What are these lines in core logs?
Hello,I just upgraded to the Home Assistant 2022.04 and started notice these white lines in core logs as per attached image.
Never noticed these before and I don’t understand what are they for.
Also noticed a constant increment on the ram used,it’s a small increment but quite constant.
I’m running Home Assistant Supervised on a Raspberry Pi4.
Is anybody reporting the same weird thing?
Thanks in advance for any suggestion on it.
Regards.
Basically add the -s or --silent option to your curl commands to supress them.
Thank you,it shoud be this!
