Wemo Air Purifier Connection Failing
Setup Information:
Raspberry Pi 3
Home Assistant Hass.io
Version 0.73.0
Aeotec Z-Stick Gen5
Aeotec Siren Gen5, Z-Wave Plus, 105dB siren with strobe alerts, Plug-in, Backup battery
Aeotec by Aeon Labs ZW120 Door / Window Sensor, Small, White
Holmes Smart Wifi-Enabled WeMo True-HEPA Premium Air Purifier, WAP532
Hi All,
I have had very little success integrating the about Wemo Air Purifier into HA. I have attempted to use the wemo component leveraging auto discovery, but no success.
wemo:
I have attempted to staticly configure wemo using the device IP address, but no success.
wemo:
  static:
    - XXX.XX
With the last attempt, home-assistant.log file shows the following information:
2018-07-12 13:55:10 ERROR (SyncWorker_6) [pywemo.ssdp] Found malformed XML at http://192.168.55.45:9080: status=ok
2018-07-12 13:55:15 WARNING (MainThread) [homeassistant.setup] Setup of config is taking over 10 seconds.
2018-07-12 13:55:15 ERROR (MainThread) [homeassistant.setup] Error during setup of component wemo
  File "/usr/lib/python3.6/site-packages/homeassistant/setup.py", line 146, in _async_setup_component
    component.setup, hass, processed_config)  # type: ignore
  File "/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/usr/lib/python3.6/site-packages/homeassistant/components/wemo.py", line 100, in setup
    'model_name': device.model_name,
AttributeError: 'NoneType' object has no attribute 'model_name'
2018-07-12 13:55:49 WARNING (SyncWorker_0) [netdisco.ssdp] Found malformed XML at http://192.168.55.45:9080: status=ok
2018-07-12 13:55:55 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of switch.wemo. Setup failed for dependencies: wemo
2018-07-12 13:55:55 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform switch.wemo: Could not setup all dependencies.
Does anyone have any suggestions on how to resolve these issues with integrating the Wemo Air Purifier into HA?
Thanks in advance for any help!
Any ideas?
Did you try to use it before home assistant version 73? I don’t have air purifier but my wemo lights have been misbehaving since the 0.73 update.
Just having a look at the docs, is the air purifier supported?
I think it’s not supported in HA. The docs only mention lights, switches and coffee makers.
