What docker image I need to install on my QNAP TS-231P2 NAS?
Hi all,
I have a QNAP TS-231P2 with Docker support.
On this page https://www.home-assistant.io/docs/installation/docker/
I read to select image “homeassistant/home-assistant” on Docker hub.
I tried it but the container won’t start. I think can be a problem on “format” image not compatible with ARM version of my QNAP ARM platform.
The dockerHUB page https://hub.docker.com/u/homeassistant list 176 images.
I’m lost on it.
What is the docker image for my QNAP ?
Many thank’s
Solved. This is the correct image.
https://hub.docker.com/r/homeassistant/armhf-homeassistant
It run perfectly.
Ciao
You installed Home Assistant but tagged your thread as Hass.io. Which did you want to install?
I think you can install Hass.io on your QNAP but the instructions are a little scattered. I can try to gather them up if you wish to try. I do not have a QNAP to test.
