What is that integration?
This is just a hardcoded test sensor. What I am actually trying to do is send schedule information from the hacs schedule component. But to do that I need to send a csv text string. But I simplified the code to explain the problem
Are you trying to implement the use of input text? That would be something like this:
input_text:
bschet:
initial: Hello Test
I have never heard of that integration. I think you have made that up.
Its a custom card and custom component Scheduler card/custom component
I want to use it to define a schedule for the esp device that controls my biomass plant room. So the ESP needs to know the schedule so if I have a wifi or HA failure the controller still works
I have already set up the input helper via the gui that did help either that what drive input_text.text1
What does sensor.bschet say in developer tools/states.
The HA sensors sensor.bschet & input_text.text1 have right values but when I followed mike’s advice post #2 and published the ESP values back to HA both ESP values where unknown when the device was on and unavailable when the device was switch off.
I am going try to remove the ESP device from HA and re add it. Another post with a similar issue said it resolved it.
That did not resolve the issue
Any other thoughts?
How do I get detailed logs from HA? Just clutching at straws
I get the feeling that you have probably changed a few things now, can you post:
- your esphome yaml
- any relevant ha yaml
- your esphome logs
This is the esp device yaml
esphome:
platform: ESP8266
board: d1_mini
on_boot:
then:
# read the RTC time once when the system boots
ds1307.read_time:
wifi:
ssid: !secret wifi_ssid
fast_connect: true
api:
password: !secret api_password
services:
- service: update_nextion
then:
- lambda: 'id(disp1)->upload_tft();'
ota:
password: !secret ota_password
logger:
baud_rate: 0 # Disable UART logging (pins GPIO1/3 are used for Nextion communication)
level: VERY_VERBOSE
logs:
api: VERY_VERBOSE
homeassistant: VERY_VERBOSE
nextion: VERY_VERBOSE
api.service: VERY_VERBOSE
sensor: VERY_VERBOSE
scheduler: DEBUG
captive_portal:
uart:
rx_pin: D6
tx_pin: D7
baud_rate: 115200
time:
- platform: ds1307
# repeated synchronization is not necessary unless the external RTC
# is much more accurate than the internal clock
update_interval: never
- platform: homeassistant
# instead try to synchronize via network repeatedly ...
on_time_sync:
then:
# ... and update the RTC when the synchronization was successful
ds1307.write_time:
http_request:
i2c:
sda: D2
scl: D1
scan: true
dallas:
- pin: D4
update_interval: 30s
- platform: dallas
name: "Tank Top Temperature"
address: 0x8C01202253CD1E28
entity_id: sensor.sun_elevation
internal: true
- platform: homeassistant # Office temperature
entity_id: sensor.office_temperature_temperature
internal: true
- platform: wifi_signal
name: "WiFi Signal Boiler"
update_interval: 60s
text_sensor:
entity_id: sensor.bschet
name: "esp bsched rtn"
on_value:
then:
- lambda: |-
ESP_LOGD("main", "The current schedba is %s", x.c_str());
name: "esp input test rtn"
entity_id: input_text.text1
on_value:
then:
- lambda: ESP_LOGD("main", "The current schedbb is %s", x.c_str());
internal: true
lambda: |-
return {"Hello World"};
# Select setup
select:
optimistic: true
options:
- 'Off'
- 'Manual On'
- 'Auto'
- 'Local'
initial_option: 'Off'
on_value:
then:
- logger.log:
format: "$$$$$$$$$$$$$$$ Chosen option: %s"
args: ["x.c_str()"]
- script.execute: adjust_buttons_pagew
- script.execute: adjust_buttons_pageb
globals:
- id: first_page # First page of the display?
type: bool
restore_value: no
initial_value: 'false'
- id: current_brightness # Is display on?
type: float
restore_value: no
initial_value: '-1.0'
- id: wifi_state
type: bool
restore_value: no
- id: current_mode # 0= OFF, MAN_ON, AUTO, = LOCAL
type: int
initial_value: '0'
restore_value: yes
- id: run_state # false not runing - true running
type: bool
restore_value: no
- id: auto_btn_img_idx
type: int
restore_value: no
initial_value: '0'
display:
- platform: nextion
update_interval: 10s
tft_url: 'http://rhome:8123/local/boiler5.tft'
lambda: |-
ESP_LOGD("main", "enter display loop");
if (id(first_page)) {
it.goto_page("weather");
auto time = id(rtc_time).now();
auto day_text = time.strftime("%a");
it.set_component_text("dayw",day_text.c_str());
it.set_component_text_printf("hourw","%02d:",time.hour);
it.set_component_text_printf("minutew","%02d",time.minute);
it.set_component_text_printf("statuslabelw","s: %s",id(bsched).state.c_str());
id(adjust_buttons_pagew).execute();
if (id(wifi_state)) {
it.send_command_printf ("wifiiconw.picc=0");
else {
it.send_command_printf ("wifiiconw.picc=1");
else
it.goto_page("temperature");
it.set_component_text_printf("topt","%2.1f",id(toptemp).state);
it.set_component_text_printf("bottemp","%2.1f",id(temperature_office).state);
it.set_component_text_printf("ladtemp","%2.1f",id(temperature_office).state);
it.set_component_text_printf("furtemp","%2.1f",id(temperature_office).state);
it.set_component_text_printf("rettemp","%2.1f",id(temperature_office).state);
it.set_component_text_printf("blendtemp","%2.1f",id(toptemp).state);
it.set_component_text_printf("statuslabel","s: %s",id(bsched).state.c_str());
it.set_component_text("day",day_text.c_str());
it.set_component_text_printf("hour","%02d:",time.hour);
it.set_component_text_printf("minute","%02d",time.minute);
id(adjust_buttons_pageb).execute();
it.send_command_printf ("wifiicon.picc=0");
else {
it.send_command_printf ("wifiicon.picc=1");
id(first_page) = !id(first_page); // Switch page
ESP_LOGD("main", "EXIT display loop");
ESP_LOGD("main", "The current sched is %s", id(bsched).state.c_str());
binary_sensor:
- platform: status
- platform: nextion
page_id: 0
component_id: 14
internal: true
on_release:
lambda: |-
auto call = id(boil_mode).make_call();
call.set_option("Off");
call.perform();
- platform: nextion
page_id: 0
component_id: 15
internal: true
on_release:
lambda: |-
call.set_option("Manual On");
call.perform();
- platform: nextion
page_id: 0
component_id: 16
internal: true
on_release:
if:
lambda: 'return id(wifi_state);'
then:
lambda: |-
call.set_option("Auto");
call.perform();
else:
lambda: |-
call.set_option("Local");
call.perform();
- platform: nextion
page_id: 1
component_id: 9
internal: true
on_release:
lambda: |-
call.perform();
- platform: nextion
page_id: 1
component_id: 8
internal: true
on_release:
lambda: |-
call.perform();
- platform: nextion
page_id: 1
component_id: 10
internal: true
on_release:
if:
then:
lambda: |-
call.perform();
else:
lambda: |-
call.perform();
- platform: status
name: "Boiler API Status"
internal: true
on_state: # based on wifi connection, we set the global variable here. This way it will be stored and valid upon refresh
- if:
api.connected:
then:
- globals.set:
value: 'true'
- lambda: |-
id(disp1).send_command_printf ("wifiicon.picc=0");
else:
- globals.set:
value: 'false'
- lambda: |-
id(disp1).send_command_printf ("wifiicon.picc=1");
script:
- id: adjust_buttons_pageb # adjust button setting on boiler page
then:
- lambda: |-
id(auto_btn_img_idx) = 0;
if ( !id(wifi_state))
id(auto_btn_img_idx) = 3;
- if:
- lambda: |-
return (strcmp( id(boil_mode).state.c_str(), "Off") == 0);
then:
lambda: |-
id(disp1).send_command_printf ("off_btn.picc=1");
id(disp1).send_command_printf ("man_btn.picc=0");
id(disp1).send_command_printf ("auto_btn.picc=%i", id(auto_btn_img_idx));
- if:
- lambda: |-
return (strcmp( id(boil_mode).state.c_str(), "Manual On") == 0);
then:
lambda: |-
id(disp1).send_command_printf ("off_btn.picc=0");
id(disp1).send_command_printf ("man_btn.picc=1");
- if:
- lambda: |-
return (strcmp( id(boil_mode).state.c_str(), "Auto") == 0);
then:
lambda: |-
id(disp1).send_command_printf ("auto_btn.picc=1");
- if:
- lambda: |-
return (strcmp( id(boil_mode).state.c_str(), "Local") == 0);
then:
lambda: |-
id(disp1).send_command_printf ("auto_btn.picc=2");
- id: adjust_buttons_pagew # adjust button setting on weather page
then:
- lambda: |-
- if:
- lambda: |-
then:
lambda: |-
id(disp1).send_command_printf ("off_btnw.picc=1");
id(disp1).send_command_printf ("man_btnw.picc=0");
id(disp1).send_command_printf ("auto_btnw.picc=%i", id(auto_btn_img_idx));
- if:
- lambda: |-
then:
lambda: |-
id(disp1).send_command_printf ("off_btnw.picc=0");
id(disp1).send_command_printf ("man_btnw.picc=1");
- if:
- lambda: |-
then:
lambda: |-
id(disp1).send_command_printf ("auto_btnw.picc=1");
- if:
- lambda: |-
then:
lambda: |-
id(disp1).send_command_printf ("auto_btnw.picc=2");
HA config
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
logger:
default: info
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
automation: !include automations.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
# Example configuration.yaml entry
- platform: systemmonitor
resources:
- type: processor_use
- type: disk_use_percent
arg: "/"
- type: disk_free
arg: "/"
- type: memory_use_percent
- type: network_in
arg: eth0
- type: throughput_network_in
arg: eth0
- type: network_out
arg: eth0
- type: throughput_network_out
arg: eth0
- type: processor_temperature
- type: last_boot
- platform: time_date
display_options:
- 'time'
- 'date'
- 'date_time'
- 'date_time_utc'
- 'date_time_iso'
- 'time_date'
- 'time_utc'
- 'beat'
# OPTIONAL CPU Raspberry Pi Temp
- platform: command_line
command: "cat /sys/class/thermal/thermal_zone0/temp"
unit_of_measurement: "°C"
value_template: '{{ value | multiply(0.001) | round(2) }}'
- platform: mqtt
unique_id: 'tempTestEnt'
state_topic: "pi/sensor1"
value_template: "{{ value_json.temperature }}"
sensors:
thermostat_status:
friendly_name: 'HVAC Status'
unique_id: 'sensor.hstatus'
value_template: "{{ states.climate.office_trv.attributes.system_mode }}"
test_txt_sensor:
friendly_name: 'Test Text'
unique_id: 'sensor.bschet'
value_template: 'Hello Test'
schedule_5268b9:
friendly_name: 'Boiler Schedule'
unique_id: 'sensor.bsched'
value_template: '{{ states.switch.schedule_5268b9.attributes.next_trigger }}'
switch:
- platform: mqtt
unique_id: pi_test_switch
state_topic: "pi/switch1/stat"
value_template: "{{ value_json.status }}"
command_topic: "pi/switch1/cmmd"
payload_on: '{"status": "on"}'
payload_off: '{"status": "off"}'
state_on: 'on'
state_off: 'off'
optimistic: false
qos: 0
retain: false
Link to the logs as they are to big for the board
Logs
Thank you for help
I will setup a new device today with minimal code to see if its device code based or it is server side
Cheers
Paul
Right I have now set up a new device with minimal code/config. The same behaviour is seen. Text sensors from HA are not received by the device but text values set by the device are seen in HA. The code has a pair of timers one just prints the values from the sensors. The other timer forces a value into one of the sensors. HA reports both sensor as unknown until the force event happens. Other HA sensors (FLoat / Binary) are fine and rxed by device. The bottom line is home assistant text based sensor values are not sent from HA.
@nickrout As this looks like a native API issue how do I workout if the problem is HA or ESPHome. Are there any apps that use the native API so I can binary spilt the problem as at the moment not sure where to look . Was thinking about rolling ESPhome back to a earlier version
ESP code
# This is ESPHome configuration file. This goes to the esphome folder
# You need to provide your WiFi ssis/password and passwords for API and OTA (or put them in your esphome/secrets.yaml)
esphome:
platform: ESP8266
board: d1_mini
wifi:
fast_connect: true
api:
ota:
logger:
level: VERY_VERBOSE
logs:
api: VERY_VERBOSE
scheduler: DEBUG
time:
- platform: sntp
on_time:
# Every 15 seconds
- seconds: /15
then:
- lambda: |-
std::string val = id(bsched).state;
ESP_LOGD("main", "The current bsched is %s", val.c_str());
val = id(input_text1).state;
ESP_LOGD("main", "The current input_text1 is %s", val.c_str());
# Every1 minutes
- seconds: /30
minutes: /2
then:
- lambda: |-
id(bsched).publish_state("ESP forced value");
ESP_LOGD("main", "Forcing current input_text1");
internal: true
text_sensor:
on_value:
then:
- lambda: |-
on_value:
then:
- lambda: ESP_LOGD("main", "The current input_text1 is %s", x.c_str());
name: "esp template test rtn"
lambda: |-
Log data
INFO Reading configuration /config/display_weather.yaml...
WARNING 'display_weather': Using the '_' (underscore) character in the hostname is discouraged as it can cause problems with some DHCP and local name services. For more information, see https://esphome.io/guides/faq.html#why-shouldn-t-i-use-underscores-in-my-device-name
INFO Detected timezone 'Etc/UTC'
INFO Generating C++ source...
INFO Compiling app...
Processing display_weather (board: d1_mini; framework: arduino; platform: platformio/espressif8266 @ 2.6.3)
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
Dependency Graph
|-- <ESP8266WiFi> 1.0
|-- <ESP8266mDNS> 1.2
RAM: [==== ] 44.0% (used 36056 bytes from 81920 bytes)
Flash: [==== ] 37.6% (used 392224 bytes from 1044464 bytes)
========================= [SUCCESS] Took 3.83 seconds =========================
INFO Successfully compiled program.
INFO Resolving IP address of display_weather.local
INFO -> 192.168.1.98
INFO Uploading /config/.esphome/build/display_weather/.pioenvs/display_weather/firmware.bin (396384 bytes)
INFO Compressed to 273848 bytes
Uploading: [============================================================] 100% Done...
INFO Waiting for result...
INFO OTA successful
INFO Successfully uploaded program.
INFO Starting log output from display_weather.local using esphome API
WARNING Can't connect to ESPHome API for display_weather.local: Error resolving IP address: [Errno -2] Name or service not known
INFO Trying to reconnect to display_weather.local in the background
INFO Successfully connected to display_weather.local
[17:27:21][I][app:102]: ESPHome version 2022.1.2 compiled on Jan 26 2022, 17:24:25
[17:27:21][C][wifi:488]: WiFi:
[17:27:21][C][wifi:350]: Local MAC: 44:17:93:1E:29:0D
[17:27:21][C][wifi:351]: SSID: [redacted]
[17:27:21][C][wifi:352]: IP Address: 192.168.1.98
[17:27:21][C][wifi:354]: BSSID: [redacted]
[17:27:21][C][wifi:355]: Hostname: 'display_weather'
[17:27:21][C][wifi:357]: Signal strength: -74 dB ▂▄▆█
[17:27:21][C][wifi:361]: Channel: 12
[17:27:21][C][wifi:362]: Subnet: 255.255.255.0
[17:27:21][C][wifi:363]: Gateway: 192.168.1.254
[17:27:21][C][wifi:364]: DNS1: 192.168.1.64
[17:27:21][C][wifi:365]: DNS2: 192.168.1.254
[17:27:21][C][logger:233]: Logger:
[17:27:21][C][logger:234]: Level: VERY_VERBOSE
[17:27:21][C][logger:235]: Log Baud Rate: 0
[17:27:21][C][logger:236]: Hardware UART: UART0
[17:27:21][C][logger:238]: Level for 'api': VERY_VERBOSE
[17:27:21][C][logger:238]: Level for 'homeassistant': VERY_VERBOSE
[17:27:21][C][logger:238]: Level for 'api.service': VERY_VERBOSE
[17:27:21][C][logger:238]: Level for 'sensor': VERY_VERBOSE
[17:27:21][C][logger:238]: Level for 'scheduler': DEBUG
[17:27:21][C][template.text_sensor:021]: Template Sensor 'esp template test rtn'
[17:27:21][C][ota:082]: Over-The-Air Updates:
[17:27:21][C][ota:083]: Address: display_weather.local:8266
[17:27:21][C][ota:086]: Using Password.
[17:27:21][C][api:134]: API Server:
[17:27:21][C][api:135]: Address: display_weather.local:6053
[17:27:21][C][api:139]: Using noise encryption: NO
[17:27:21][C][sntp:050]: SNTP Time:
[17:27:21][C][sntp:051]: Server 1: '0.pool.ntp.org'
[17:27:21][C][sntp:052]: Server 2: '1.pool.ntp.org'
[17:27:21][C][sntp:053]: Server 3: '2.pool.ntp.org'
[17:27:21][C][sntp:054]: Timezone: 'UTC0'
[17:27:22][C][mdns:084]: mDNS:
[17:27:22][C][mdns:085]: Hostname: display_weather
[17:27:22][V][mdns:086]: Services:
[17:27:22][V][mdns:088]: - _esphomelib, _tcp, 6053
[17:27:22][V][mdns:090]: TXT: version = 2022.1.2
[17:27:22][V][mdns:090]: TXT: mac = 4417931e290d
[17:27:22][V][mdns:090]: TXT: platform = ESP8266
[17:27:22][V][mdns:090]: TXT: board = d1_mini
[17:27:22][C][homeassistant.sensor:030]: Homeassistant Sensor 'temperature_office'
[17:27:22][C][homeassistant.sensor:030]: State Class: ''
[17:27:22][C][homeassistant.sensor:030]: Unit of Measurement: ''
[17:27:22][C][homeassistant.sensor:030]: Accuracy Decimals: 1
[17:27:22][C][homeassistant.sensor:031]: Entity ID: 'sensor.office_temperature_temperature'
[17:27:22][C][homeassistant.text_sensor:023]: Homeassistant Text Sensor 'esp bsched rtn'
[17:27:22][C][homeassistant.text_sensor:024]: Entity ID: 'sensor.bschet'
[17:27:22][C][homeassistant.text_sensor:023]: Homeassistant Text Sensor 'esp input test rtn'
[17:27:22][C][homeassistant.text_sensor:024]: Entity ID: 'input_text.text1'
[17:27:30][VV][api.service:337]: on_ping_request: PingRequest {}
[17:27:30][VV][api.service:043]: send_ping_response: PingResponse {}
[17:27:30][D][main:042]: The current bsched is
[17:27:30][D][main:044]: The current input_text1 is
[17:27:36][VV][api.service:337]: on_ping_request: PingRequest {}
[17:27:36][VV][api.service:043]: send_ping_response: PingResponse {}
[17:27:45][VV][api.service:337]: on_ping_request: PingRequest {}
[17:27:45][VV][api.service:043]: send_ping_response: PingResponse {}
[17:27:45][D][main:042]: The current bsched is
[17:27:45][D][main:044]: The current input_text1 is
[17:27:51][VV][api.service:337]: on_ping_request: PingRequest {}
[17:27:51][VV][api.service:043]: send_ping_response: PingResponse {}
[17:27:53][V][text_sensor:016]: 'esp template test rtn': Received new state Hello World
[17:27:53][D][text_sensor:067]: 'esp template test rtn': Sending state 'Hello World'
[17:27:53][VV][api.service:174]: send_text_sensor_state_response: TextSensorStateResponse {
key: 1114204214
state: 'Hello World'
missing_state: NO
[17:28:00][VV][api.service:337]: on_ping_request: PingRequest {}
[17:28:00][VV][api.service:043]: send_ping_response: PingResponse {}
[17:28:00][D][main:042]: The current bsched is
[17:28:00][D][main:044]: The current input_text1 is
[17:28:00][V][text_sensor:016]: 'esp bsched rtn': Received new state ESP forced value
[17:28:00][D][text_sensor:067]: 'esp bsched rtn': Sending state 'ESP forced value'
[17:28:00][D][main:071]: The current schedba is ESP forced value
[17:28:00][VV][api.service:174]: send_text_sensor_state_response: TextSensorStateResponse {
key: 67256600
state: 'ESP forced value'
missing_state: NO
[17:28:00][D][main:053]: Forcing current input_text1
[17:28:06][VV][api.service:337]: on_ping_request: PingRequest {}
[17:28:06][VV][api.service:043]: send_ping_response: PingResponse {}
[17:28:15][VV][api.service:337]: on_ping_request: PingRequest {}
[17:28:15][VV][api.service:043]: send_ping_response: PingResponse {}
[17:28:15][D][main:042]: The current bsched is ESP forced value
[17:28:15][D][main:044]: The current input_text1 is
[17:28:21][VV][api.service:337]: on_ping_request: PingRequest {}
[17:28:21][VV][api.service:043]: send_ping_response: PingResponse {}
I think we are at the end of my usefulness on this. I suggest a post on the esphome issues tracker on github.
Ok thank you very much for the support.
Wait, I just looked again at the docs. First thing I notice is
The
homeassistant
text sensor platform allows you to create a sensors that import states from your Home Assistant instance using the native API
It doesn’t say it is two way!
Hi
Thank you very much. This is actually a far better approach to achieve what I need as it supports multi dimensional arrays. eg mulit day schedule events with start and stop times. I was raised the issue on the tracker because this should work.
For others who have an issue with text sensors please see the following examples
ESPCode
esphome:
platform: ESP8266
board: d1_mini
wifi:
fast_connect: true
api:
services:
- service: update_schedule
variables:
my_string: string
then:
- globals.set:
value: !lambda 'return my_string;'
ota:
logger:
level: VERY_VERBOSE
logs:
api: VERY_VERBOSE
scheduler: DEBUG
globals:
- id: my_test_str
type: std::string
restore_value: no
initial_value: ''
time:
- platform: sntp
on_time:
# Every 15 seconds
- seconds: /15
then:
- lambda: |-
ESP_LOGD("main", "The current schedule is %s", id(my_test_str).c_str());
# Every1 minutes
- seconds: /30
minutes: /2
then:
- lambda: |-
internal: true
text_sensor:
on_value:
then:
- lambda: |-
on_value:
then:
lambda: |-
HA script
script:
send_schedule_to_boiler:
service: esphome.display_weather_update_schedule
my_string: Example qwerty
Cheers
Hi @pebblebed,
I’m facing kind of similar problem (ha issue) trying to implement a kind of two way binding and I’m not totally sure how your solution works. Could you please post a very short example like only the components needed?
Reading the code pasted I guess there’s a service with name update_schedule?! and on value it sets the global variable with name my_test_str
with the value of my_string
variable of service. So maybe that’s not important for updating value in ha ui, because I also could write id(text_sensor_id).state.
Then there are some cron jobs, first one just logging. Second one publishing values to text sensor ← does this work - for me it doesn’t?
Then there is an sensor temperature_office
not needed for example and 3 others from which I’m not sure what their purpose is.
HA script: I dont know what it is for
Sry if the question may be dump as I’m not that much into ha and just wanted to give it a try
BR
i7i5
Basically the code was there to a demonstrate the issue with string sensors this has now been raise as a ESPHome issue Issue #2990. The solution / work around was to use a service to send string values from HA to the ESP device.
I would suggest for you to achieve two way binding you would need to two sensors one mapped to a HA virtual entity and a virtual sensor on the ESP device this would then allow data from HA to be sent to the device and then using the appropriate trigger run some lambda code to change the value and report it back to HA. Then at the HA end another trigger to detect changes in the ESP virtual sensor. But a not of warning if you make this close loop you could end up with a deadly embrace eg the sensor updating it self repeatedly
