Hi , i have recently done alot of research and found out that these 3 brand might work in my country which is Malaysia. So would like to get any advice from you guys . What are your thoughs on my floorplan.
Choosen Brand & Some Devices:
- Aqara Xiaomi (Switches,Sensors Door@Motion)
- TUYA (Climate Sensors,IR Universal)
- Sonoff (Meter monitoring [Aircondition] )
*Raspberry Pi 4
*HUSBZB-1 (Support Zigbee & Zwave)
Things I should achieve:
- Make a local HUB
- Command / Automation can be done without internet connection
- Not using the brand cloud/Hub , Basically Respberry Pi and HA will be the HUB with HUSHBZB-1 for the Zigbee and Zwave
Side note: This is at my work office And below are my current Scene Set that i could think of:
SCENE SET
- Global Scene:
- When anyone enter the office , all the lights will be turned on
- When everyone is not in the office , all the devices will be turned off after timer ends
- Office Scene:
- When someone enter the office , light will be turned on
- When every leave the office , Aircondition and lights will be turned off
- Temperature & Humidity Sensor will keep the office at minimum level
- DevOps Scene:
- When someone enter the DevOps room , light and aircondition will be turned on
- When there is no activity in the DevOps room , light and aircond will be turned off
- When a certain temperature reached aircondition temperature will be modified
Approximately cost: 1123.87 MYR / 277.53 USD
Maximum Cost: 2000MYR / 493.89USD
