I just upgraded to 0.103.6, and wemo seems to be causing problems. Here’s what I see in the main home assistant log file: Component error: wemo - No module named 'netdisco'
My wemo config section is pretty simple: wemo:
I’m not sure how to troubleshoot this - it looks like discovery is turned on by default, so why would it say that the module doesn’t exist?
I had this with my konnected component, something to do with optional dependencies afaik.
The same issue has also been reported for roku component
Looks like you aren’t running hassio, so you should be able to resolve it with (substitute your python version for 3.7 and run inside venv if you are running that way). python3.7 -m pip install netdisco
