WEMOS s2 Mini - Battery tracking ADC problem - fix value
Hello!
I got two Wemos s2 mini, and now I am creating a multiple Moisture sensor for the garden powered by two 18650 bateries (4.2v max) in parallel which are rechargables by a mini Solar Panel. I followed this tutorial https://randomnerdtutorials.com/power-esp32-esp8266-solar-panels-battery-level-monitoring/ with all the same components.
In the pin 2,3 and 4 I have the three moisture sensor which works as I expected, in the pin 1 (adc1) I connected by following the tutorial the same pin from the circuit including two resistors 27k and 100kohm. If I measure the wire with my multitester when is full charge corresponds to 3.2v and when is discharged is around 2.38v.
While I am using the device I can see the battery is discharging, having for example 3.8v, and the wire conencted to the pin 1 around 2.91v. The problem is then in ESPHOME readings, always I have a fix value of 2.62733v. I tried to change the GPIO pins and same error. WIth the moisture sensor no problem.
My yaml config is:
substitutions:
  display_name: garden
  update_fq: 120s
  battery_full: '3.20'
  battery_empty: '2.382'
  battery_diff: ${battery_full}-${battery_empty}
  dry01: '2.10859' #1.44
  wet01: '0.68' # 0.64
  dry02: '2.12758'
  wet02: '0.734'
  dry03: '2.084'
  wet03: '0.537'
  #ivolt: '1' #'3.32
  utime: '120' #se
esphome:
  friendly_name: wemos-s2-01
# esp32:
#   board: lolin_s2_mini
#   framework:
#     type: arduino
esp32:
  variant: esp32s2
  framework:
    type: arduino
    # version: 2.0.3
    # platform_version: 4.4.0
#MOISTURE SENSOR
  - platform: adc
    pin: GPIO2
    attenuation: auto
    name: "Soil Moisture W01"
    unit_of_measurement: "%"
    device_class: humidity
    icon: "mdi:watering-can"
    filters:
      - calibrate_linear:
         - ${dry01} -> 0.00
         - ${wet01} -> 100.00
      - lambda: |
         if (x < 0) return 0;
         else if (x > 100) return 100;
         else return (x);
    update_interval: ${utime}s
    accuracy_decimals: 1
  - platform: adc
    pin: GPIO2
    attenuation: auto
    name: "Soil Voltage  W01"
    unit_of_measurement: "V"
    device_class: voltage
    accuracy_decimals: 2
#Battery tracking
  - platform: adc
    pin: GPIO1
    attenuation: auto
    name: '${display_name} Battery Voltage'
    update_interval: ${update_fq}
  - platform: adc
    pin: GPIO1
    name: '${display_name} Battery charge'
    attenuation: auto #11db
    unit_of_measurement: '%'
    filters:
      - calibrate_linear:
         - ${battery_empty} -> 0.00
         - ${battery_full} -> 100.00
      - lambda: |
         else return (x);
As example I just wrote one moisture sensor, also, you can see I tried to define different boards.
What I am doing wrong?
Thank you!
Looks like A0 is now measuring the output from TP4056, since the 27k resistor is connected to OUT+.
2.62733V * (100k + 27k) / 100k = 3.3367V (at OUT+ pin)
Maybe you could try connecting the resistor to the battery itself. But it could be a hazard if the battery voltage is too low.
