Weird problem with 3 gang Wi-Fi Smart Switch backlight - help with YAML please
I managed to use the ltchiptool to backup then flash libretiny over serial onto a couple of generic tuya wifi touch switches that I bought from eBay (no cloudcutter profile worked). They have a tiny surface-mount BK7321N chip soldered directly onto the PCB.
The YAML generated by ltchiptool got the touch switches and relays working, but the backlight for the touch switches was all wonky.
I worked out that P28 had to be on to enable the blue “off state” backlight for buttons 1 and 3, but nothing happened for button 2. It just stays off.
With P28 enabled, buttons 1 and 3 change from blue to red when on. This is the proper behaviour.
Button 2 has no backlight whether off or on.
Can one of you experts please help me out? Either:
  1. Maybe there is a clue in the JSON from the original that just wasn’t converted to yaml properly?
    Please help me to work out what’s missing and how to add it.
  2. If I can find this information somewhere, please give me some directions. I can’t work it out.
Here is the JSON from the backup:
Expand
    "gw_bi": {
        "uuid": "dd77e010871e2d84",
        "psk_key": "kHI2JHHYjCtEj4ju3EvcKcG1cNfJpgURDaUjg",
        "auth_key": "9TeTkBgIRE9okiiu8pbWWeAo4u9jZipB",
        "ap_ssid": "SmartLife",
        "ap_passwd": null,
        "country_code": "CN",
        "bt_mac": null,
        "bt_hid": null,
        "prod_test": false,
        "fac_pin": "qpalfe6ashfu7bbx"
    "user_param_key": {
        "backlit_dp": 16,
        "backlit_io_lv": 1,
        "backlit_io_pin": 28,
        "backlit_select": 1,
        "bt1_lv": 0,
        "bt1_pin": 6,
        "bt2_lv": 0,
        "bt2_pin": 9,
        "bt3_lv": 0,
        "bt3_pin": 16,
        "bt_type": 1,
        "cd_flag2": 1,
        "ch_cddpid1": 7,
        "ch_cddpid2": 8,
        "ch_cddpid3": 9,
        "ch_dpid1": 1,
        "ch_dpid2": 2,
        "ch_dpid3": 3,
        "ch_flag1": 1,
        "ch_flag3": 1,
        "ch_num": 3,
        "crc": 123,
        "cyc_dpid": 17,
        "inch_dp": 19,
        "init_conf": 14,
        "jv": "1.0.0",
        "led1_lv": 1,
        "led1_pin": 8,
        "led2_lv": 1,
        "led2_pin": 15,
        "led3_lv": 1,
        "led3_pin": 26,
        "led_dp": 15,
        "light_status_select": 1,
        "module": "CBU",
        "net_trig": 4,
        "rand_dpid": 18,
        "reset_t": 6,
        "rl1_lv": 1,
        "rl1_pin": 7,
        "rl2_lv": 1,
        "rl2_pin": 14,
        "rl3_lv": 1,
        "rl3_pin": 17,
        "total_stat": 2
    "light_mode_en": 1,
    "save_off_stat": {
        "power": [
            false,
            false,
            false,
            false,
            false
    "tls_ca_cnt": 0,
    "gw_wsm": {
        "nc_tp": 4,
        "ssid": "Sy1Xb2lGb2lfMi40",
        "passwd": "MUNvcjEzOjhsbmY=",
        "md": 0,
        "random": 0,
        "wfb64": 1,
        "stat": 2,
        "token": "t1Tn4gsA",
        "region": "EU",
        "reg_key": "4PUn",
        "dns_prio": 2
    "init_stat_save": {
        "def_mode": 2
    "wf_start_md": 3,
    "is_stride": 0,
    "backlit_en": "\u0001",
    "000004cnb1": [
            "type": "obj",
            "mode": "rw",
            "property": {
                "type": "bool"
            "id": 1
            "type": "obj",
            "mode": "rw",
            "property": {
                "type": "bool"
            "id": 2
            "type": "obj",
            "mode": "rw",
            "property": {
                "type": "bool"
            "id": 3
            "type": "obj",
            "mode": "rw",
            "property": {
                "min": 0,
                "max": 86400,
                "scale": 0,
                "step": 1,
                "type": "value"
            "id": 7
            "type": "obj",
            "mode": "rw",
            "property": {
                "min": 0,
                "max": 86400,
                "scale": 0,
                "step": 1,
                "type": "value"
            "id": 8
            "type": "obj",
            "mode": "rw",
            "property": {
                "min": 0,
                "max": 86400,
                "scale": 0,
                "step": 1,
                "type": "value"
            "id": 9
            "type": "obj",
            "mode": "rw",
            "property": {
                "range": [
                    "off",
                    "on",
                    "memory"
                "type": "enum"
            "id": 14
            "type": "obj",
            "mode": "rw",
            "property": {
                "range": [
                    "none",
                    "relay",
                    "pos"
                "type": "enum"
            "id": 15
            "type": "obj",
            "mode": "rw",
            "property": {
                "type": "bool"
            "id": 16
            "type": "obj",
            "mode": "rw",
            "property": {
                "type": "string",
                "maxlen": 255
            "id": 17
            "type": "obj",
            "mode": "rw",
            "property": {
                "type": "string",
                "maxlen": 255
            "id": 18
            "type": "obj",
            "mode": "rw",
            "property": {
                "type": "string",
                "maxlen": 255
            "id": 19
            "type": "obj",
            "mode": "rw",
            "property": {
                "range": [
                    "switch",
                    "linkage_control"
                "type": "enum"
            "id": 35
            "type": "obj",
            "mode": "rw",
            "property": {
                "range": [
                    "switch",
                    "linkage_control"
                "type": "enum"
            "id": 36
            "type": "obj",
            "mode": "rw",
            "property": {
                "range": [
                    "switch",
                    "linkage_control"
                "type": "enum"
            "id": 37
            "trigger": "direct",
            "type": "obj",
            "mode": "rw",
            "property": {
                "range": [
                    "single_click",
                    "double_click",
                    "long_press"
                "type": "enum"
            "id": 41
            "type": "obj",
            "mode": "rw",
            "property": {
                "range": [
                    "single_click",
                    "double_click",
                    "long_press"
                "type": "enum"
            "id": 42
            "type": "obj",
            "mode": "rw",
            "property": {
                "range": [
                    "single_click",
                    "double_click",
                    "long_press"
                "type": "enum"
            "id": 43
    "timer_arr": {
        "lastFetchTime": 0,
        "cnt": 0
    "gw_di": {
        "abi": 0,
        "id": "bf7943fa3ec86c8692jah7",
        "swv": "1.0.1",
        "bv": "40.00",
        "pv": "2.2",
        "lpv": "3.3",
        "pk": "keyfk4gt95hqky4p",
        "firmk": "keyfk4gt95hqky4p",
        "cadv": "1.0.3",
        "cdv": "1.0.0",
        "dev_swv": "1.0.1",
        "s_id": "000004cnb1",
        "dtp": 0,
        "sync": 0,
        "attr_num": 0,
        "mst_tp_0": 0,
        "mst_ver_0": null,
        "mst_tp_1": 0,
        "mst_ver_1": null,
        "mst_tp_2": 0,
        "mst_ver_2": null,
        "mst_tp_3": 0,
        "mst_ver_3": null
    "em_sys_env": "bk7231n",
    "gw_ai": {
        "key": "N/d1SdV!9=E'/9N-",
        "lckey": "BK?vMKuV^(?@O2MS",
        "h_url": "http://a.tuyaeu.com/d.json",
        "h_ip": "3.67.217.150",
        "hs_url": null,
        "hs_ip": null,
        "hs_psk": "https://a3.tuyaeu.com/d.json",
        "hs_psk_ip": "18.195.249.137",
        "mqs_url": null,
        "mqs_ip": null,
        "mq_url": "m2.tuyaeu.com:1883",
        "mq_ip": "3.67.242.33",
        "ai_sp": null,
        "ai_sp_ip": null,
        "mq_psk": "m2.tuyaeu.com:8886",
        "mq_psk_ip": "3.67.242.33",
        "time_z": "+10:00",
        "s_time_z": "[[1696089600,1712419200],[1728144000,1743868800]]",
        "wx_app_id": null,
        "wx_uuid": null,
        "dy_tls_m": 2,
        "cloud_cap": 1025,
        "psk21_key": null
    "mf_test_close": true
Here is the YAML from ESPhome that I am using:
Expand
esphome:
  friendly_name: sw_wifi_laundry_top
bk72xx:
  board: generic-bk7231n-qfn32-tuya
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: !secret api_encryption_key
ota:
  password: !secret ota_password
wifi:
  ssid: !secret my_wifi_ssid
  password: !secret my_wifi_pwd
  ap:
    ssid: "Sw-Wifi-Laundry-Top"
    password: !secret ap_password
captive_portal:
web_server:
mdns:
text_sensor:
  - platform: libretiny
    version:
output:
  - platform: libretiny_pwm
    pin: P8
    pin: P15
    pin: P26
light:
  - platform: binary
    output: output_led_1
  - platform: binary
    output: output_led_2
  - platform: binary
    output: output_led_3
binary_sensor:
  - platform: gpio
    pin:
      number: P6
      inverted: true
      mode: INPUT_PULLUP
    on_press:
      then:
        - switch.toggle: switch_1
  - platform: gpio
    pin:
      number: P9
      inverted: false
      mode: INPUT_PULLUP
    on_press:
      then:
        - switch.toggle: switch_2
  - platform: gpio
    pin:
      number: P16
      inverted: true
      mode: INPUT_PULLUP
    on_press:
      then:
        - switch.toggle: switch_3
switch:
  - platform: gpio
    pin: P7
    on_turn_on:
      - light.turn_on: light_switch_1
    on_turn_off:
      - light.turn_off: light_switch_1
  - platform: gpio
    pin: P14
    on_turn_on:
      - light.turn_on: light_switch_2
    on_turn_off:
      - light.turn_off: light_switch_2
  - platform: gpio
    pin: P17
    on_turn_on:
      - light.turn_on: light_switch_3
    on_turn_off:
      - light.turn_off: light_switch_3
status_led:
  pin:
    number: P28
    inverted: yes
I’ve been messing around changing states etc with the unused GPIO pins all day and still nothing works. (The status led definition at the bottom of the yaml makes the backlight on buttons 1 and 3 flash while initialising then stays on once it is connected, but I think that is supposed to happen on a different button backlight.)
Is there anything else I need to include?
This is what it should look like with one switch on (this switch-plate has 2x 3 gang modules side-by-side.)
Ok, I changed:
output:
    pin: P8
to:
output:
  - platform: gpio
    pin: P8
for all the outputs…and now the middle button backlight is working! :grin: (Maybe there were different residual pwm settings for the different buttons???)
