So I had until now without problem a automation running that was changing the rgb and brightness.
- service: light.turn_on
brightness: 255
rgb_color:
- '0'
- '255'
- '0'
entity_id: light.arbeitszimmer_tv_licht
But this does not work anymore. I wanted to debug and tried to setup the service in developer tools but only get strange error about
Fehler beim Aufrufen des Diensts light/turn_on. sequence item 0: expected str instance, Optional found
I am also unclear how to add the rob values there so I tried the color name thing and got the same error.
So changed something with the service? Can someone give a sample how it works for him?
