What cause the component.http: Serving ....(auth: False)?
Hi!
My HA looks working fine on a raspberry (by manual installation in virtual environment).
However, every time when there is a web client connected, it shows the following:
INFO:homeassistant.components.http:Serving / to 192.168.x.x (auth: False)
INFO:homeassistant.components.http:Serving /api/websocket to 168.168.x.x (auth: False)
INFO:homeassistant.components.http:Serving /description.xml to 192.168.x.x (auth: False)
where 192.168.x.x is the IP address of the client machine.
If I enable the camera platform, there is one more message as shown below:
homeassistant.components.http: Serving /api/camera_proxy/camera.mycamera to 192.168.x.x (auth: False).
May I know if anybody has an idea on what’s wrong in my configuration?
Many thanks!
I believe the auth: false just means you haven’t set a password in your configuration.yaml file. Nothing wrong and if you don’t want or need a password just ignore it.
Thanks. But I do have the lines in my configuration.yaml:
http:
api_password: my password
and I have to use the password on the web client.
Same problem here.
I have my Dahua camera connected as a still image component, everything is working as expected.
But log file is displaying below error multiple times.
Serving /api/camera_proxy/camera.dahua_sd6c225uhni to 192.168.2.14 (auth: False)e[0m
The ip is from the HASS server not the Ip camera.
