Following up on a question about switch vs light in a Sonoff running ESPHome, I ended up with the following configuration:
esphome:
platform: ESP8266
board: esp8285
binary_sensor:
- platform: gpio
pin:
number: GPIO0
mode: INPUT_PULLUP
inverted: True
on_press:
- switch.toggle: relay
switch:
- platform: gpio
pin: GPIO12
status_led:
pin:
number: GPIO13
inverted: yes
- platform: wifi_signal
update_interval: 60s
output:
- platform: gpio
pin: GPIO12
light:
- platform: binary
output: switch_status
This is visible in HA as:
The last switch is the light one, the one before is the switch.
I am now trying to understand how from the ESPHome configuration I get the elements in the screenshot.
binary_sensor is the physical button on the Sonoff.
switch is the actual electrical relay
output is an internal status of GPIO13 ← I am not sure of this one
light is a component which is driven (and which drives) the output.
If the above is correct:
- is
switchonly needed bybinary_sensorto act upon a physical press? - since I can toggle via the light component, does
outputactually change the state of the GPIO? (I think so) → I am asking becauseoutputwould suggest that this is just an indication of a state
