What is supposed to happen when an automation step fails for some reason?
I’ve got an automation I manually trigger where I want a hot water pump to run for some amount of time:
- alias: 'Hot Water'
  trigger: []
  - service: switch.turn_on
    entity_id: switch.garage_hotwater
  - delay:
      seconds: 510
  - service: switch.turn_off
  - service: notify.ios_all
      message: "Hot Water Ready"
      title: "Hot Water Ready"
This works great most of the time, but sometimes it seems like the switch.turn_on fails for some reason. It’s a z-wave switch and sometimes the signal gets lost, or other times somebody will trigger it when the switch is already on and it will fail.
When this happens it seems to skip the delay step and go straight into switch.turn_off and then the notify step.
Does anybody have any idea why the delay would be skipped? Is there some sort of error handling I should be performing? I couldn’t find any docs that talked about failure scenarios for actions.
Thanks!
If you re-trigger the automation while it is waiting in the delay it will skip the delay and proceed with the rest of the actions. It’s designed to operate that way.
A better way to approach this would be to simply turn the switch on manually. Then have an automation that turns the switch off after it has been on for 510 seconds.
- alias: 'Hot Water Off'
  initial_state: true
    platform: state
    to: 'on'
    for:
      seconds: 510
Ahh, that’s super helpful. That wasn’t clear.
I thought there were other cases where it skipped straight to the notify when something would fail, but maybe I’m wrong about that. I’ll keep an eye out to see if I see that or if it’s always when it’s retriggered.
Thanks!
I edited my reply with another way to approach the problem.
That’s a better solution in general I’d say.
Doesn’t quite work for me since I actually have two different automations for different delay lengths depending on where in the house I need the water.
But it does work nicely for me as an “auto off” since sometimes the switch.turn_off gets lost in the z-wave network and this ensure it doesn’t run forever.
Since its not using any automated trigger, why not use a script instead? Delays would not be skipped then. You can also have the first step of the script be something like:
script:
  hot_water:
    alias: Hot Water Control
    sequence:
    - service: script.turn_off
      entity_id: script.some_trigger script
    - delay:
        seconds: 510
EDIT: i made a mistake there with cancelling itself but you get the idea
I agree that a script is a better option, but stopping itself as the first action is going to mean it never gets any further.
There’s a few solutions to a lost signal, like put a delay of a few seconds and then call the service again, or use a wait_template with a short timeout to let you know if something didn’t work properly.
