What is an average CPU Load on an Intel NUC N3050 (Celeron)
Hi there,
I´m using an Intel NUC N3050 for about a year now, running Ubuntu 18.04 as base OS. At the beginning, the CPU load was around 15%, for the last 8 month around 20-22%.
Now, after the upgrade to 112.2 (and the finished database conversion), the CPU load has gone up to 30%.
I wonder if this is because of any bad coding by myself in my configuration, although there aren´t any heavy-complicated automations or scripts I´m aware of.
Is there something I can look after whats causing this? when using a taskmanager in the GUI of ubuntu, I get the “python3 -m homeassistant --config /config” process which is causing the load but I guess this is the whole homeassistant thing.
Maybe this?
Thanks for the tip but no. I disabled the speedtest Integration, but no effect on the cpu load.
My nuc with n3700 cpu does 19% load average. And peaks of 41%. With motioneye with two streams. And vscode installed.
