Weird Zigbee issue
So I have several Zigbee devices and one in particular is causing me some confusion. It’s a Zigbee wall switch that I use to trigger a routine that closes my Pergola roof. However when I press it, other Zigbee devices turn on (whether I press on or off on the mentioned switch). I can’t figure out why this is happening, no other automations are related to this switch. See attached log where you can see the switch pressed, the roof routine is triggered but then other switches are turned on which are unrelated.
Also if it helps the switch is Aqara opple 1 gang using Zigbee2MQTT direct. (Lumi remote b286opcn01)
Read the section on binding to unbind it.
https://www.zigbee2mqtt.io/devices/WXCJKG11LM.html
Lovely, worked a treat. Thanks for the steer.
