I am new to Hassio. I am trying to find a syntax for hassio CLI command to create a partial snapshot.
There is no example I can find on the internet, GitHub or this forum that can give any clue on how to do this.
Only I can find is options to take a full snapshot, which is no options.
This is what I come up with and it didn’t work.
# hassio snapshots new --name=Partial_2018-12-25:19:03 --options folders=homeassistant
ERROR
extra keys not allowed @ data['folders']. Got 'homeassistant'
It is very little help in there. Options perhaps can be used to specify the name or folders, but how to use for partial?
I am not even sure this ever worked unless someone can prove otherwise.
core-ssh:~# hassio snapshots new --help
NAME:
hassio snapshots - list, info, reload, new, restore, remove
USAGE:
hassio snapshots [command options] [arguments...]
OPTIONS:
--rawjson, -j Returns the output in JSON format
--options key=val,key2=val2, -o key=val,key2=val2 holds data for POST in format key=val,key2=val2
--filter prop1,prop2, -f prop1,prop2 properties to extract from returned data prop1,prop2
--slug slugofsnapshot used with 'info|remove|restore|new' actions to return info on a specific snapshot slugofsnapshot
--name value used with 'restore|new' actions to set a name for a snapshot
--password value used with 'restore|new' actions to set a password on a snapshot
