Wemos D1 mini deep sleep does not work properly
I have built a sensor with the distance meter and the state of the battery.
The sensor should read the values of the battery and the distance, then it should go to sleep.
After the start, the values are read out, but it does not go into deep sleep mode. However, if I set sleep_mode to ON via mqtt, then it goes into deep_sleep, but not again after waking up.
ota_mode is set to OFF.
RST is set to D0 with R220.
A0 is connected to B+ via 100kOhm.
esphome:
  platform: ESP8266
  board: d1_mini
# Enable logging
logger:
    level: DEBUG
# Enable Home Assistant API
mqtt:
  broker: !secret mqtt_url
  username: !secret mqtt_user
  password: !secret mqtt_pass
  discovery: True
  discovery_retain: True
  birth_message:
  will_message:
  topic_prefix: 'regentonne'
  on_message:
    - topic: esp/ota_mode
      payload: 'ON'
      then:
        - deep_sleep.prevent: deep_sleep_control
    - topic: esp/sleep_mode
      payload: 'ON'
      then:
        - deep_sleep.enter: deep_sleep_control
ota:
  password: "123456"
wifi:
  ssid: "xxxxxxxxxxx"
  password: "xxxxxxxx"
  fast_connect: True
  ap:
    ssid: "Regentonne Fallback Hotspot"
    password: "xxxxxxxxxxx"
captive_portal:
i2c:
  sda: D3
  scl: D2
  scan: True
  - platform: adc
    pin: A0
    name: "Regentonne VCC Voltage"
    internal: true
    accuracy_decimals: 3
    filters:
      - multiply: 4.2
    unit_of_measurement: 'V'
    update_interval: 5s
    accuracy_decimals: 2
    lambda: |-
      return (id(a0_pin).state);
    unit_of_measurement: '%'
    update_interval: 5s
    accuracy_decimals: 0
    lambda: |-
      return ((id(a0_pin).state-3) /1.2 * 100.00);
  - platform: vl53l0x
    address: 0x29
    timeout: 200us
    enable_pin: D6
    update_interval: 1s
    unit_of_measurement: "m"
    #on_value:
    #  then:
    #    deep_sleep.enter: deep_sleep_control
deep_sleep:
  run_duration: 5s
  sleep_duration: 60s
Log:
[11:31:36][D][vl53l0x:307]: 'Regentonne Distance' - Got distance 0.051 m
[11:31:36][D][sensor:113]: 'Regentonne Distance': Sending state 0.05100 m with 2 decimals of accuracy
[11:31:37][I][deep_sleep:072]: Beginning Deep Sleep
[11:32:37][I][mqtt:214]: MQTT Connected!
[11:32:38][C][deep_sleep:017]: Setting up Deep Sleep...
[11:32:38][I][app:060]: setup() finished successfully!
[11:32:38][I][app:099]: ESPHome version 2021.10.1 compiled on Oct 22 2021, 11:01:19
[11:32:38][C][wifi:490]: WiFi:
[11:32:38][C][wifi:352]:   Local MAC: C4:5B:BE:54:B4:B1
[11:32:38][C][wifi:353]:   SSID: [redacted]
[11:32:38][C][wifi:354]:   IP Address: 192.168.1.217
[11:32:38][C][wifi:356]:   BSSID: [redacted]
[11:32:38][C][wifi:357]:   Hostname: 'regentonne'
[11:32:38][C][wifi:359]:   Signal strength: -53 dB ▂▄▆█
[11:32:38][C][wifi:363]:   Channel: 1
[11:32:38][C][wifi:364]:   Subnet: 255.255.255.0
[11:32:38][C][wifi:365]:   Gateway: 192.168.1.1
[11:32:38][C][wifi:366]:   DNS1: 192.168.1.50
[11:32:38][C][wifi:367]:   DNS2: 192.168.1.100
[11:32:38][C][i2c.arduino:032]: I2C Bus:
[11:32:38][C][i2c.arduino:033]:   SDA Pin: GPIO0
[11:32:38][C][i2c.arduino:034]:   SCL Pin: GPIO4
[11:32:38][C][i2c.arduino:035]:   Frequency: 50000 Hz
[11:32:38][C][i2c.arduino:038]:   Recovery: bus successfully recovered
[11:32:38][I][i2c.arduino:048]: Scanning i2c bus for active devices...
[11:32:38][I][i2c.arduino:053]: Found i2c device at address 0x29
[11:32:38][C][template.sensor:023]: Template Sensor 'Regentonne_Battery_Voltage'
[11:32:38][C][template.sensor:023]:   State Class: ''
[11:32:38][C][template.sensor:023]:   Unit of Measurement: 'V'
[11:32:38][C][template.sensor:023]:   Accuracy Decimals: 2
[11:32:38][C][template.sensor:024]:   Update Interval: 5.0s
[11:32:38][C][template.sensor:023]: Template Sensor 'Regentonne_Battery_Percentage'
[11:32:38][C][template.sensor:023]:   Unit of Measurement: '%'
[11:32:38][C][template.sensor:023]:   Accuracy Decimals: 0
[11:32:38][C][logger:233]: Logger:
[11:32:38][C][logger:234]:   Level: DEBUG
[11:32:38][C][logger:235]:   Log Baud Rate: 115200
[11:32:38][C][logger:236]:   Hardware UART: UART0
[11:32:38][C][adc:077]: ADC Sensor 'Regentonne VCC Voltage'
[11:32:38][C][adc:077]:   Device Class: 'voltage'
[11:32:38][C][adc:077]:   State Class: 'measurement'
[11:32:38][C][adc:077]:   Unit of Measurement: 'V'
[11:32:38][C][adc:077]:   Accuracy Decimals: 3
[11:32:38][C][adc:082]:   Pin: GPIO17
[11:32:38][C][adc:104]:   Update Interval: 60.0s
[11:32:38][C][vl53l0x:024]: VL53L0X 'Regentonne Distance'
[11:32:38][C][vl53l0x:024]:   State Class: 'measurement'
[11:32:38][C][vl53l0x:024]:   Unit of Measurement: 'm'
[11:32:38][C][vl53l0x:024]:   Accuracy Decimals: 2
[11:32:38][C][vl53l0x:024]:   Icon: 'mdi:arrow-expand-vertical'
[11:32:38][C][vl53l0x:025]:   Update Interval: 1.0s
[11:32:38][C][vl53l0x:026]:   Address: 0x29
[11:32:38][C][vl53l0x:028]:   Enable Pin: GPIO12
[11:32:38][C][vl53l0x:030]:   Timeout: 200us
[11:32:38][C][captive_portal:150]: Captive Portal:
[11:32:38][C][ota:082]: Over-The-Air Updates:
[11:32:38][C][ota:083]:   Address: regentonne.local:8266
[11:32:38][C][ota:086]:   Using Password.
[11:32:38][C][mqtt:063]: MQTT:
[11:32:38][C][mqtt:065]:   Server Address: 192.168.1.50:1883 (192.168.1.50)
[11:32:38][C][mqtt:066]:   Username: [redacted]
[11:32:38][C][mqtt:067]:   Client ID: [redacted]
[11:32:38][C][mqtt:069]:   Discovery prefix: 'homeassistant'
[11:32:38][C][mqtt:070]:   Discovery retain: YES
[11:32:38][C][mqtt:072]:   Topic Prefix: 'regentonne'
[11:32:38][C][mqtt:074]:   Log Topic: 'regentonne/debug'
[11:32:38][C][mqtt:584]: MQTT Message Trigger:
[11:32:38][C][mqtt:585]:   Topic: 'esp/ota_mode'
[11:32:38][C][mqtt:586]:   QoS: 0
[11:32:38][C][mqtt.sensor:025]: MQTT Sensor 'Regentonne_Battery_Voltage':
[11:32:38][C][mqtt.sensor:029]:   State Topic: 'regentonne/sensor/regentonne_battery_voltage/state'
[11:32:38][D][vl53l0x:307]: 'Regentonne Distance' - Got distance 0.051 m
[11:32:38][D][sensor:113]: 'Regentonne Distance': Sending state 0.05100 m with 2 decimals of accuracy
[11:32:38][C][mqtt.sensor:025]: MQTT Sensor 'Regentonne_Battery_Percentage':
[11:32:38][C][mqtt.sensor:029]:   State Topic: 'regentonne/sensor/regentonne_battery_percentage/state'
[11:32:38][C][mqtt.sensor:025]: MQTT Sensor 'Regentonne Distance':
[11:32:38][C][mqtt.sensor:029]:   State Topic: 'regentonne/sensor/regentonne_distance/state'
[11:32:38][C][mqtt:585]:   Topic: 'esp/sleep_mode'
[11:32:38][C][deep_sleep:024]: Setting up Deep Sleep...
[11:32:38][C][deep_sleep:027]:   Sleep Duration: 60000 ms
[11:32:38][C][deep_sleep:030]:   Run Duration: 5000 ms
[11:32:39][D][vl53l0x:307]: 'Regentonne Distance' - Got distance 0.050 m
[11:32:39][D][sensor:113]: 'Regentonne Distance': Sending state 0.05000 m with 2 decimals of accuracy
[11:32:40][D][vl53l0x:307]: 'Regentonne Distance' - Got distance 0.051 m
[11:32:40][D][sensor:113]: 'Regentonne Distance': Sending state 0.05100 m with 2 decimals of accuracy
[11:32:41][D][sensor:113]: 'Regentonne_Battery_Voltage': Sending state 4.08926 V with 2 decimals of accuracy
[11:32:41][D][vl53l0x:307]: 'Regentonne Distance' - Got distance 0.051 m
[11:32:41][D][sensor:113]: 'Regentonne Distance': Sending state 0.05100 m with 2 decimals of accuracy
[11:32:41][D][sensor:113]: 'Regentonne_Battery_Percentage': Sending state 90.77148 % with 0 decimals of accuracy
[11:32:42][D][vl53l0x:307]: 'Regentonne Distance' - Got distance 0.050 m
[11:32:42][D][sensor:113]: 'Regentonne Distance': Sending state 0.05000 m with 2 decimals of accuracy
[11:32:43][D][vl53l0x:307]: 'Regentonne Distance' - Got distance 0.049 m
[11:32:43][D][sensor:113]: 'Regentonne Distance': Sending state 0.04900 m with 2 decimals of accuracy
[11:32:44][D][vl53l0x:307]: 'Regentonne Distance' - Got distance 0.049 m
[11:32:44][D][sensor:113]: 'Regentonne Distance': Sending state 0.04900 m with 2 decimals of accuracy
[11:32:45][D][vl53l0x:307]: 'Regentonne Distance' - Got distance 0.049 m
[11:32:45][D][sensor:113]: 'Regentonne Distance': Sending state 0.04900 m with 2 decimals of accuracy
[11:32:46][D][sensor:113]: 'Regentonne_Battery_Voltage': Sending state 4.08926 V with 2 decimals of accuracy
[11:32:46][D][vl53l0x:307]: 'Regentonne Distance' - Got distance 0.051 m
[11:32:46][D][sensor:113]: 'Regentonne Distance': Sending state 0.05100 m with 2 decimals of accuracy
[11:32:46][D][sensor:113]: 'Regentonne_Battery_Percentage': Sending state 90.77148 % with 0 decimals of accuracy
[11:32:47][D][vl53l0x:307]: 'Regentonne Distance' - Got distance 0.048 m
[11:32:47][D][sensor:113]: 'Regentonne Distance': Sending state 0.04800 m with 2 decimals of accuracy
[11:32:48][D][vl53l0x:307]: 'Regentonne Distance' - Got distance 0.051 m
[11:32:48][D][sensor:113]: 'Regentonne Distance': Sending state 0.05100 m with 2 decimals of accuracy
[11:32:49][D][vl53l0x:307]: 'Regentonne Distance' - Got distance 0.050 m
[11:32:49][D][sensor:113]: 'Regentonne Distance': Sending state 0.05000 m with 2 decimals of accuracy
[11:32:50][D][vl53l0x:307]: 'Regentonne Distance' - Got distance 0.050 m
[11:32:50][D][sensor:113]: 'Regentonne Distance': Sending state 0.05000 m with 2 decimals of accuracy
[11:32:51][D][sensor:113]: 'Regentonne_Battery_Voltage': Sending state 4.08926 V with 2 decimals of accuracy
[11:32:51][D][vl53l0x:307]: 'Regentonne Distance' - Got distance 0.050 m
[11:32:51][D][sensor:113]: 'Regentonne Distance': Sending state 0.05000 m with 2 decimals of accuracy
[11:32:51][D][sensor:113]: 'Regentonne_Battery_Percentage': Sending state 90.77148 % with 0 decimals of accuracy
[11:32:52][D][vl53l0x:307]: 'Regentonne Distance' - Got distance 0.049 m
[11:32:52][D][sensor:113]: 'Regentonne Distance': Sending state 0.04900 m with 2 decimals of accuracy
[11:32:53][D][vl53l0x:307]: 'Regentonne Distance' - Got distance 0.050 m
[11:32:53][D][sensor:113]: 'Regentonne Distance': Sending state 0.05000 m with 2 decimals of accuracy
[11:32:54][D][vl53l0x:307]: 'Regentonne Distance' - Got distance 0.048 m
[11:32:54][D][sensor:113]: 'Regentonne Distance': Sending state 0.04800 m with 2 decimals of accuracy
[11:32:55][D][vl53l0x:307]: 'Regentonne Distance' - Got distance 0.050 m
[11:32:55][D][sensor:113]: 'Regentonne Distance': Sending state 0.05000 m with 2 decimals of accuracy
[11:32:56][D][sensor:113]: 'Regentonne_Battery_Voltage': Sending state 4.08926 V with 2 decimals of accuracy
[11:32:56][D][vl53l0x:307]: 'Regentonne Distance' - Got distance 0.049 m
[11:32:56][D][sensor:113]: 'Regentonne Distance': Sending state 0.04900 m with 2 decimals of accuracy
[11:32:56][D][sensor:113]: 'Regentonne_Battery_Percentage': Sending state 90.77148 % with 0 decimals of accuracy
[11:32:57][D][vl53l0x:307]: 'Regentonne Distance' - Got distance 0.049 m
[11:32:57][D][sensor:113]: 'Regentonne Distance': Sending state 0.04900 m with 2 decimals of accuracy
[11:32:58][D][vl53l0x:307]: 'Regentonne Distance' - Got distance 0.051 m
EDIT: Now that I reread your post, it looks like you accomplished the same by RST/D0 as the traces look like they go to the sleep pads
If I remember correctly when I created my temperature sensor, I had to bridge the “sleep” pads on the back of the board to get deep sleep to work.
I used this for the settings:
deep_sleep:
  run_duration: 15s
  sleep_duration: 4.85min
I dont have this pins:
But by the way, it work if I do it over mqtt…
Problem is solved. It was missing retain flag on OFF message ;(
