Probably something I’m missing and a very easy fix. Using hassio how do I get everything that is in homekit to show up in hassio. There are things I’d like to control that are in homekit that I would like to use. I have some VOCOlinc L2 bulbs that I’d like to do some automation with that I can’t do with homekit’s automation. Below is my configuration.yaml
According to the documentation for the HomeKit Controller integration, it will automatically detect your HomeKit accessories (assuming they and Home Assistant are on the same network).
For each detected HomeKit accessory, a configuration prompt will appear in the web front end. Use this to provide the HomeKit PIN. Note that HomeKit accessories can only be paired to one device at once. If your device is currently paired with Siri, you will need to reset it in order to pair it with Home Assistant. Once Home Assistant is configured to work with the device, you can export it back to Siri with the HomeKit integration.
Thanks. I guess i’m not able to do what I was wanting as the only time the device shows up in the integrations is when i’m in the process of pairing it to siri and at that point it’s too late.
I was having a hard time with these since it required homekit to connect it to the network, i finally figured out I could cancel the pairing after it got connected to the network and then pair in home assistant.
