Wemos D1 mini with DHT22 sensor
Hello I am using a Wemos D1 mini with DHT22 sensor in HA.
I use this code: but after the sleep timer the wemos crashes and i have to reset the wemos.
Also tried other sketches but they work not satisfying.
I want to have a simple code that checks every 10 minutes the temp and hum and publishes to the MQTT topic
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include "DHT.h"
#include <ArduinoJson.h>
#define MQTT_VERSION MQTT_VERSION_3_1_1
// Wifi: SSID and password
const char* WIFI_SSID = "[Redacted]";
const char* WIFI_PASSWORD = "[Redacted]";
// MQTT: ID, server IP, port, username and password
const PROGMEM char* MQTT_CLIENT_ID = "office_dht22";
const PROGMEM char* MQTT_SERVER_IP = "[Redacted]";
const PROGMEM uint16_t MQTT_SERVER_PORT = 1883;
const PROGMEM char* MQTT_USER = "[Redacted]";
const PROGMEM char* MQTT_PASSWORD = "[Redacted]";
// MQTT: topic
const PROGMEM char* MQTT_SENSOR_TOPIC = "office/sensor1";
// sleeping time
const PROGMEM uint16_t SLEEPING_TIME_IN_SECONDS = 600; // 10 minutes x 60 seconds
// DHT - D1/GPIO5
#define DHTPIN 5
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
WiFiClient wifiClient;
PubSubClient client(wifiClient);
// function called to publish the temperature and the humidity
void publishData(float p_temperature, float p_humidity) {
  // create a JSON object
  // doc : https://github.com/bblanchon/ArduinoJson/wiki/API%20Reference
  StaticJsonBuffer<200> jsonBuffer;
  JsonObject& root = jsonBuffer.createObject();
  // INFO: the data must be converted into a string; a problem occurs when using floats...
  root["temperature"] = (String)p_temperature;
  root["humidity"] = (String)p_humidity;
  root.prettyPrintTo(Serial);
  Serial.println("");
        "temperature": "23.20" ,
        "humidity": "43.70"
  char data[200];
  root.printTo(data, root.measureLength() + 1);
  client.publish(MQTT_SENSOR_TOPIC, data, true);
  yield();
// function called when a MQTT message arrived
void callback(char* p_topic, byte* p_payload, unsigned int p_length) {
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.println("INFO: Attempting MQTT connection...");
    // Attempt to connect
    if (client.connect(MQTT_CLIENT_ID, MQTT_USER, MQTT_PASSWORD)) {
      Serial.println("INFO: connected");
    } else {
      Serial.print("ERROR: failed, rc=");
      Serial.print(client.state());
      Serial.println("DEBUG: try again in 5 seconds");
      // Wait 5 seconds before retrying
      delay(5000);
void setup() {
  // init the serial
  Serial.begin(115200);
  dht.begin();
  // init the WiFi connection
  Serial.println();
  Serial.println();
  Serial.print("INFO: Connecting to ");
  WiFi.mode(WIFI_STA);
  Serial.println(WIFI_SSID);
  WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.println("INFO: WiFi connected");
  Serial.println("INFO: IP address: ");
  Serial.println(WiFi.localIP());
  // init the MQTT connection
  client.setServer(MQTT_SERVER_IP, MQTT_SERVER_PORT);
  client.setCallback(callback);
void loop() {
  if (!client.connected()) {
    reconnect();
  client.loop();
  // Reading temperature or humidity takes about 250 milliseconds!
  // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
  float h = dht.readHumidity();
  // Read temperature as Celsius (the default)
  float t = dht.readTemperature();
  if (isnan(h) || isnan(t)) {
    Serial.println("ERROR: Failed to read from DHT sensor!");
    return;
  } else {
    //Serial.println(h);
    //Serial.println(t);
    publishData(t, h);
  Serial.println("INFO: Closing the MQTT connection");
  client.disconnect();
  Serial.println("INFO: Closing the Wifi connection");
  WiFi.disconnect();
  ESP.deepSleep(SLEEPING_TIME_IN_SECONDS * 1000000, WAKE_RF_DEFAULT);
  delay(500); // wait for deep sleep to happen
It looks like you close the wifi connection at the end of the loop, before the sleep, but don’t don’t start it up again when the loop function is called again, which (I think) will cause the mqtt client code to fail.
Hi thanks for your reply.
I removed the disconnections rules.
But the code still crashes on the wemos.
When i reboot it, it read once the sensor, after the timer i got one rule “rubbish” on the serial output and i have to reset the board again
you are using deep sleep in your sketch. did you physically connect RST and GPIO16 on you device to enable the wake up from deep sleep?
Hi Thanks for reply,
I dont have make any connections on the board, exeption the sensor.
Maybe i don’t need the “deep sleep” i only want every 10 minutes a temp/hum reading.
I found this sketch online (i am beginning at arduino)
I think you would only need the deep sleep if you were using battery power. If you are not, I think a simple delay would do the job.
Edit:
Or maybe sleep() would be better for times as long as 10 minutes.:thinking:
Hi Thanks for the suggestions.
I removed the deep sleep and added a delay for 10 minutes.
Looks working now. :slight_smile:
Do i forget something?
#include "DHT.h"
const char* WIFI_SSID = "[redacted]";
const char* WIFI_PASSWORD = "[redacted]";
const PROGMEM char* MQTT_SERVER_IP = "[redacted]";
const PROGMEM char* MQTT_USER = "[redacted]";
const PROGMEM char* MQTT_PASSWORD = "[redacted]";
// MQTT: topic
#define DHTPIN D3
  Serial.println("");
    "humidity": "43.70"
  char data[200];
  yield();
void reconnect() {
} else {
  delay(5000);
void setup() {
  // init the serial
  dht.begin();
  Serial.println();
  Serial.println();
delay(500);
Serial.print(".");
  Serial.println("");
void loop() {
reconnect();
  client.loop();
return;
  } else {
publishData(t, h);
 delay(600000);
Hello
Have a look at the custom Firmware called Tasmota for the Wemos D1 Mini. It does exactly the things you need (and much more). Setup is very easy (even through Web Interface) and MQTT works great. Also provides drivers for many sensors.
