I see this on my cameras, but I have no idea what it does. I know that it’s supposed to reduce latency when streaming from an ip camera, but I can’t see a difference if it’s checked or not.
The documentation says this:
The
Preload stream
option will start the camera feed on Home Assistant startup and continue to keep the stream alive. This will result in reduced latency when opening the stream in the frontend, as well as when using theplay_stream
service or Google Assistant integration. It does, however, utilize more resources on your machine, so it is recommended to check CPU usage if you plan to use this feature.
Would that I am running HA on an Intel NUC i5 be why I don’t see a difference?
Not necessarily.
I guess your camera is pretty quick at starting a new stream.
If you want to reduce camera lag, this option works well.
Yeah I always ithought that, inever iowned one.
