I’d also like to know the same thing about CPU use as well.
I see occasional spikes up to around 60% CPU use according to system monitor. and that spike last for anywhere from 8-9 minutes every single time. But it’s not regular when it happens. It happens anywhere from 30 minutes to 2.5 hours apart.
I always thought it was from stuff outside of HA (I run a Kodi medfia server as well) but the recent discussions make me think that it is something that HA is doing buut I can’t figure out where it’s coming from.
So is the CPU usage only related to HA processes or is system wide?
Sorry, not trying to hijack the thread but I figure it’s related.
System wide (for a Home Assistant OS install it includes all containers, cant comment on other install methods) but, if you have a multi core processor it measures the sum of all cores. So 60% CPU use on a 2 core 4 thread processor (the maximum use you could see on that system would be 400%) is only really using 15% of the total available resources.
