What happened to scenes?
From the settings menu I see the option for scenes in the usual spot. I can’t even trigger a scene by manually calling it from from the type in window.
menu
When I go into the menu scenes is not there…
no screnes
Trying to use the type in menu to call my goodnight scene
goodnight
Error!
not turn on
This used to work fine. What happened? I’m running hassos in a VM.
Still working here.
Look in Settings → System → Logs.
Do you see an error about the scene integration not being able to be loaded?
Look in configuration.yaml. Do you see:
scene:
I restore from a backup and now it works. Not sure what happened.
Very likely this because you had a configuration issue that could have been solved without a restore from backup:
