zamb
October 12, 2020, 10:50am
1
I’m trying to get the RPM from a CPU fan.
I don’t know if I’m at the right spot, while using: platform: pulse_width
Part of my config looks like this:
substitutions:
hostid: fireplace_fan
hostname: Fireplace Fan
comment: Fireplace fan controller
node_platform: ESP8266
node_board: d1_mini
packages:
core: !include common/core.yaml
basic_sensors: !include common/basic_sensors.yaml
esphome:
on_boot:
then:
- fan.turn_on:
speed: low
- platform: pulse_width
pin: D2
update_interval: 15s
fan:
- platform: speed
output: ${hostid}_fan_speed
output:
- platform: esp8266_pwm
pin: D3
frequency: 25000 Hz
Log shows:
[D][sensor:092]: 'Fireplace Fan Speed': Sending state 0.00000 s with 3 decimals of accuracy
I have D2 connected directly to the sensor pin at the CPU fan (the Wemos D1 mini uses common gound with the fan).
Am I missing something here?
tom_l
October 12, 2020, 11:52am
2
Most CPU fan sensors are open drain / open collector . So you need a pull up resistor to convert the pulsed connections to ground to a voltage that the ESP can detect. Try:
pin:
number: D2
mode: INPUT_PULLUP
You probably also want the pulse counter not pulse width, and you may have to scale the result to get RPM.
e.g. Noctua fans output 2 pulses per rotation. Thus if using one of their fans you would need this to get RPM:
- platform: pulse_counter
pin:
number: D2
mode: INPUT_PULLUP
unit_of_measurement: 'RPM'
filters:
- multiply: 0.5
zamb
October 12, 2020, 12:21pm
3
Thanks!
For test I’m unsung an intel stock fan. But the real application will use a noctua fan from their industri-series (powerful but more noisy).
But the resistor, I guess it’s not just a yaml change. I need a physical resistor also? What value and how to connect?..
zamb
October 12, 2020, 1:16pm
4
Just tried without any additional hardware, It seems to be working… I’ll try to verify the speed…
tom_l
October 12, 2020, 3:29pm
5
Yes it is just a yaml change, as per my post above. The software enabled internal resistor will be fine for this application.
