So, I have a TRADFRI bulb, TRADFRI on/off switch, both joined to my zigbee2mqtt network and discovered in HA. I also have a Sonoff mini running tasmota. I want to
Be able to use the “primary function” (on off) of the light without any smarthome (in case of server down or HA install broken)
Not getting blinded by the light when power is back after a power outage
Use the dimmer function
What I did :
Set the bulb
power_on_behavior
toON
PowerRetain 1
on Tasmota
This will take care of the power outages and manual control of the light (Sonoff Mini has mechanical switch connection headers)
Created 5 automations with TRADFRI on/off:
ON action → turns sonoff mini on
OFF action → turns sonoff mini off
Move brightness up action → send mqtt
{"brightness_move": 40}
Move brightness down action → send mqtt
{"brightness_move": -40}
Stop brightness action → send mqtt
{"brightness_move": 0}
Is that the cleanest way to achieve this ? I think 5 automations is pretty “heavy” but could not think of a cleaner way.
Also, what would be the solution to the following problem : HA is down, my light turns on thanks to the Sonoff mini but the brightness is set to 1% (last state before shutdown) ?
