EDIT: It started to work Dont know why but out of desperation i turned d1 and d2 into gpio4 and 5 again and what didn’t work at first works now. I also changed scan false to true (had tried that to). I am not sure what fixed it but it works now. So hopefully this post will be helpful for people in the futur trying to figure it out
Good evening all, I cant get an AM2320 to work with my wemos d1 mini, i get an error : [20:14:23][D][am2320:065]: AM2320:
[20:14:23][C][am2320:066]: Address: 0x5C
[20:14:23][E][am2320:068]: Communication with AM2320 failed!
SDA and SDL are connected to d1 and d2 , and i have tried with or without 4.7k resistors between them an vcc, it does not seem to make any difference.
I do see an address in my log, which means it is connected to the correct pins right? But it wont communicate
I did find an older post telling me to push the rested button on the side but alas that didnt help. I also found a setting : setup_priority: -100, but that dint help either.
Below is my yaml, i am probably doing something stupid, since i’m not experienced, but any help is appreciated. I have also uploaded a picture of my breadboard
(I did try renaming d1 and d2 to gpio4 and 5, but that didn’t help either.)
captive_portal:
i2c:
sda: D1 <<changed that to GPIO4
scl: D2 <<Changed that to GPIO5
scan: false << Changed that to true
- platform: am2320
address: 0x5C
temperature:
name: "Living Room Temperature"
humidity:
name: "Living Room Humidity"
update_interval: 60s`
