Now my question is, what in the world could possibly be filling up my disk? When ESPresense devices are active, my disk just starts to FILL up at a RAPID. Nothing I’ve done reclaims the space either. I’ve tried to purge both parts of the recorder and have been clearing DB frequently, shouldn’t that reclaim my disk space? Only thing I could think these ESPs are affecting is logs from the consistent stream of information coming in from the ESPs, so why wouldn’t I get my disk space back upon clearing and purging?
I know that with Home Assistant OS there is a directory that is “hidden” from UI and stores incomplete backups, interrupted backups, bad addon installations, and the only way to clear this is to SSH into the box on a special port so you can access the overlay directory.
Not saying that’s your issue, but depending on how you run HA, could be…
@Tinkerer The reason I saw this as an MQTT question is because they communicate via MQTT. If it is only filling while they are active, it has to be related to the MQTT signal being received in some way.
Version core-2022.7.2
Installation Type Home Assistant OS
Development false
Supervisor true
Docker true
User root
Virtual Environment false
Python Version 3.10.5
Operating System Family Linux
Operating System Version 5.15.32-v8
CPU Architecture aarch64
Timezone America/Denver
Configuration Directory /config
Home Assistant Community Store
GitHub API ok
GitHub Content ok
GitHub Web ok
GitHub API Calls Remaining 4317
Installed Version 1.26.0
Stage running
Available Repositories 1077
Downloaded Repositories 108
AccuWeather
Reach AccuWeather server ok
Remaining allowed requests 39
Home Assistant Cloud
Logged In true
Subscription Expiration July 25, 2022 at 6:00 PM
Relayer Connected true
Remote Enabled true
Remote Connected true
Alexa Enabled true
Google Enabled true
Remote Server
Reach Certificate Server ok
Reach Authentication Server ok
Reach Home Assistant Cloud ok
Home Assistant Supervisor
Host Operating System Home Assistant OS 8.2
Update Channel stable
Supervisor Version supervisor-2022.07.0
Agent Version 1.2.1
Docker Version 20.10.14
Disk Total 238.0 GB
Disk Used 15.7 GB
Healthy true
Supported true
Board rpi4-64
Supervisor API ok
Version API ok
Installed Add-ons Samba share (10.0.0), Portainer (1.5.0), Spotify Connect (0.12.1), Mosquitto broker (6.1.2), File editor (5.3.3), Terminal & SSH (9.6.0), Home Assistant Google Drive Backup (0.108.2), Glances (0.16.0), AdGuard Home (4.6.0), Plex Media Server (3.0.0), Grocy (0.18.2), InfluxDB (4.5.0), motionEye (0.18.0), Uptime Kuma (0.1.0), Studio Code Server (5.1.2), room-assistant (2.20.0), diyHue (2.0.4)
Dashboards
Dashboards 4
Resources 72
Views 11
Mode storage
Recorder
Oldest Run Start Time July 9, 2022 at 3:53 AM
Current Run Start Time July 9, 2022 at 3:22 PM
Estimated Database Size (MiB) 174.29 MiB
Database Engine sqlite
Database Version 3.38.5
Sorry, a little bit inexperienced with SSH on OS instead of docker install. But… don’t you have to do something specific to enable root access?
CMD, tried how you put it, then tried replacing homeassistant with my instance name:
C:\WINDOWS\system32>ssh root@homeassistant -p 22222
ssh: Could not resolve hostname homeassistant: No such host is known.
C:\WINDOWS\system32>ssh root@prohome -p 22222
ssh: connect to host prohome port 22222: Connection refused
Lemme know if you need help. If you’re using SSH you already have a key pair. They’re probably stored in a .ssh or ssh_keys directory. There will be one called id_rsa and another called id_rsa.pub. The contents of the pub one is your public key.
Not sure what that means.
Also, if you’re not sure what you’re doing, you may not want to do this. That said, this is how to create keys and once you have keys, you can then use that other article to put them on your server.
I’ve been doing most of this for a few years, it’s just little pieces of how things work that I’ve missed. No degrees or anything, but most of this is really easy to just look up and do. SSH into a pi running debian and HA Supervisor - easy, SSH into HA OS - not easy. I had actually originally switched to Supervisor on my Pi3b+ because I needed SSH and access to docker. I’m running this one solely for HA, so I went with OS, I wanted a “supported” install (not really sure why) and kept running into walls trying to install Bullseye straight up without Raspbian. (The 400 was a better price than a 4gb 4, I know I don’t need the keyboard built in for OS). The main reason I went OS is because I couldn’t get a 64 bit install to work any other way and from what I understand you can only get things like VSCode and a few others on 64 bit.
