What causing my home empty helper to delay?
My wife text me again at 4:41 PM tonight that she was home and the lights didnt turn on automatically. Now I found that in item #4, I forgot to include her entity ID in the entity field. But then with that said, I cant figure out what turned off the home empty helper then.
  1. So looking at her history, she was logged home at 4:41:
  2. But my home empty helper didnt turn off until 4:52:
  3. Here is the only flow that changes the home empty helper. Unfortunately, I have it set to output at connect so thats why it shows it being turned off at 19:51. But we know from seeing home empty helper above, that it also turned off at 4:52.
  4. Looking at my condition, I see that I forgot to include her entity ‘person.christina’ in the entity id field.
But then her entity was not in that field, did it not use that to turn off the home empty helper? As I said, I cant find a home empty condition anywhere else in node red.
Not an answer to the question but why not use a group?
Group the family and you will have home/not_home status.
If you then need a condition with guests then just add a guest device tracker that you control with device tucker see or just set the state.
I switched to group. Working well so far.
