I use 3 different wemo switches link and I often find that they are “unavailable” within hassio. Rebooting my hassio server occasionally works to find them, but not always. They typically will come back, but there doesn’t seem to be any rhyme or reason to it. Just wanted to see if anyone else has this problem.
Yes right from the beginning. I originally had them on a single AP, and they were always very low on signal, so I could understand why they were dropping out.
So I figured I’d fix it by getting multiple AP’s. Then I found they were unreliable in a multiple SSID configuration; they would always connected to the lowest mac address instead of the highest signal strength, so I put in some single SSIDs to hard-code them to.
Even that way, they still used to dropout frequently. I suspect they were just too old (even the newest F/W they were running 11g mode) and maybe weren’t too happy with the newer 11n mode I was running on the 2.4GHz wifi.
I had that issue when only using discovery mode, I changed the switches to fixed IP and then specified the IP in configuration.yaml and they have been rock solid since then.
Had to do this for reliability for myself as well. I did, however, just buy a 3-pack of TP-Link mini plugs to replace these as they stop behaving. OP, I have the exact same WeMo plugs you do too, same nonsense.
Got a few of the HS110s as well, like you set on static.
Again, like you very reliable. That said I prefer the wemo pugs as they capture power consumption.
Do you mean power consumption over time (kwh) vs just the instantaneous draw (kw)? E.g. Wemo did power consumption over time, and the HS110 only does instantaneous consumption?
I realize this is a very late update, but ultimately changing the switches to fixed IP did not fix the problem. See image for a typical example of how often the connection drops:
Additionally, one of my switches just won’t connect at all anymore. Bottom line - don’t buy Wemo!
