What do I need to get started to replace Alexas with Home Assistant
Hi, I have a number of HiveHome, SmartLife and CozyLife devices that I control via Alexa. I’m looking to remove Alexa and replace it with a Home Assistant Yellow along with Home Assistant Voice Preview Edition. Before I do this, I have a number of questions, such as are all of my devices supported and can I have multiple HA Voice PE boxes in different rooms.
Is this the best place to ask these questions? Is there already somewhere with answers to these questions?
Thanks, Martin
It is the place.
On the devices, you will need to give specific details about what they are, but a broad brushstroke reply would be “Check to see if there is an integration.” If there is, Voice PE should be able to control the device, if there isn’t, it may not. There is a list of integrations here:
If there isn’t a built-in integration, you may be able to find a custom one in the Community Store.
You should bear in mind that functionality may be a bit different from what you’re used to with Alexa. The “experience” of using Voice PE will also be different, so just buy one to start with - but yes, you can have one in each room.
That’s an excellent start. Many thanks.
