sender
November 29, 2022, 10:53pm
1
Suddenly I have weird behavior.
2 days ago a mains powered device was suddenly “gone”. I had to exclude and included it and it is now back. This oneqas just totally gone,not device, not entity.
Then another mains powered was gone. But thedevice was still in and entities unavailable. Powerof and on brought it back.
Today abattery powered door sensorwhich worked well for years suddenly does not anymore. Device is still in and entities are active. But no status uodates.
Having these weird messages in log:
The node is now asleep.
2022-11-29T22:00:34.693Z DRIVER dropping CC with invalid values (Reason: Unsupported rate type Unspecified or
corrupted data)
2022-11-29T22:00:35.706Z DRIVER dropping CC with invalid values (Reason: Unsupported rate type Unspecified or
corrupted data)
2022-11-29T22:09:59.362Z CNTRLR [Node 076] Timed out while waiting for a response from the node (ZW0201)
2022-11-29T22:10:35.451Z DRIVER dropping CC with invalid values (Reason: Unsupported rate type Unspecified or
corrupted data)
2022-11-29T22:10:36.440Z DRIVER dropping CC with invalid values (Reason: Unsupported rate type Unspecified or
What’s wrong?
Running latest zwavejs addon and standaard integration (not zwaevjs ui)
sender
November 29, 2022, 11:03pm
2
Some logging fwiw
Subscribed to Z-Wave JS Log Messages…
Log Level changed to: Silly
2022-11-29T22:55:18.493Z SERIAL « 0x01120004005b0a32022134000000000000c3005e (20 bytes)
2022-11-29T22:55:18.494Z SERIAL » [ACK] (0x06)
2022-11-29T22:55:18.495Z CNTRLR [Node 091] [translateValueEvent: value updated]
commandClass: Meter
endpoint: 0
property: value
propertyKey: 66049
internal: false
secret: false
event source: undefined
2022-11-29T22:55:18.496Z CNTRLR [Node 091] [~] [Meter] value[66049]: 0 => 0 [Endpoint 0]
2022-11-29T22:55:18.497Z CNTRLR [Node 091] [translateValueEvent: value updated]
is root endpoint: true
is application CC: true
should hide root values: false
2022-11-29T22:55:18.498Z DRIVER « [Node 091] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: W
rate type: Consumed
value: 0
time delta: 0 seconds
2022-11-29T22:55:26.464Z SERIAL « 0x0116000400710e600d010032022134000000000000c7001c (24 bytes)
2022-11-29T22:55:26.465Z SERIAL » [ACK] (0x06)
2022-11-29T22:55:26.466Z CNTRLR [Node 113] [translateValueEvent: value updated]
commandClass: Meter
endpoint: 1
property: value
propertyKey: 66049
internal: false
secret: false
2022-11-29T22:55:26.467Z CNTRLR [Node 113] [~] [Meter] value[66049]: 0 => 0 [Endpoint 1]
2022-11-29T22:55:26.467Z CNTRLR [Node 113] [translateValueEvent: value updated]
is root endpoint: false
2022-11-29T22:55:26.468Z DRIVER « [Node 113] [REQ] [ApplicationCommand]
└─[MultiChannelCCCommandEncapsulation]
│ source: 1
│ destination: 0
└─[MeterCCReport]
type: Electric
scale: W
rate type: Consumed
value: 0
2022-11-29T22:55:27.463Z SERIAL « 0x0116000400710e600d020032022134000000000000c7001f (24 bytes)
2022-11-29T22:55:27.465Z SERIAL » [ACK] (0x06)
2022-11-29T22:55:27.466Z CNTRLR [Node 113] [translateValueEvent: value updated]
commandClass: Meter
endpoint: 2
property: value
propertyKey: 66049
internal: false
secret: false
2022-11-29T22:55:27.469Z CNTRLR [Node 113] [~] [Meter] value[66049]: 0 => 0 [Endpoint 2]
2022-11-29T22:55:27.470Z CNTRLR [Node 113] [translateValueEvent: value updated]
2022-11-29T22:55:27.471Z DRIVER « [Node 113] [REQ] [ApplicationCommand]
│ source: 2
│ destination: 0
└─[MeterCCReport]
type: Electric
scale: W
rate type: Consumed
value: 0
2022-11-29T22:55:28.080Z SERIAL » 0x010900133d02260225d10a (11 bytes)
2022-11-29T22:55:28.080Z DRIVER » [Node 061] [REQ] [SendData]
│ transmit options: 0x25
│ callback id: 209
└─[MultilevelSwitchCCGet]
2022-11-29T22:55:28.083Z SERIAL « [ACK] (0x06)
2022-11-29T22:55:28.091Z SERIAL « 0x0104011301e8 (6 bytes)
2022-11-29T22:55:28.091Z SERIAL » [ACK] (0x06)
2022-11-29T22:55:28.092Z DRIVER « [RES] [SendData]
was sent: true
2022-11-29T22:55:28.128Z SERIAL « 0x01180013d100000200b17f7f7f7f010103000000000201000096 (26 bytes)
2022-11-29T22:55:28.129Z SERIAL » [ACK] (0x06)
2022-11-29T22:55:28.130Z DRIVER « [REQ] [SendData]
callback id: 209
transmit status: OK, took 20 ms
routing attempts: 1
protocol & route speed: Z-Wave, 40 kbit/s
ACK RSSI: -79 dBm
ACK channel no.: 1
TX channel no.: 1
2022-11-29T22:55:28.150Z SERIAL « 0x010b0004003d03260300b1005a (13 bytes)
2022-11-29T22:55:28.151Z SERIAL » [ACK] (0x06)
2022-11-29T22:55:28.151Z CNTRLR [Node 061] [translateValueEvent: value updated]
commandClass: Multilevel Switch
endpoint: 0
property: currentValue
propertyKey: undefined
internal: false
secret: false
2022-11-29T22:55:28.152Z CNTRLR [Node 061] [~] [Multilevel Switch] currentValue: 0 => 0 [Endpoint 0]
2022-11-29T22:55:28.152Z CNTRLR [Node 061] [translateValueEvent: value updated]
2022-11-29T22:55:28.153Z DRIVER « [Node 061] [REQ] [ApplicationCommand]
└─[MultilevelSwitchCCReport]
current value: 0
2022-11-29T22:55:53.412Z SERIAL « 0x01160004004e0e600d010032022134000000000000b60052 (24 bytes)
2022-11-29T22:55:53.412Z SERIAL » [ACK] (0x06)
2022-11-29T22:55:53.414Z CNTRLR [Node 078] [translateValueEvent: value updated]
commandClass: Meter
endpoint: 1
property: value
propertyKey: 66049
internal: false
secret: false
2022-11-29T22:55:53.414Z CNTRLR [Node 078] [~] [Meter] value[66049]: 0 => 0 [Endpoint 1]
2022-11-29T22:55:53.415Z DRIVER « [Node 078] [REQ] [ApplicationCommand]
│ source: 1
│ destination: 0
└─[MeterCCReport]
type: Electric
scale: W
rate type: Consumed
value: 0
2022-11-29T22:55:54.421Z SERIAL « 0x01160004004e0e600d020032022134000000000000b50052 (24 bytes)
2022-11-29T22:55:54.421Z SERIAL » [ACK] (0x06)
2022-11-29T22:55:54.422Z CNTRLR [Node 078] [translateValueEvent: value updated]
commandClass: Meter
endpoint: 2
property: value
propertyKey: 66049
internal: false
secret: false
2022-11-29T22:55:54.422Z CNTRLR [Node 078] [~] [Meter] value[66049]: 0 => 0 [Endpoint 2]
2022-11-29T22:55:54.423Z DRIVER « [Node 078] [REQ] [ApplicationCommand]
│ source: 2
│ destination: 0
└─[MeterCCReport]
type: Electric
scale: W
rate type: Consumed
value: 0
2022-11-29T22:56:47.908Z SERIAL « 0x01120004005b0a3202213400acedc50000c300da (20 bytes)
2022-11-29T22:56:47.909Z SERIAL » [ACK] (0x06)
2022-11-29T22:56:47.909Z CNTRLR [Node 091] [translateValueEvent: value updated]
commandClass: Meter
endpoint: 0
property: value
propertyKey: 66049
internal: false
secret: false
2022-11-29T22:56:47.910Z CNTRLR [Node 091] [~] [Meter] value[66049]: 0 => 1133306.1 [Endpoint 0]
2022-11-29T22:56:47.910Z CNTRLR [Node 091] [translateValueEvent: value updated]
2022-11-29T22:56:47.911Z DRIVER « [Node 091] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: W
rate type: Consumed
value: 1133306.1
2022-11-29T22:56:48.907Z SERIAL « 0x01120004005b0a32022134000000000000c3005e (20 bytes)
2022-11-29T22:56:48.908Z SERIAL » [ACK] (0x06)
2022-11-29T22:56:48.908Z CNTRLR [Node 091] [translateValueEvent: value updated]
commandClass: Meter
endpoint: 0
property: value
propertyKey: 66049
internal: false
secret: false
2022-11-29T22:56:48.909Z CNTRLR [Node 091] [~] [Meter] value[66049]: 1133306.1 => 0 [Endpoint 0]
2022-11-29T22:56:48.909Z CNTRLR [Node 091] [translateValueEvent: value updated]
2022-11-29T22:56:48.909Z DRIVER « [Node 091] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: W
rate type: Consumed
value: 0
2022-11-29T22:56:57.106Z SERIAL « 0x010e00040017063105012200c8c900f2 (16 bytes)
2022-11-29T22:56:57.106Z SERIAL » [ACK] (0x06)
2022-11-29T22:56:57.107Z CNTRLR [Node 023] [translateValueEvent: metadata updated]
commandClass: Multilevel Sensor
endpoint: 0
property: Air temperature
internal: false
secret: false
2022-11-29T22:56:57.108Z CNTRLR [Node 023] [Multilevel Sensor] Air temperature: metadata updated [Endpoint 0]
2022-11-29T22:56:57.108Z CNTRLR [Node 023] [translateValueEvent: metadata updated]
2022-11-29T22:56:57.108Z CNTRLR [Node 023] [translateValueEvent: value updated]
endpoint: 0
internal: false
secret: false
2022-11-29T22:56:57.109Z CNTRLR [Node 023] [~] [Multilevel Sensor] Air temperature: 20 => 20 [Endpoint 0]
2022-11-29T22:56:57.109Z CNTRLR [Node 023] [translateValueEvent: value updated]
2022-11-29T22:56:57.110Z DRIVER « [Node 023] [REQ] [ApplicationCommand]
└─[MultilevelSensorCCReport]
type: Air temperature
scale: Celsius
value: 20
2022-11-29T22:56:58.080Z SERIAL » 0x010900134102260225d275 (11 bytes)
2022-11-29T22:56:58.080Z DRIVER » [Node 065] [REQ] [SendData]
│ callback id: 210
2022-11-29T22:56:58.082Z SERIAL « [ACK] (0x06)
2022-11-29T22:56:58.088Z SERIAL « 0x0104011301e8 (6 bytes)
2022-11-29T22:56:58.090Z SERIAL » [ACK] (0x06)
2022-11-29T22:56:58.091Z DRIVER « [RES] [SendData]
was sent: true
2022-11-29T22:56:58.121Z SERIAL « 0x01180013d200000200bc7f7f7f7f010103000000000201000098 (26 bytes)
2022-11-29T22:56:58.121Z SERIAL » [ACK] (0x06)
2022-11-29T22:56:58.122Z DRIVER « [REQ] [SendData]
callback id: 210
routing attempts: 1
ACK RSSI: -68 dBm
ACK channel no.: 1
TX channel no.: 1
2022-11-29T22:56:58.137Z SERIAL « 0x010b0004004103260300b9002e (13 bytes)
2022-11-29T22:56:58.137Z SERIAL » [ACK] (0x06)
2022-11-29T22:56:58.138Z CNTRLR [Node 065] [translateValueEvent: value updated]
endpoint: 0
internal: false
secret: false
2022-11-29T22:56:58.139Z CNTRLR [Node 065] [~] [Multilevel Switch] currentValue: 0 => 0 [Endpoint 0]
2022-11-29T22:56:58.139Z CNTRLR [Node 065] [translateValueEvent: value updated]
2022-11-29T22:56:58.140Z DRIVER « [Node 065] [REQ] [ApplicationCommand]
current value: 0
2022-11-29T22:57:15.930Z SERIAL « 0x0117000400640f32022144000000640e100000006400d80014 (25 bytes)
2022-11-29T22:57:15.930Z SERIAL » [ACK] (0x06)
2022-11-29T22:57:15.931Z CNTRLR [Node 100] [translateValueEvent: value updated]
commandClass: Meter
endpoint: 0
property: value
propertyKey: 65537
internal: false
secret: false
2022-11-29T22:57:15.931Z CNTRLR [Node 100] [~] [Meter] value[65537]: 1 => 1 [Endpoint 0]
2022-11-29T22:57:15.932Z CNTRLR [Node 100] [translateValueEvent: value updated]
2022-11-29T22:57:15.932Z DRIVER « [Node 100] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: kWh
rate type: Consumed
value: 1
time delta: 3600 seconds
prev. value: 1
2022-11-29T22:57:37.857Z SERIAL « 0x010b00040034033003ffb600bd (13 bytes)
2022-11-29T22:57:37.857Z SERIAL » [ACK] (0x06)
2022-11-29T22:57:37.858Z CNTRLR [Node 052] [translateValueEvent: metadata updated]
commandClass: Binary Sensor
endpoint: 0
property: Any
internal: false
secret: false
2022-11-29T22:57:37.858Z CNTRLR [Node 052] [Binary Sensor] Any: metadata updated [Endpoint 0]
2022-11-29T22:57:37.859Z CNTRLR [Node 052] [translateValueEvent: metadata updated]
2022-11-29T22:57:37.859Z CNTRLR [Node 052] [translateValueEvent: value updated]
endpoint: 0
property: Any
internal: false
secret: false
2022-11-29T22:57:37.860Z CNTRLR [Node 052] [~] [Binary Sensor] Any: false => true [Endpoint 0]
2022-11-29T22:57:37.860Z CNTRLR [Node 052] [translateValueEvent: value updated]
2022-11-29T22:57:37.860Z DRIVER « [Node 052] [REQ] [ApplicationCommand]
└─[BinarySensorCCReport]
type: Any
value: true
2022-11-29T22:57:42.975Z SERIAL « 0x010b0004003403300300b50041 (13 bytes)
2022-11-29T22:57:42.976Z SERIAL » [ACK] (0x06)
2022-11-29T22:57:42.976Z CNTRLR [Node 052] [translateValueEvent: metadata updated]
endpoint: 0
property: Any
internal: false
secret: false
2022-11-29T22:57:42.976Z CNTRLR [Node 052] [Binary Sensor] Any: metadata updated [Endpoint 0]
2022-11-29T22:57:42.977Z CNTRLR [Node 052] [translateValueEvent: value updated]
endpoint: 0
property: Any
internal: false
secret: false
2022-11-29T22:57:42.977Z CNTRLR [Node 052] [~] [Binary Sensor] Any: true => false [Endpoint 0]
2022-11-29T22:57:42.977Z DRIVER « [Node 052] [REQ] [ApplicationCommand]
type: Any
value: false
2022-11-29T22:57:52.523Z SERIAL « 0x01120004004b0a32022134000000000000ca0047 (20 bytes)
2022-11-29T22:57:52.523Z SERIAL » [ACK] (0x06)
2022-11-29T22:57:52.524Z CNTRLR [Node 075] [translateValueEvent: value updated]
commandClass: Meter
endpoint: 0
property: value
propertyKey: 66049
internal: false
secret: false
2022-11-29T22:57:52.525Z CNTRLR [Node 075] [~] [Meter] value[66049]: 0 => 0 [Endpoint 0]
2022-11-29T22:57:52.525Z CNTRLR [Node 075] [translateValueEvent: value updated]
2022-11-29T22:57:52.525Z DRIVER « [Node 075] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: W
rate type: Consumed
value: 0
2022-11-29T22:57:55.519Z SERIAL « 0x01140004004f0c600d030331050144000008efd20085 (22 bytes)
2022-11-29T22:57:55.519Z SERIAL » [ACK] (0x06)
2022-11-29T22:57:55.520Z CNTRLR [Node 079] [translateValueEvent: metadata updated]
endpoint: 3
internal: false
secret: false
2022-11-29T22:57:55.520Z CNTRLR [Node 079] [Multilevel Sensor] Air temperature: metadata updated [Endpoint 3]
2022-11-29T22:57:55.521Z CNTRLR [Node 079] [translateValueEvent: metadata updated]
should hide root values: true
2022-11-29T22:57:55.521Z CNTRLR [Node 079] [translateValueEvent: value updated]
endpoint: 3
internal: false
secret: false
2022-11-29T22:57:55.521Z CNTRLR [Node 079] [~] [Multilevel Sensor] Air temperature: 22.87 => 22.8 [Endpoint 3]
7
2022-11-29T22:57:55.522Z DRIVER « [Node 079] [REQ] [ApplicationCommand]
│ source: 3
│ destination: 3
scale: Celsius
value: 22.87
2022-11-29T22:57:55.541Z SERIAL « 0x01140004004f0c600d04043105014400000dd1d200be (22 bytes)
2022-11-29T22:57:55.542Z SERIAL » [ACK] (0x06)
2022-11-29T22:57:55.542Z CNTRLR [Node 079] [translateValueEvent: metadata updated]
endpoint: 4
internal: false
secret: false
2022-11-29T22:57:55.543Z CNTRLR [Node 079] [Multilevel Sensor] Air temperature: metadata updated [Endpoint 4]
2022-11-29T22:57:55.543Z CNTRLR [Node 079] [translateValueEvent: metadata updated]
2022-11-29T22:57:55.544Z CNTRLR [Node 079] [translateValueEvent: value updated]
endpoint: 4
internal: false
secret: false
2022-11-29T22:57:55.544Z CNTRLR [Node 079] [~] [Multilevel Sensor] Air temperature: 35.37 => 35.3 [Endpoint 4]
7
2022-11-29T22:57:55.545Z DRIVER « [Node 079] [REQ] [ApplicationCommand]
│ source: 4
│ destination: 4
scale: Celsius
value: 35.37
2022-11-29T22:58:25.497Z SERIAL « 0x0116000400470e600d0100320221340000004d00007e00de (24 bytes)
2022-11-29T22:58:25.497Z SERIAL » [ACK] (0x06)
2022-11-29T22:58:25.499Z CNTRLR [Node 071]
