Tyfoon
(@Tyfoon)
1
My theme (a variation of Noctis) has some transparency in it. However in some cases this is not desirable. Like in the case below.
What in the theme definitions define the transparency of this (type of) pop up? Rather have (only) pop ups not have any transparancy.
pedolsky
(Pedolsky)
2
Should be primary-background-color .
To soften the transparent effect, you can try
mdc-dialog-scrim-color: rgba(0, 0, 0, .5)
mdc-dialog-backdrop-blur: .5vw
Tyfoon
(@Tyfoon)
3
If people ever look for a solution, it should be:
mdc-theme-surface: rgba(43,55,78,1)
thank you, this works on dialog popups in the dashboard, but the ones in settings. have you found another solution for this?
