambda: |-
                  id(disp1).send_command_printf  ("off_btn.picc=1");
                  id(disp1).send_command_printf  ("man_btn.picc=0");
                  id(disp1).send_command_printf  ("auto_btn.picc=%i", id(auto_btn_img_idx));
      - if:
           condition:
            - lambda: |-
                return (strcmp( id(boil_mode).state.c_str(), "Manual On") == 0);
           then:
            lambda: |-
              id(disp1).send_command_printf  ("off_btn.picc=0");
              id(disp1).send_command_printf  ("man_btn.picc=1");
      - if:
           condition:
            - lambda: |-
                return (strcmp( id(boil_mode).state.c_str(), "Auto") == 0);
           then:
            lambda: |-
              id(disp1).send_command_printf  ("auto_btn.picc=1");
      - if:
           condition:
            - lambda: |-
                return (strcmp( id(boil_mode).state.c_str(), "Local") == 0);
           then:
            lambda: |-
              id(disp1).send_command_printf  ("auto_btn.picc=2");
  - id: adjust_buttons_pagew      # adjust button setting on weather  page
    then:
      - lambda: |-
      - if:
          condition:
             - lambda: |-
          then:
                lambda: |-
                  id(disp1).send_command_printf  ("off_btnw.picc=1");
                  id(disp1).send_command_printf  ("man_btnw.picc=0");
                  id(disp1).send_command_printf  ("auto_btnw.picc=%i",  id(auto_btn_img_idx));
      - if:
           condition:
            - lambda: |-
           then:
            lambda: |-
              id(disp1).send_command_printf  ("off_btnw.picc=0");
              id(disp1).send_command_printf  ("man_btnw.picc=1");
      - if:
           condition:
            - lambda: |-
           then:
            lambda: |-
              id(disp1).send_command_printf  ("auto_btnw.picc=1");
      - if:
           condition:
            - lambda: |-
           then:
            lambda: |-
              id(disp1).send_command_printf  ("auto_btnw.picc=2");
HA config
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
logger:
  default: info
# Text to speech
tts:
  - platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
# Example configuration.yaml entry
  - platform: systemmonitor
    resources:
    - type: processor_use
    - type: disk_use_percent
      arg: "/"
    - type: disk_free
      arg: "/"
    - type: memory_use_percent
    - type: network_in
      arg: eth0
    - type: throughput_network_in
      arg: eth0
    - type: network_out
      arg: eth0
    - type: throughput_network_out
      arg: eth0
    - type: processor_temperature
    - type: last_boot
  - platform: time_date
    display_options:
      - 'time'
      - 'date'
      - 'date_time'
      - 'date_time_utc'
      - 'date_time_iso'
      - 'time_date'
      - 'time_utc'
      - 'beat'
# OPTIONAL CPU Raspberry Pi Temp
  - platform: command_line
    command: "cat /sys/class/thermal/thermal_zone0/temp"
    unit_of_measurement: "°C"
    value_template: '{{ value | multiply(0.001) | round(2)  }}'
  - platform: mqtt
    unique_id: 'tempTestEnt'
    state_topic: "pi/sensor1"
    value_template: "{{ value_json.temperature }}"
    sensors:
        thermostat_status:
          friendly_name: 'HVAC Status'
          unique_id: 'sensor.hstatus'
          value_template: "{{ states.climate.office_trv.attributes.system_mode }}"
        test_txt_sensor:
        schedule_5268b9:
          friendly_name: 'Boiler Schedule'
          unique_id: 'sensor.bsched'
          value_template: '{{ states.switch.schedule_5268b9.attributes.next_trigger }}'
switch:
  - platform: mqtt
    unique_id: pi_test_switch
    state_topic: "pi/switch1/stat"
    value_template: "{{ value_json.status }}"
    command_topic: "pi/switch1/cmmd"
    payload_on: '{"status": "on"}'
    payload_off: '{"status": "off"}'
    state_on: 'on'
    state_off: 'off'
    optimistic: false
    qos: 0
    retain: false
Link to the logs as they are to big for the board
Logs
Thank you for help
I will setup a new device today with minimal code to see if its device code based or it is server side
Cheers
Paul
Right I have now set up a new device with minimal code/config. The same behaviour is seen. Text sensors from HA are not received by the device but text values set by the device are seen in HA. The code has a pair of timers one just prints the values from the sensors. The other timer forces a value into one of the sensors. HA reports both sensor as unknown until the force event happens. Other HA sensors (FLoat / Binary) are fine and rxed by device. The bottom line is home assistant text based sensor values are not sent from HA.
@nickrout As this looks like a native API issue how do I workout if the problem is HA or ESPHome. Are there any apps that use the native API so I can binary spilt the problem as at the moment not sure where to look . Was thinking about rolling ESPhome back to a earlier version
ESP code
# This is ESPHome configuration file. This goes to the esphome folder
# You need to provide your WiFi ssis/password and passwords for API and OTA (or put them in your esphome/secrets.yaml)
esphome:
  platform: ESP8266
  board: d1_mini
wifi:
  fast_connect: true
api:
ota:
logger:
    level: VERY_VERBOSE
    logs:
        api: VERY_VERBOSE
        scheduler: DEBUG
time:
  - platform: sntp
    on_time:
      # Every 15 seconds
      - seconds: /15
        then:
          - lambda: |-
                std::string val = id(bsched).state;
                ESP_LOGD("main", "The current bsched is %s", val.c_str());
                val = id(input_text1).state;
                ESP_LOGD("main", "The current input_text1 is %s", val.c_str());
          # Every1 minutes
      - seconds: /30
        minutes: /2
        then:
            - lambda: |-
                  id(bsched).publish_state("ESP forced value");
                  ESP_LOGD("main", "Forcing current input_text1");
    internal: true
text_sensor:
    on_value:
      then:
        - lambda: |-
    on_value:
       then:
         - lambda:  ESP_LOGD("main", "The current input_text1 is %s", x.c_str());
    name: "esp template test rtn"
    lambda: |-
Log data
INFO Reading configuration /config/display_weather.yaml...
WARNING 'display_weather': Using the '_' (underscore) character in the hostname is discouraged as it can cause problems with some DHCP and local name services. For more information, see https://esphome.io/guides/faq.html#why-shouldn-t-i-use-underscores-in-my-device-name
INFO Detected timezone 'Etc/UTC'
INFO Generating C++ source...
INFO Compiling app...
Processing display_weather (board: d1_mini; framework: arduino; platform: platformio/espressif8266 @ 2.6.3)
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
Dependency Graph
|-- <ESP8266WiFi> 1.0
|-- <ESP8266mDNS> 1.2
RAM:   [====      ]  44.0% (used 36056 bytes from 81920 bytes)
Flash: [====      ]  37.6% (used 392224 bytes from 1044464 bytes)
========================= [SUCCESS] Took 3.83 seconds =========================
INFO Successfully compiled program.
INFO Resolving IP address of display_weather.local
INFO  -> 192.168.1.98
INFO Uploading /config/.esphome/build/display_weather/.pioenvs/display_weather/firmware.bin (396384 bytes)
INFO Compressed to 273848 bytes
Uploading: [============================================================] 100% Done...
INFO Waiting for result...
INFO OTA successful
INFO Successfully uploaded program.
INFO Starting log output from display_weather.local using esphome API
WARNING Can't connect to ESPHome API for display_weather.local: Error resolving IP address: [Errno -2] Name or service not known
INFO Trying to reconnect to display_weather.local in the background
INFO Successfully connected to display_weather.local
[17:27:21][I][app:102]: ESPHome version 2022.1.2 compiled on Jan 26 2022, 17:24:25
[17:27:21][C][wifi:488]: WiFi:
[17:27:21][C][wifi:350]:   Local MAC: 44:17:93:1E:29:0D
[17:27:21][C][wifi:351]:   SSID: [redacted]
[17:27:21][C][wifi:352]:   IP Address: 192.168.1.98
[17:27:21][C][wifi:354]:   BSSID: [redacted]
[17:27:21][C][wifi:355]:   Hostname: 'display_weather'
[17:27:21][C][wifi:357]:   Signal strength: -74 dB ▂▄▆█
[17:27:21][C][wifi:361]:   Channel: 12
[17:27:21][C][wifi:362]:   Subnet: 255.255.255.0
[17:27:21][C][wifi:363]:   Gateway: 192.168.1.254
[17:27:21][C][wifi:364]:   DNS1: 192.168.1.64
[17:27:21][C][wifi:365]:   DNS2: 192.168.1.254
[17:27:21][C][logger:233]: Logger:
[17:27:21][C][logger:234]:   Level: VERY_VERBOSE
[17:27:21][C][logger:235]:   Log Baud Rate: 0
[17:27:21][C][logger:236]:   Hardware UART: UART0
[17:27:21][C][logger:238]:   Level for 'api': VERY_VERBOSE
[17:27:21][C][logger:238]:   Level for 'homeassistant': VERY_VERBOSE
[17:27:21][C][logger:238]:   Level for 'api.service': VERY_VERBOSE
[17:27:21][C][logger:238]:   Level for 'sensor': VERY_VERBOSE
[17:27:21][C][logger:238]:   Level for 'scheduler': DEBUG
[17:27:21][C][template.text_sensor:021]: Template Sensor 'esp template test rtn'
[17:27:21][C][ota:082]: Over-The-Air Updates:
[17:27:21][C][ota:083]:   Address: display_weather.local:8266
[17:27:21][C][ota:086]:   Using Password.
[17:27:21][C][api:134]: API Server:
[17:27:21][C][api:135]:   Address: display_weather.local:6053
[17:27:21][C][api:139]:   Using noise encryption: NO
[17:27:21][C][sntp:050]: SNTP Time:
[17:27:21][C][sntp:051]:   Server 1: '0.pool.ntp.org'
[17:27:21][C][sntp:052]:   Server 2: '1.pool.ntp.org'
[17:27:21][C][sntp:053]:   Server 3: '2.pool.ntp.org'
[17:27:21][C][sntp:054]:   Timezone: 'UTC0'
[17:27:22][C][mdns:084]: mDNS:
[17:27:22][C][mdns:085]:   Hostname: display_weather
[17:27:22][V][mdns:086]:   Services:
[17:27:22][V][mdns:088]:   - _esphomelib, _tcp, 6053
[17:27:22][V][mdns:090]:     TXT: version = 2022.1.2
[17:27:22][V][mdns:090]:     TXT: mac = 4417931e290d
[17:27:22][V][mdns:090]:     TXT: platform = ESP8266
[17:27:22][V][mdns:090]:     TXT: board = d1_mini
[17:27:22][C][homeassistant.sensor:030]: Homeassistant Sensor 'temperature_office'
[17:27:22][C][homeassistant.sensor:030]:   State Class: ''
[17:27:22][C][homeassistant.sensor:030]:   Unit of Measurement: ''
[17:27:22][C][homeassistant.sensor:030]:   Accuracy Decimals: 1
[17:27:22][C][homeassistant.sensor:031]:   Entity ID: 'sensor.office_temperature_temperature'
[17:27:22][C][homeassistant.text_sensor:023]: Homeassistant Text Sensor 'esp bsched rtn'
[17:27:22][C][homeassistant.text_sensor:024]:   Entity ID: 'sensor.bschet'
[17:27:22][C][homeassistant.text_sensor:023]: Homeassistant Text Sensor 'esp input test rtn'
[17:27:22][C][homeassistant.text_sensor:024]:   Entity ID: 'input_text.text1'
[17:27:30][VV][api.service:337]: on_ping_request: PingRequest {}
[17:27:30][VV][api.service:043]: send_ping_response: PingResponse {}
[17:27:30][D][main:042]: The current bsched is
[17:27:30][D][main:044]: The current input_text1 is
[17:27:36][VV][api.service:337]: on_ping_request: PingRequest {}
[17:27:36][VV][api.service:043]: send_ping_response: PingResponse {}
[17:27:45][VV][api.service:337]: on_ping_request: PingRequest {}
[17:27:45][VV][api.service:043]: send_ping_response: PingResponse {}
[17:27:45][D][main:042]: The current bsched is
[17:27:45][D][main:044]: The current input_text1 is
[17:27:51][VV][api.service:337]: on_ping_request: PingRequest {}
[17:27:51][VV][api.service:043]: send_ping_response: PingResponse {}
[17:27:53][V][text_sensor:016]: 'esp template test rtn': Received new state Hello World
[17:27:53][D][text_sensor:067]: 'esp template test rtn': Sending state 'Hello World'
[17:27:53][VV][api.service:174]: send_text_sensor_state_response: TextSensorStateResponse {
  key: 1114204214
  state: 'Hello World'
  missing_state: NO
[17:28:00][VV][api.service:337]: on_ping_request: PingRequest {}
[17:28:00][VV][api.service:043]: send_ping_response: PingResponse {}
[17:28:00][D][main:042]: The current bsched is
[17:28:00][D][main:044]: The current input_text1 is
[17:28:00][V][text_sensor:016]: 'esp bsched rtn': Received new state ESP forced value
[17:28:00][D][text_sensor:067]: 'esp bsched rtn': Sending state 'ESP forced value'
[17:28:00][D][main:071]: The current schedba is ESP forced value
[17:28:00][VV][api.service:174]: send_text_sensor_state_response: TextSensorStateResponse {
  key: 67256600
  state: 'ESP forced value'
  missing_state: NO
[17:28:00][D][main:053]: Forcing current input_text1
[17:28:06][VV][api.service:337]: on_ping_request: PingRequest {}
[17:28:06][VV][api.service:043]: send_ping_response: PingResponse {}
[17:28:15][VV][api.service:337]: on_ping_request: PingRequest {}
[17:28:15][VV][api.service:043]: send_ping_response: PingResponse {}
[17:28:15][D][main:042]: The current bsched is ESP forced value
[17:28:15][D][main:044]: The current input_text1 is
[17:28:21][VV][api.service:337]: on_ping_request: PingRequest {}
[17:28:21][VV][api.service:043]: send_ping_response: PingResponse {}
I think we are at the end of my usefulness on this. I suggest a post on the esphome issues tracker on github.
Ok thank you very much for the support.
Wait, I just looked again at the docs. First thing I notice is
The homeassistant text sensor platform allows you to create a sensors that import states from your Home Assistant instance using the native API
It doesn’t say it is two way!
Also could you change the HA text sensor with a service Native API Component — ESPHome
