Why do I get these things ?
And is this normal ?
I already restarted HA and even my computer, but nothing helps…
2 probleme
1 some identities should have been renamed or removed (harmony) look for entities in your integartion list
2 ‘editor disabled because config stored in configuration.yaml’
it mean what it mean
I don’t understand, that the default dashboard and I never took control of it ?
I created a new one… can the old one been deleted ?
yes and you can choose wich one you prefer in user settings.
the default dashboard is with all entities from your integrations.
if you take control of it: you start with a blank one.
i always start with a blank one and add cards i wish.
It seems I can’t delete the default dashboard :
So, I set it back as default and empty the card :
How can I switch it back, so that HA updates automatically the entities on it ?
create a new one
u can copy all dashboard code with 3 dot up right.
paste the code in your first dashboard.
or juste use your new dashboard
