Hi, since updating from 0.30.2 I am unable to get my Wemo devices to connect. I have HA running in a Docker on a Synology NAS. They worked fine on 0.30.2 and the only way I can get it to work again is to revert to 0.30.2.
Any ideas? Thanks in advance…
Here is the log:
10/26/2016 5:43 stdout requests.exceptions.ConnectTimeout: HTTPConnectionPool(host='192.168.1.196', port=49153): Max retries exceeded with url: /setup.xml (Caused by ConnectTimeoutError(<requests.packages.urllib3.connection.HTTPConnection object at 0x7f79253467b8>, 'Connection to 192.168.1.196 timed out. (connect timeout=10)'))e[0m
10/26/2016 5:43 stdout raise ConnectTimeout(e, request=request)
10/26/2016 5:43 stdout File \/usr/local/lib/python3.5/site-packages/requests/adapters.py\" line 479 in send"
10/26/2016 5:43 stdout r = adapter.send(request, **kwargs)
10/26/2016 5:43 stdout File \/usr/local/lib/python3.5/site-packages/requests/sessions.py\" line 596 in send"
10/26/2016 5:43 stdout resp = self.send(prep, **send_kwargs)
10/26/2016 5:43 stdout File \/usr/local/lib/python3.5/site-packages/requests/sessions.py\" line 475 in request"
10/26/2016 5:43 stdout return session.request(method=method, url=url, **kwargs)
10/26/2016 5:43 stdout File \/usr/local/lib/python3.5/site-packages/requests/api.py\" line 56 in request"
10/26/2016 5:43 stdout return request('get', url, params=params, **kwargs)
10/26/2016 5:43 stdout File \/usr/local/lib/python3.5/site-packages/requests/api.py\" line 70 in get"
10/26/2016 5:43 stdout xml = requests.get(url, timeout=10)
10/26/2016 5:43 stdout File \/usr/local/lib/python3.5/site-packages/pywemo/ouimeaux_device/__init__.py\" line 62 in __init__"
10/26/2016 5:43 stdout return Switch(location, mac)
10/26/2016 5:43 stdout File \/usr/local/lib/python3.5/site-packages/pywemo/discovery.py\" line 45 in device_from_uuid_and_location"
10/26/2016 5:43 stdout return device_from_uuid_and_location(uuid, mac, description_url)
10/26/2016 5:43 stdout File \/usr/local/lib/python3.5/site-packages/pywemo/discovery.py\" line 39 in device_from_description"
10/26/2016 5:43 stdout device = pywemo.discovery.device_from_description(url, None)
10/26/2016 5:43 stdout File \/usr/src/app/homeassistant/components/wemo.py\" line 95 in setup"
10/26/2016 5:43 stdout result = component.setup(hass, config)
10/26/2016 5:43 stdout File \/usr/src/app/homeassistant/bootstrap.py\" line 106 in _setup_component"
10/26/2016 5:43 stdout Traceback (most recent call last):
10/26/2016 5:43 stdout During handling of the above exception, another exception occurred:
10/26/2016 5:43 stdout requests.packages.urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.1.196', port=49153): Max retries exceeded with url: /setup.xml (Caused by ConnectTimeoutError(<requests.packages.urllib3.connection.HTTPConnection object at 0x7f79253467b8>, 'Connection to 192.168.1.196 timed out. (connect timeout=10)'))
10/26/2016 5:43 stdout raise MaxRetryError(_pool, url, error or ResponseError(cause))
10/26/2016 5:43 stdout File \/usr/local/lib/python3.5/site-packages/requests/packages/urllib3/util/retry.py\" line 287 in increment"
10/26/2016 5:43 stdout _stacktrace=sys.exc_info()[2])
10/26/2016 5:43 stdout File \/usr/local/lib/python3.5/site-packages/requests/packages/urllib3/connectionpool.py\" line 640 in urlopen"
10/26/2016 5:43 stdout timeout=timeout
10/26/2016 5:43 stdout File \/usr/local/lib/python3.5/site-packages/requests/adapters.py\" line 423 in send"
10/26/2016 5:43 stdout requests.packages.urllib3.exceptions.ConnectTimeoutError: (<requests.packages.urllib3.connection.HTTPConnection object at 0x7f79253467b8>, 'Connection to 192.168.1.196 timed out. (connect timeout=10)')
10/26/2016 5:43 stdout (self.host, self.timeout))
10/26/2016 5:43 stdout File \/usr/local/lib/python3.5/site-packages/requests/packages/urllib3/connection.py\" line 147 in _new_conn"
10/26/2016 5:43 stdout conn = self._new_conn()
10/26/2016 5:43 stdout File \/usr/local/lib/python3.5/site-packages/requests/packages/urllib3/connection.py\" line 167 in connect"
10/26/2016 5:43 stdout self.connect()
10/26/2016 5:43 stdout File \/usr/local/lib/python3.5/http/client.py\" line 877 in send"
10/26/2016 5:43 stdout self.send(msg)
10/26/2016 5:43 stdout File \/usr/local/lib/python3.5/http/client.py\" line 934 in _send_output"
10/26/2016 5:43 stdout self._send_output(message_body)
10/26/2016 5:43 stdout File \/usr/local/lib/python3.5/http/client.py\" line 1102 in endheaders"
10/26/2016 5:43 stdout self.endheaders(body)
10/26/2016 5:43 stdout File \/usr/local/lib/python3.5/http/client.py\" line 1151 in _send_request"
10/26/2016 5:43 stdout self._send_request(method, url, body, headers)
10/26/2016 5:43 stdout File \/usr/local/lib/python3.5/http/client.py\" line 1106 in request"
10/26/2016 5:43 stdout conn.request(method, url, **httplib_request_kw)
10/26/2016 5:43 stdout File \/usr/local/lib/python3.5/site-packages/requests/packages/urllib3/connectionpool.py\" line 363 in _make_request"
10/26/2016 5:43 stdout chunked=chunked)
10/26/2016 5:43 stdout File \/usr/local/lib/python3.5/site-packages/requests/packages/urllib3/connectionpool.py\" line 595 in urlopen"
10/26/2016 5:43 stdout socket.timeout: timed out
10/26/2016 5:43 stdout sock.connect(sa)
10/26/2016 5:43 stdout File \/usr/local/lib/python3.5/site-packages/requests/packages/urllib3/util/connection.py\" line 88 in create_connection"
10/26/2016 5:43 stdout raise err
10/26/2016 5:43 stdout File \/usr/local/lib/python3.5/site-packages/requests/packages/urllib3/util/connection.py\" line 98 in create_connection"
10/26/2016 5:43 stdout (self.host, self.port), self.timeout, **extra_kw)
10/26/2016 5:43 stdout File \/usr/local/lib/python3.5/site-packages/requests/packages/urllib3/connection.py\" line 142 in _new_conn"
10/26/2016 5:43 stdout e[31m16-10-26 05:43:38 ERROR (Thread-1) [homeassistant.bootstrap] Error during setup of component wemoe[0m
10/26/2016 5:43 stdout e[32m16-10-26 05:43:25 INFO (Thread-1) [homeassistant.components.wemo] Adding wemo at 192.168.1.196:49153e[0m
10/26/2016 5:43 stdout e[32m16-10-26 05:43:18 INFO (Thread-1) [homeassistant.components.wemo] Scanning for WeMo devices.e[0m
10/26/2016 5:43 stdout e[32m16-10-26 05:43:09 INFO (Thread-1) [homeassistant.loader] Loaded wemo from homeassistant.components.wemoe[0m
10/26/2016 5:43 stdout Config directory: /config
