I just started playing with HA last week and am working on adding different components. I recently purchased the WEMO light kit and am trying to connect it to HA. I have tried using the discovery component and the wemo component, but both result in a description.xml error.
I am running HA on a rpi2 and through a docker container for testing. Any suggestions on what I can do to get these integrated? As a side problem, I am also unable to get Plex to connect either.
How do you have it set up in your configuration.yaml file?
Also, Plex will only show up if you have a client currently connected to the Plex server when you startup HA at first. BTW, FireTV connected to Plex won’t count; it will show the component for the FireTV instead.
For the WEMO, I tried using the discovery and the WEMO components. I also tried to set the ip address. All methods returned the same errors in the log.
I didn’t know Plex would only show up if a client was connected at startup. I figured the component would only display in HA while a client was connected. Thanks.
homeassistant:
Name of the location where Home Assistant is running
Location required to calculate the time the sun rises and sets
Not sure but it seems strange to me that you put in 192.168.1.106 but the pywemo errors are from the locahost and another IP range…
Granted, I’m on WIn10 and so it’s probably different, but any errors I’ve ever gotten either had my actual IP of the HA host or one of the IP addresses on the same subnet. What are you running HA on?
Well I was playing with it on my RPI2, but I switched back over to the docker container and its working fine. I thought the switched would show up automatically, but I had to put them in a group in order for them to show on the dashboard. Now I get to play with automation. YAY!.
Oh! I assumed you had them in a group already. If you didn’t change the default_view though, they should have shown up in a group with all the switches. Not sure why that didn’t happen. Glad you got it working though.
