What am i doing wrong in ESPHome (Sensor Conversions)
what am i doing wrong here,
  - platform: hx711
    name: "Scale A g"
    dout_pin: GPIO4
    clk_pin: GPIO5
    gain: 64
    update_interval: 1s
    filters:
      - calibrate_linear:
          - -10000 -> 0
          - -11567 -> 1000
    device_class: "weight"
    state_class: "measurement"
    unit_of_measurement: g
    icon: mdi:scale
    accuracy_decimals: 1
    internal: false
  - platform: hx711
    name: "Scale B g"
    dout_pin: GPIO12
    clk_pin: GPIO14
    gain: 64
    update_interval: 1s
    filters:
      - calibrate_linear:
          - -10000 -> 0
          - -11567 -> 1000
    icon: mdi:scale
    internal: false
    name: "Scale A kg"
    lambda: |-
      return id("SAR") / 1000.0;
    update_interval: 5s
    unit_of_measurement: kg
    icon: mdi:scale
    accuracy_decimals: 3
    internal: false
    name: "Scale B kg"
    lambda: |-
      return id("SBR") / 1000.0;
    update_interval: 5s
    icon: mdi:scale
    internal: false
the Scale A/B kg just show 83 (statically) , where as the Scale A/B g shows correctly and changes
no logs - no issue
As my signature says- I am no expert. But, where are “SAR” and “SBR” defined? Shouldn’t that be “SAg” and “SBg”?
 substitutions:
   device_name: -test
 esphome:
   friendly_name: ${device_name}
   #name_add_mac_suffix: true
 esp8266:
   board: esp01_1m
 # Enable logging
 logger:
 # Enable Home Assistant API
 api:
   encryption:
     key: "Key="
 ota:
   - platform: esphome
     password: "Key"
 wifi:
   ssid: !secret wifi_ssid
   ap:
     ssid: "Gas-Bottles"
     password: "vziYD1UCzCLT"
   - platform: uptime
   - platform: wifi_signal
     update_interval: 60s
   - platform: hx711
     name: "Scale A g"
     dout_pin: GPIO4
     clk_pin: GPIO5
     gain: 64
     update_interval: 1s
     filters:
       - calibrate_linear:
           - -10000 -> 0
           - -11567 -> 1
     icon: mdi:scale
     accuracy_decimals: 4
     #internal: true
   - platform: hx711
     name: "Scale B g"
     dout_pin: GPIO12
     clk_pin: GPIO14
     gain: 64
     update_interval: 1s
     filters:
       - calibrate_linear:
           - -10000 -> 0
           - -11567 -> 1
     icon: mdi:scale
     #internal: true
     name: "Scale A kg"
     lambda: |-
       return id("SAg") / 1000.00 ;
     update_interval: 5s
     icon: mdi:scale
     internal: false
     name: "Scale B kg"
     lambda: |-
       return id("SBg") /1000.00 ;
     update_interval: 5s
     icon: mdi:scale
     internal: false
 text_sensor:
   - platform: version
   - platform: wifi_info
     ip_address:
      icon: mdi:ip-network
 binary_sensor:
   - platform: status
 button:
   - platform: restart
 captive_portal:
 web_server:
   port: 80
so this is the full config, i did notice a couple of typos which have been fixed and it still does not play nicely.
the kg still isn’t showing correctly.
in terms of compilation errors there are none, but the return id(“SBg”) dosen’t appear to pull the g value.
You want:
    lambda: |-
      return id(SAg).state / 1000.0;
that gives me compilation errors.
/config/esphome/-test.yaml: In lambda function:
/config/esphome/-test.yaml:82:24: error: request for member 'state' in 'esphome::id<const char>(((const char*)"SAg"))', which is of non-class type 'const char'
   82 |       return id("SAg").state / 1000.00 ;
/config/esphome/-test.yaml:95:24: error: request for member 'state' in 'esphome::id<const char>(((const char*)"SBg"))', which is of non-class type 'const char'
   95 |       return id("SBg").state /1000.00 ;
*** [.pioenvs/-test/src/main.cpp.o] Error 1
========================= [FAILED] Took 10.56 seconds =========================
Look again at my code. No quotes around SAg.
Please format logs, code etc correctly using the </> button to avoid destroying quotes and indentation, like you did in your original post.
Thank you, I’m sure i’d tried that last night though it was very late
Go back and edit your post with code tags. We can’t read your configuration until you do.
