Wemos D1 with Grow R503 stops responding
I have the following setup:
  • Wemos D1 Mini
  • 0.98 TFT display
  • R503 Fingerprint reader (brown wire)
I am using this device to disarm the alarm system and to see the lock status. It worked earlier with Dfrobot’s reader, but the aura control was not working completely with it.
This combination works in the beginning, but quite soon the device becomes unresponsive. I cannot see the web portal nor I can connect to see the logs. The aura keeps breathing.
I have also tried to use ESP32 WROOM, but it had the same problems. I have also tried to use different pins, but since the display uses D1 and D2, to my understanding D5, D6 and D7 are the only usable ones.
Any ideas?
esphome:
  friendly_name: fprint
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
globals:
  - id: fp_status
    type: int
    restore_value: yes
    initial_value: "0"
    # 0: Ready
    # 1: Recognized
    # 2: Unknown
    # 3: Enrollment scan
    # 4: Enrollment finished
    # 5: Enrollment error
  - id: fp_id
    type: int
  - id: fp_scan
    type: int
ota:
  password: "(highly secret)"
wifi:
  ssid: !secret wifi_ssid
  manual_ip:
    static_ip: 192.168.0.110
    gateway: 192.168.0.1
    subnet: 255.255.255.0
    dns1: 192.168.0.1
  ap:
    ssid: "Fprint Fallback Hotspot"
    password: "(verysecret)"
web_server:
  port: 80
captive_portal:
uart:
  rx_pin: GPIO16
  tx_pin: GPIO17
  baud_rate: 57600
i2c:
  sda: GPIO21
  scl: GPIO22
  # frequency: 800kHz
font:
  - file: "gfonts://Roboto"
  - file: 'fonts/materialdesignicons-webfont.ttf'
    glyphs:
      - "\U000F0FC6" # lock open
      - "\U000F033E" # lock closed
      - "\U000F012C" # check
      - "\U000F0028" # error
      - "\U000F0237" # fingerprint
display:
  - platform: ssd1306_i2c
    model: "SSD1306 128x64"
    flip_x: false
    flip_y: false
    lambda: |-
      switch (id(fp_status)) {
        case 0:
          it.print(0, 0, id(roboto), "Ready");
          if (id(alarm_enabled).state) {
            it.print(0, 35, id(roboto), "ARMED");
          } else {
            it.print(0, 35, id(roboto), "DISARMED");
          if (strcmp(id(door_locked).state.c_str(), "locked")) {
            it.print(90, 0, id(icon_font), TextAlign::TOP_LEFT, "\U000F0FC6");
          } else {
            it.print(90, 0, id(icon_font), TextAlign::TOP_LEFT, "\U000F033E");
          break;
        case 1:
          it.print(0, 0, id(roboto), "Welcome");
          it.print(90, 0, id(icon_font), TextAlign::TOP_LEFT, "\U000F012C");
          it.print(0, 35, id(roboto), "Ville");
          break;
        case 2:
          it.print(0, 0, id(roboto), "Go away");
          it.print(90, 0, id(icon_font), TextAlign::TOP_LEFT, "\U000F0028");
          it.print(0, 35, id(roboto), "Stranger");
          break;
        case 3:
          it.print(0, 0, id(roboto), "Enroll");
          it.printf(0, 35, id(roboto), "Round %d", id(fp_scan));
          it.print(90, 0, id(icon_font), TextAlign::TOP_LEFT, "\U000F0237");
          break;
        case 4:
          it.print(0, 35, id(roboto), "Finished");
          break;
        case 5:
          it.print(0, 35, id(roboto), "Failed");
          break;
fingerprint_grow:
  sensing_pin: GPIO4
  on_finger_scan_start:
    - fingerprint_grow.aura_led_control:
        state: BREATHING
        speed: 200
        color: BLUE
        count: 0
  on_finger_scan_matched:
        state: FLASHING
        speed: 50
        color: GREEN
        count: 4
    - homeassistant.event:
        event: esphome.fpdoor_finger_scan_matched
          finger_id: !lambda 'return finger_id;'
          confidence: !lambda 'return confidence;'
    - lambda: id(fp_status) = 1;
    - lambda: id(fp_id) = finger_id;
    - homeassistant.service:
        service: input_boolean.turn_off
          entity_id: input_boolean.alarm_enabled
    - delay: 1000 ms
    - lambda: id(fp_status) = 0;
        state: BREATHING
        speed: 200
        color: BLUE
        count: 0
  on_finger_scan_unmatched:
        state: FLASHING
        speed: 25
        color: RED
        count: 4
    - lambda: id(fp_status) = 2;
        event: esphome.fpdoor_finger_scan_unmatched
    - delay: 1000 ms
        state: BREATHING
        speed: 200
        color: BLUE
        count: 0
  on_enrollment_scan:
    - lambda: id(fp_status) = 3;
    - lambda: id(fp_scan) = scan_num;
        event: esphome.fpdoor_enrollment_scan
          scan_num: !lambda 'return scan_num;'
  on_enrollment_done:
    - lambda: id(fp_status) = 4;
        event: esphome.fpdoor_enrollment_done
    - delay: 2000 ms
  on_enrollment_failed:
    - lambda: id(fp_status) = 5;
        event: esphome.fpdoor_enrollment_failed
    - delay: 2000 ms
  - platform: fingerprint_grow
    status:
    last_finger_id:
      name: "Last fingerprint"
    last_confidence:
      name: "Last confidence"
text_sensor:
  - platform: homeassistant
    entity_id: saver.saver
    attribute: variables
    entity_id: input_text.fingerprint_learning_name
    entity_id: lock.lock_frontyard
binary_sensor:
# Enable Home Assistant API
api:
  encryption:
    key: "(evenmoresecret)"
  services:
  - service: enroll
    variables:
      finger_id: int
      num_scans: int
    then:
      - fingerprint_grow.enroll:
          num_scans: !lambda 'return num_scans;'
  - service: cancel_enroll
    then:
      - fingerprint_grow.cancel_enroll:
  - service: delete
    variables:
      finger_id: int
    then:
      - fingerprint_grow.delete:
  - service: delete_all
    then:
      - fingerprint_grow.delete_all:
I have the same issue…
Anyone having R503 with brown wire working?
Have you found any solution?
ESPHome update helped
