My Home Assistant gives me lately a warning: Available space is less than 1GB!
But I do not know what file(s) are eating the space om my SD card.
Running with RPi4
- Installatiemethod Home Assistant OS
- Core 2025.5.2
- Supervisor 2025.05.3
- Operating System 15.2
- Frontend 20250516.0
Info from command line:
→ / du -h
From the root it tells me all the files together are using 3.0G
→ / df -H
Filesystem Size Used Available Use% Mounted on
overlay 13.9G 12.5G 804.0M 94% /
/dev/mmcblk0p8 13.9G 12.5G 804.0M 94% /data
/dev/mmcblk0p8 13.9G 12.5G 804.0M 94% /addon_configs
/dev/mmcblk0p8 13.9G 12.5G 804.0M 94% /addons
/dev/mmcblk0p8 13.9G 12.5G 804.0M 94% /share
/dev/mmcblk0p8 13.9G 12.5G 804.0M 94% /backup
/dev/mmcblk0p8 13.9G 12.5G 804.0M 94% /media
/dev/mmcblk0p8 13.9G 12.5G 804.0M 94% /ssl
/dev/mmcblk0p8 13.9G 12.5G 804.0M 94% /homeassistant
devtmpfs 1.6G 0 1.6G 0% /dev
tmpfs 1.8G 0 1.8G 0% /dev/shm
/dev/mmcblk0p8 13.9G 12.5G 804.0M 94% /run/audio
/dev/mmcblk0p8 13.9G 12.5G 804.0M 94% /etc/asound.conf
tmpfs 757.9M 1.6M 756.3M 0% /run/dbus
/dev/mmcblk0p8 13.9G 12.5G 804.0M 94% /etc/resolv.conf
/dev/mmcblk0p8 13.9G 12.5G 804.0M 94% /etc/hostname
/dev/mmcblk0p8 13.9G 12.5G 804.0M 94% /etc/hosts
/dev/mmcblk0p8 13.9G 12.5G 804.0M 94% /etc/pulse/client.conf
tmpfs 757.9M 1.6M 756.3M 0% /run/log/journal
/dev/mmcblk0p8 13.9G 12.5G 804.0M 94% /var/log/journal
tmpfs 1.8G 0 1.8G 0% /proc/asound
devtmpfs 1.6G 0 1.6G 0% /proc/interrupts
devtmpfs 1.6G 0 1.6G 0% /proc/keys
devtmpfs 1.6G 0 1.6G 0% /proc/latency_stats
devtmpfs 1.6G 0 1.6G 0% /proc/timer_list
tmpfs 1.8G 0 1.8G 0% /sys/firmware
Do I have to run a somekind of diskrepair of are there other commands to find that place where space consuming files are stored?
