If it ever helps, mother of all scripts to work out a whole pile of ‘special days’ in the year. It sets two (must be pre-setup) helpers after it’s run: input_text.special_day_text (name of the special day) and input_boolean.special_day (on if it is a special day, off if it isn’t)…
It’s not built for speed, it’s built to be easy to read and hack about with - I run it at 7am in the morning on a timed automation (just because that keeps the special day going until 7am the next day… which is generally what you want - but if you were being precise about it you’d run it at midnight every day…)
alias: Is It A Special Day
sequence:
- variables:
special_text: |-
{# Output is text string that fits with phrase 'today is...'
# or the string 'unknown'
{# Nth weekday in a month #}
{%- macro x_weekday_in_month(o,d,m,y) -%}
{%- set f = as_local(as_datetime('%04d-%02d-01T00:00:00'%(y,m))) -%}
{{- f + timedelta(days = (7 - f.isoweekday() + d if d < f.isoweekday()
else d - f.isoweekday()) + 7*(o-1)) -}}
{%- endmacro -%}
{# Last Nth weekday in a month #}
{%- macro x_last_in_month(o,d,m,y) -%}
{%- set l = as_local(as_datetime('%04d-%02d-01T00:00:00'%(y,(m+1)))) -
timedelta(days=1) -%}
{{- l - timedelta(days = (l.isoweekday() - d if d <= l.isoweekday()
else 7 - d + l.isoweekday()) + 7*(o-1)) -}}
{%- endmacro -%}
{# Nth weekday after a date #}
{%- macro x_weekday_after(o,d,t,m,y) -%}
{%- set f = as_local(as_datetime('%04d-%02d-%02dT00:00:00'%(y,m,t))) -%}
{%- endmacro -%}
{# Nth weekday before a date #}
{%- macro x_weekday_before(o,d,t,m,y) -%}
{%- set l = as_local(as_datetime('%04d-%02d-%02dT00:00:00'%(y,m,t))) -%}
{%- endmacro -%}
{# Mangle now() into midnight with timezone #}
{%- set cur_date = now() -%}
{%- set cur_year = cur_date.year -%}
{%- set cur_month = cur_date.month -%}
{%- set cur_day = cur_date.day -%}
{%- set cur_date =
as_local(as_datetime('%04d-%02d-%02dT00:00:00'%(cur_year,cur_month,cur_day)))
{# Set default output text #}
{%- set output_text = "unknown" -%}
{%- if cur_month == 1 -%}
{%- set new_years_day = as_local(as_datetime('%04d-01-01T00:00:00'%(cur_year))) -%}
{%- set ninth_night = as_local(new_years_day + timedelta(days = 1)) -%}
{%- set tenth_night = as_local(new_years_day + timedelta(days = 2)) -%}
{%- set eleventh_night = as_local(new_years_day + timedelta(days = 3)) -%}
{%- set twelfth_night = as_local(new_years_day + timedelta(days = 4)) -%}
{%- set epiphany = as_local(new_years_day + timedelta(days = 5)) -%}
{%- set burns_night = as_local(as_datetime('%04d-01-25T00:00:00'%(cur_year))) -%}
{%- if cur_date == new_years_day -%}
{%- set output_text = "New Year's Day" -%}
{%- elif cur_date == ninth_night -%}
{%- set output_text = "Ninth Night" -%}
{%- elif cur_date == tenth_night -%}
{%- set output_text = "Tenth Night" -%}
{%- elif cur_date == eleventh_night -%}
{%- set output_text = "Eleventh Night" -%}
{%- elif cur_date == twelfth_night -%}
{%- set output_text = "Twelfth Night" -%}
{%- elif cur_date == epiphany -%}
{%- set output_text = "Epiphany" -%}
{%- elif cur_date == burns_night -%}
{%- set output_text = "Burns Night" -%}
{%- endif -%}
{# Start looking for interesting dates... Easter is somewhere in here #}
{%- elif cur_month > 1 and cur_month < 6 -%}
{#- Easter - based on a calculated date -#}
{%- set Y = cur_year -%}
{%- set G = Y % 19 + 1 -%}
{%- set C = (Y / 100) | int + 1 -%}
{%- set X = (3*C / 4) | int - 12 -%}
{%- set Z = ((8*C + 5) / 25) | int - 5 -%}
{%- set D = (5*Y / 4)| int - X - 10 -%}
{%- set E = (11*G + 20 + Z - X ) % 30 -%}
{%- set E = E+1 if (E == 25 and G > 11 or E == 24) else E -%}
{%- set N = 44 - E -%}
{%- set N = N+30 if N < 21 else N -%}
{%- set N = N + 7 - (( D + N ) % 7) -%}
{%- set M = 4 if N > 31 else 3 -%}
{%- set N = N-31 if N > 31 else N -%}
{%- set easter = as_local(as_datetime('%04d-%02d-%02dT00:00:00'%(Y,M,N))) -%}
{# Calculate all the interesting days in Easter - easier to see if done in one go #}
{%- set shrove_monday = as_local(easter - timedelta(days=48)) -%}
{%- set shrove_tuesday = as_local(easter - timedelta(days=47)) -%}
{%- set ash_wednesday = as_local(easter - timedelta(days=46)) -%}
{%- set mothering_sunday = as_local(easter - timedelta(days=21)) -%}
{%- set passion_sunday = as_local(easter - timedelta(days=14)) -%}
{%- set palm_sunday = as_local(easter - timedelta(days=7)) -%}
{%- set good_friday = as_local(easter - timedelta(days=2)) -%}
{%- set ascension = as_local(easter + timedelta(days=39)) -%}
{%- set ascension_sunday = as_local(easter + timedelta(days=42)) -%}
{%- set easter_monday = as_local(easter + timedelta(days=1)) -%}
{# Check all the dates relevant to Easter #}
{%- if cur_date >= shrove_monday and cur_date <= ascension_sunday -%}
{# Set default text #}
{%- if cur_date > ash_wednesday and cur_date < easter -%}
{%- set output_text = "Lent" -%}
{%- endif -%}
{%- if cur_date == shrove_monday -%}
{%- set output_text = "Shrove Monday" -%}
{%- elif cur_date == shrove_tuesday -%}
{%- set output_text = "Shrove Tuesday" -%}
{%- elif cur_date == ash_wednesday -%}
{%- set output_text = "Ash Wednesday" -%}
{%- elif cur_date == mothering_sunday -%}
{%- set output_text = "Mothering Sunday" -%}
{%- elif cur_date == passion_sunday -%}
{%- set output_text = "Passion Sunday" -%}
{%- elif cur_date == palm_sunday -%}
{%- set output_text = "Palm Sunday" -%}
{%- elif cur_date == good_friday -%}
{%- set output_text = "Good Friday" -%}
{%- elif cur_date == easter -%}
{%- set output_text = "Easter Day" -%}
{%- elif cur_date == ascension -%}
{%- set output_text = "Ascension Day" -%}
{%- elif cur_date == ascension_sunday -%}
{%- set output_text = "Ascension Sunday" -%}
{%- elif cur_date | string == easter_monday -%}
{%- set output_text = "Easter Monday" -%}
{%- endif -%}
{%- endif -%}
{# Other months in the first half of the year #}
{%- if cur_month == 2 -%}
{%- set candlemas = as_local(as_datetime('%04d-02-02T00:00:00'%(cur_year))) -%}
{%- set valentines_day = as_local(as_datetime('%04d-02-14T00:00:00'%(cur_year))) -%}
{%- if cur_date == candlemas -%}
{%- set output_text = "Candlemas" -%}
{%- elif cur_date == valentines_day -%}
{%- set output_text = "Valentines Day" -%}
{%- endif -%}
{%- elif cur_month == 3 -%}
{%- set clock_forward = x_last_in_month(1,7,3,cur_year) -%}
{%- set stpatricks_day = as_local(as_datetime('%04d-03-17T00:00:00'%(cur_year))) -%}
{%- if cur_date == clock_forward -%}
{%- set output_text = "the day the clocks move forwards one hour" -%}
{%- elif cur_date == stpatricks_day -%}
{%- set output_text = "Saint Patrick's Day" -%}
{%- endif -%}
{%- elif cur_month == 5 -%}
{%- set may_early_bank = x_weekday_in_month(1,1,5,cur_year) -%}
{%- set spring_bank = x_last_in_month(1,1,5,cur_year) -%}
{%- if cur_date == may_early_bank -%}
{%- set output_text = "the Early May Bank Holiday" -%}
{%- elif cur_date == spring_bank -%}
{%- set output_text = "the Spring Bank Holiday" -%}
{%- endif -%}
{%- endif -%}
{# Specific months in the second half of the year #}
{%- elif cur_month == 6 -%}
{%- set fathers_day = x_weekday_in_month(3,7,6,cur_year) -%}
{%- if cur_date == fathers_day -%}
{%- set output_text = "Fathers Day" -%}
{%- endif -%}
{%- elif cur_month == 7 -%}
{%- set st_swithins_day = as_local(as_datetime('%04d-07-15T00:00:00'%(cur_year))) -%}
{%- if cur_date == st_swithins_day -%}
{%- set output_text = "Saint Swithin's Day" -%}
{%- endif -%}
{%- elif cur_month == 8 -%}
{%- set summer_bank = x_last_in_month(1,1,8,cur_year) -%}
{%- if cur_date == summer_bank -%}
{%- set output_text = "the Summer Bank Holiday" -%}
{%- endif -%}
{%- elif cur_month == 9 -%}
{%- set michaelmas = as_local(as_datetime('%04d-09-29T00:00:00'%(cur_year))) -%}
{%- if cur_date == michaelmas -%}
{%- set output_text = "Michaelmas" -%}
{%- endif -%}
{%- elif cur_month == 10 -%}
{%- set clock_backward = x_last_in_month(1,7,10,cur_year) -%}
{%- set halloween = as_local(as_datetime('%04d-10-31T00:00:00'%(cur_year))) -%}
{%- if cur_date == clock_backward -%}
{%- set output_text = "the day the clocks move backwards one hour" -%}
{%- elif cur_date == halloween -%}
{%- set output_text = "Holloween" -%}
{%- endif -%}
{%- elif cur_month >= 11 -%}
{%- set all_saints_day = as_local(as_datetime('%04d-11-01T00:00:00'%(cur_year))) -%}
{%- set bonfire_night = as_local(as_datetime('%04d-11-05T00:00:00'%(cur_year))) -%}
{%- if cur_date == all_saints_day -%}
{%- set output_text = "All Saints' Day" -%}
{%- elif cur_date == bonfire_night -%}
{%- set output_text = "Guy Fawkes Night" -%}
{%- endif -%}
{# Advent can start 27 November #}
{#- Christmas based off a fixed date, but advent moves about -#}
{%- set christmas_day = as_local(as_datetime('%04d-12-25T00:00:00'%(cur_year))) -%}
{%- set first_advent = as_local(christmas_day - timedelta(days = 21 + (christmas_day.isoweekday()))) -%}
{%- set second_advent = as_local(first_advent + timedelta(days = 7)) -%}
{%- set third_advent = as_local(first_advent + timedelta(days = 14)) -%}
{%- set fourth_advent = as_local(first_advent + timedelta(days = 21)) -%}
{%- set christmas_eve = as_local(christmas_day - timedelta(days = 1)) -%}
{%- set boxing_day = as_local(christmas_day + timedelta(days = 1)) -%}
{%- set third_night = as_local(christmas_day + timedelta(days = 3)) -%}
{%- set fourth_night = as_local(christmas_day + timedelta(days = 4)) -%}
{%- set fifth_night = as_local(christmas_day + timedelta(days = 5)) -%}
{%- set sixth_night = as_local(christmas_day + timedelta(days = 6)) -%}
{%- set new_year_eve = as_local(as_datetime('%04d-12-31T00:00:00'%(cur_year))) -%}
{%- if cur_date >= first_advent and cur_date < christmas_eve -%}
{%- set output_text = "Advent" -%}
{%- endif -%}
{%- if cur_date == christmas_day -%}
{%- set output_text = "Christmas Day" -%}
{%- elif cur_date == first_advent -%}
{%- set output_text = "the First Advent Sunday" -%}
{%- elif cur_date == second_advent -%}
{%- set output_text = "the Second Advent Sunday" -%}
{%- elif cur_date == third_advent -%}
{%- set output_text = "the Third Advent Sunday" -%}
{%- elif cur_date == fourth_advent -%}
{%- set output_text = "the Fourth Advent Sunday" -%}
{%- elif cur_date == christmas_eve -%}
{%- set output_text = "Christmas Eve" -%}
{%- elif cur_date == boxing_day -%}
{%- set output_text = "Boxing Day" -%}
{%- elif cur_date == third_night -%}
{%- set output_text = "Third Night" -%}
{%- elif cur_date == fourth_night -%}
{%- set output_text = "Fourth Night" -%}
{%- elif cur_date == fifth_night -%}
{%- set output_text = "Fifth Night" -%}
{%- elif cur_date == sixth_night -%}
{%- set output_text = "Sixth Night" -%}
{%- elif cur_date == new_year_eve -%}
{%- set output_text = "New Year's Eve" -%}
{%- endif -%}
{%- else -%}
{# Not a special day... #}
{%- endif -%}
{# Do some funky Lunar stuff #}
{%- set lunar_text = "" -%}
{%- if (states('sensor.moon') == "new_moon") -%}
{%- if (cur_month == 1 and cur_day > 20) or
(cur_month == 2 and cur_day < 22) -%}
{%- set lunar_text = "Lunar and Chinese New Year's Eve" -%}
{%- else -%}
{%- set lunar_text = "a New Moon" -%}
{%- endif -%}
{%- elif (states('sensor.moon') == "full_moon") -%}
{%- set lunar_text = "a Full Moon" -%}
{%- endif -%}
{%- if lunar_text != "" -%}
{%- if output_text == "unknown" -%}
{%- set output_text = lunar_text -%}
{%- else -%}
{%- set output_text = output_text + " and " + lunar_text -%}
{%- endif -%}
{%- endif -%}
{{ output_text }}
- if:
- condition: template
value_template: "{{ special_text != \"unknown\" }}"
then:
- service: input_text.set_value
value: "{{ special_text }}"
entity_id: input_text.special_day_text
data: {}
entity_id: input_boolean.special_day
else:
value: unknown
- service: input_boolean.turn_off
data: {}
mode: queued
max: 10
