Hi all,
New member here, I’ve been getting started with Home Assistant over the last few days.
I’ve been getting a few devices together so that I can start trying things out.
Unfortunately my existing LightwaveRF dimmer switches aren’t currently supported by HA, so I picked up a WeMo Lighting Starter Pack (2 x bulbs and 1 x Link) and an Echo Dot to start trying out some voice controlled lamps through HA.
The Echo Dot seems to communicate fine with Home Assistant, and I’ve successfully used my voice to instruct HA to turn off my smart tv.
I am having a problem with the WeMo bulbs though:
I added the WeMo Link to my wifi network, and paired the 2 bulbs to the Link.
I have tried adding the following combinations of entries to my configuration.yaml file:
1. Just auto discovery
discovery:
2. Auto discovery AND the wemo component
discovery:
wemo:
3. Auto discovery AND the wemo component with IP Address of my Link
discovery:
wemo:
static:
- 100.124.245.26
Regardless of the configuration, I get the following error in my home-assistant.log file:
16-11-18 00:38:53 homeassistant.bootstrap: Error during setup of component wemo
File "/srv/hass/lib/python3.5/site-packages/homeassistant/bootstrap.py", line 149, in _async_setup_component
None, component.setup, hass, config)
File "/usr/lib/python3.5/asyncio/futures.py", line 361, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.5/asyncio/tasks.py", line 296, in _wakeup
future.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 274, in result
raise self._exception
File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
File "/srv/hass/lib/python3.5/site-packages/homeassistant/components/wemo.py", line 80, in setup
devices = [(device.host, device) for device in pywemo.discover_devices()]
File "/home/hass/.homeassistant/deps/pywemo/discovery.py", line 27, in discover_devices
device = device_from_description(entry.location, mac)
File "/home/hass/.homeassistant/deps/pywemo/discovery.py", line 39, in device_from_description
return device_from_uuid_and_location(uuid, mac, description_url)
File "/home/hass/.homeassistant/deps/pywemo/discovery.py", line 55, in device_from_uuid_and_location
return Bridge(location, mac)
File "/home/hass/.homeassistant/deps/pywemo/ouimeaux_device/bridge.py", line 39, in __init__
self.bridge_update()
File "/home/hass/.homeassistant/deps/pywemo/ouimeaux_device/bridge.py", line 63, in bridge_update
self.Groups[uniqueID] = Group(self, group)
File "/home/hass/.homeassistant/deps/pywemo/ouimeaux_device/bridge.py", line 266, in __init__
super(Group, self).__init__(bridge, info)
File "/home/hass/.homeassistant/deps/pywemo/ouimeaux_device/bridge.py", line 92, in __init__
self._update_state(info)
File "/home/hass/.homeassistant/deps/pywemo/ouimeaux_device/bridge.py", line 280, in _update_state
for c in capabilities.split(',')
AttributeError: 'NoneType' object has no attribute 'split'
16-11-18 00:39:48 homeassistant.bootstrap: Error during setup of component wemo
future.result()
16-11-18 00:39:48 homeassistant.bootstrap: Component wemo failed to setup
16-11-18 00:39:48 homeassistant.components.light.hue: Error connecting to the Hue bridge at 192.127.0.102
Does anyone have an idea of what I might be doing wrong?
Surely methods 1 and 2 should have worked fine on their own?
Thanks in advance
