Is there a way to make a greeting that plays ONLY when my phone has been gone and has recently come back into my home zone?
For example. When my front door opens (which i have a sensor on) i want to welcome myself home by name on a speaker. I know how to fire the greeting, i just want to know how to fire it only once after my phone has entered back into my home zone. If that makes sense? I’m guessing this will have to do with the conditions section in automations… Just didn’t know what to put.
When your phone state changes from not_home to home, you want to enable a greeting automation that will be triggered by the door sensor. Then once the door is opened or a timeout of 15 minutes later, disable the automation.
great, thanks guys. i was basing this off the geolocation of my phone which has the HA app on it. Wouldn’t this theoretically be a better solution than waiting for it to talk to wifi? by the time i was on wifi i’m guessing the door would already have been entered. also, i notice the state on my location entity is “away” when i’m gone, not the “not-home” that you guys are using. which one should i go with?
Oh I’m using the wifi because I did not have much data on my phone so the 3G is closed most of the time.
So the zone event is not send before the wifi is connected anyways .
If you use the enter zone trigger you don’t have to use the from: not_home anyways
You can check that with the developer tool or the history
