This topic is part of the community-driven cookbook where you can find other topics you might be interested in or might like to contribute to.
This gets asked a lot. Obviously it means there’s something wrong with your yaml, but what?.
The error can point to a variety of things, but you should be able to locate the problem by searching for the key given in the square brackets.
YAML stores each item of data along with a key to identify it. The keys are the words followed by a colon - depending on the editor you’re using they may also be highlighted.
So if the error is “extra keys not allowed @ data[‘trigger’]” check the triggers in your automation for problems.
Common problems
Syntax errors
The most common issue is incorrect spacing. If a key contains other keys, YAML expects lines to be indented.
This will work - the actions key contains if and then keys, which contain further keys:
actions:
- if:
- condition: trigger
id:
- detected
then:
- target:
entity_id: switch.all_living_room_lights
action: switch.turn_on
This will not (because the condition key is not indented):
actions:
- if:
id:
- detected
then:
- target:
By convention, indentations in HA are two spaces, but any number of spaces will do provided they are all the same.
Lists are another common cause of error. This will work:
service: homeassistant.turn_on
entity_id:
- light.one
- light.two
and this will work:
entity_id: light.one, light.two
…but this will not:
entity_id:
light.one
light.two
…because the list of entities is incorrectly formatted.
Unsupported keys
If you’re editing a script, the trigger: key will generate an error - scripts don’t have triggers. If you’re editing an automation, fields: will do it - automations can’t have fields.
Check your typing!
triggers:
- tigger: state
entity_id:
- input_boolean.away_mode
to: "on"
